Hi! I’m developing a new integration, I already wrote the code for the config flow. But the UI doesn’t show any labels?
I have already added a strings.json and two language files (it.json / en.json)
config.flow.py
import logging
from typing import Any
import voluptuous as vol
import homeassistant.helpers.config_validation as cv
from homeassistant.exceptions import HomeAssistantError
from homeassistant.config_entries import (
ConfigEntry,
ConfigFlow,
OptionsFlow,
FlowResult,
from homeassistant.core import callback, HomeAssistant
from homeassistant import config_entries
from .const import DOMAIN
_LOGGER = logging.getLogger(__name__)
class SimpleAlarmConfigFlow(config_entries.ConfigFlow, domain=DOMAIN):
async def async_step_user(self, user_input=None):
"""Handle the initial step."""
errors = {}
if user_input is not None:
try:
_LOGGER.debug("User input: %s", user_input)
return self.async_create_entry(title="Simple Alarm", data=user_input)
except Exception as e:
_LOGGER.error(
"Errore durante la gestione del form: %s", str(e))
errors["base"] = "unknown_error"
data_schema = vol.Schema({
vol.Required("code"): str,
vol.Required("ip"): str,
vol.Required("port"): str,
vol.Required("macAddr"): str,
vol.Required("pinSuper"): str,
return self.async_show_form(
step_id="user",
data_schema=data_schema,
errors=errors,
it.json
"config": {
"step": {
"user": {
"title": "Configure Your Device",
"data": {
"code": "Access Code",
"ip": "Device IP Address",
"port": "Port Number",
"macAddr": "MAC Address",
"pinSuper": "Super User PIN"
