I don’t know why its error after error but, its driving me nuts. I’m just trying to see if temp1 < temp2 - variable.
update_interval: 30s
on_value:
if:
condition:
lambda: return (id(supply_air_temp).state > (id(return_air_temp).state + (id(heat_deg).state)));
then:
- lambda: id(heat_mode).publish_state(true);
- lambda: id(cooling_mode).publish_state(false);
- lambda: id(standby_mode).publish_state(false);
on_value:
if:
condition:
or:
- binary_sensor.is_on: heat_mode
- binary_sensor.is_on: cooling_mode
then:
- lambda: id(standby_mode).publish_state(true);
on_value:
if:
condition:
lambda: return (id(supply_air_temp).state < (id(return_air_temp).state - (id(ac_deg).state)));
then:
- lambda: id(cooling_mode).publish_state(true);
- lambda: id(heat_mode).publish_state(false);
/config/esphome/smith.yaml: In lambda function:
/config/esphome/smith.yaml:195:32: error: 'class esphome::dallas::DallasComponent' has no member named 'state'
/config/esphome/smith.yaml:195:58: error: 'class esphome::dallas::DallasComponent' has no member named 'state'
/config/esphome/smith.yaml:195:85: error: request for member 'state' in 'heat_deg->esphome::globals::RestoringGlobalsComponent<T>::value<int>()', which is of non-class type 'int'
/config/esphome/smith.yaml:225:32: error: 'class esphome::dallas::DallasComponent' has no member named 'state'
/config/esphome/smith.yaml:225:58: error: 'class esphome::dallas::DallasComponent' has no member named 'state'
/config/esphome/smith.yaml:225:83: error: request for member 'state' in 'ac_deg->esphome::globals::RestoringGlobalsComponent<T>::value<int>()', which is of non-class type 'int'
mulcmu
December 6, 2022, 12:23am
2
For the global values try .value or .value() instead of .state.
Not sure what is going on with the Dallas, can you post the yaml config for those?
zoogara
(Daryl)
December 6, 2022, 2:37am
3
For starters - for single line lambdas it is good practice to enclose them in quotes - e.g:
- lambda: 'id(standby_mode).publish_state(true); '
id(supply_air_temp).state should work fine, so yes - post the sensor config.
yes, thanks.
dallas:
- pin: GPIO23
update_interval: 10s
- pin: GPIO22
- platform: dallas
address: 0xA40000031F055028
name: "Supply Air Temp"
dallas_id: supply_air_temp
unit_of_measurement: "C"
device_class: "temperature"
state_class: "measurement"
filters:
- sliding_window_moving_average:
window_size: 15
send_every: 15
- debounce: 0.25s
# Dallas Sensor 2
- platform: dallas
address: 0xDD0000031EFB0428
name: "Return Air Temp"
dallas_id: return_air_temp
filters:
window_size: 15
send_every: 15
- debounce: 0.25s
here is all of it if that helps or if anyone has critiques or suggestions I can improve on.
globals:
- id: ac_deg
type: int
restore_value: yes
initial_value: "4"
- id: heat_deg
type: int
restore_value: yes
initial_value: "4"
substitutions:
devicename: smith # Name. Lowercase only, Used for Device Name and Entities
upper_devicename: Smith Heat/Cool
interval0: "2"
interval1: "3"
interval2: "4"
interval3: "5"
interval4: "6"
interval5: "2"
interval6: "3"
interval7: "4"
interval8: "5"
interval9: "6"
esphome:
comment: Heat/Cool Capacity Controller
project:
version: "1.0.0"
# Enter Standby Mode If ESP32 is Shut Down
on_shutdown:
priority: 700
then:
- switch.turn_off: capacity_75
- switch.turn_off: capacity_50
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "dCBKRt+U83BU14lOjmkWvoJDEXeZYRySs5XYUBGhCTk="
ota:
password: "69416d378e2dcbdb9d43f646bbbf8e72"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Smith Fallback Hotspot"
password: "YFpp0NDHnJV8"
captive_portal:
# Web Server to access logs, view and edit configurable settings
web_server:
port: 80
# Dallas Temp Sensor
dallas:
- pin: GPIO23
- pin: GPIO22
text_sensor:
# ESPHome version as sensor.
- platform: version
name: $devicename ESPHome Version
# WiFi information as sensors.
- platform: wifi_info
ip_address:
ssid:
bssid:
# Home Assistant Input Select Sensor for AC Degree Difference
select:
name: A/C Degree Difference
icon: mdi:timer-outline
optimistic: true
restore_value: true
initial_option: "4 Degrees"
options:
- $interval0 Degrees
- $interval1 Degrees
- $interval2 Degrees
- $interval3 Degrees
- $interval4 Degrees
on_value:
then:
- globals.set:
value: !lambda 'return x;'
# Home Assistant Input Select Sensor for Heat Degree Difference
name: Heat Degree Difference
optimistic: true
restore_value: true
options:
- $interval5 Degrees
- $interval6 Degrees
- $interval7 Degrees
- $interval8 Degrees
- $interval9 Degrees
on_value:
then:
- globals.set:
# Home Assistant Up Time Sensor
- platform: uptime
# Dallas Sensor 1
- platform: dallas
filters:
window_size: 15
send_every: 15
- debounce: 0.25s
# Dallas Sensor 2
- platform: dallas
filters:
window_size: 15
send_every: 15
- debounce: 0.25s
# Template Sensors
on_value:
if:
condition:
then:
- lambda: 'id(heat_mode).publish_state(true);'
- lambda: 'id(cooling_mode).publish_state(false);'
- lambda: 'id(standby_mode).publish_state(false);'
accuracy_decimals: 1
on_value:
if:
condition:
or:
then:
- lambda: 'id(standby_mode).publish_state(true);'
on_value:
if:
condition:
then:
- lambda: 'id(heat_mode).publish_state(false);'
- lambda: 'id(cooling_mode).publish_state(true);'
# Mode Status Sensor
binary_sensor:
device_class: cold
device_class: heat
# Control/Capacity Switches
switch:
turn_on_action:
turn_off_action:
name: "100% Capacity"
turn_on_action:
- platform: gpio
pin: GPIO19
name: "75% Capacity"
interlock: [capacity_50]
interlock_wait_time: 2s # 2 second delay for Relay 2 HIGH POWER
- platform: gpio
pin: GPIO17
name: "50% Capacity"
interlock: [capacity_75]
interlock_wait_time: 2s # 2 second delay for Relay 1 LOW POWER
mulcmu
December 6, 2022, 4:26pm
6
I think the id used for the lambda to get the temperature reading should be with the temperature configuration and not the dallas bus configuration.
dallas:
- pin: GPIO23
- pin: GPIO22
- platform: dallas
dallas_id: supply_air_temp_bus #edit
id: supply_air_temp #edit add id:
filters:
window_size: 15
send_every: 15
- debounce: 0.25s
#similar edits for return side
It throws an error when trying to split them up with different ID’s you cant see it in the screen shot but I changed the dallas id like your suggestion
mulcmu
December 7, 2022, 5:35pm
8
It looks like changing the id: around is a quirk or bug in the user interface. I got the same warning when making the change in the editor but disappeared after a HA restart.
To access the global values just the id(global) is all that is needed, no .state or .value necessary.
The below configuration compiles for me on 2022.11.1. I made one other fix to the template select lambdas.
globals:
- id: ac_deg
type: int
restore_value: yes
initial_value: "4"
- id: heat_deg
type: int
restore_value: yes
initial_value: "4"
substitutions:
interval0: "2"
interval1: "3"
interval2: "4"
interval3: "5"
interval4: "6"
interval5: "2"
interval6: "3"
interval7: "4"
interval8: "5"
interval9: "6"
esphome:
project:
version: "1.0.0"
on_shutdown:
priority: 700
then:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
api:
encryption:
ota:
wifi:
ap:
captive_portal:
web_server:
port: 80
dallas:
- pin: GPIO23
- pin: GPIO22
text_sensor:
- platform: version
ip_address:
ssid:
bssid:
select:
optimistic: true
restore_value: true
options:
on_value:
then:
- lambda: 'id(ac_deg)=String(x.c_str()).toInt();'
optimistic: true
restore_value: true
options:
on_value:
then:
- lambda: 'id(heat_deg)=String(x.c_str()).toInt();'
- platform: uptime
# Dallas Sensor 1
- platform: dallas
filters:
window_size: 15
send_every: 15
- debounce: 0.25s
# Dallas Sensor 2
- platform: dallas
dallas_id: return_air_temp_bus
filters:
window_size: 15
send_every: 15
- debounce: 0.25s
# Template Sensors
on_value:
if:
condition:
lambda: 'return (id(supply_air_temp).state > (id(return_air_temp).state + id(heat_deg))); '
then:
on_value:
if:
condition:
or:
then:
on_value:
if:
condition:
lambda: 'return (id(supply_air_temp).state < (id(return_air_temp).state - id(ac_deg)));'
then:
binary_sensor:
device_class: cold
device_class: heat
switch:
turn_on_action:
turn_off_action:
turn_on_action:
- platform: gpio
pin: GPIO19
- platform: gpio
pin: GPIO17
yes, i figured that out yesterday. I was trying to call the dallas component instead of the dallas sensor and giving it an ID was the issue. Its always the last thing you check too…
