I am trying to determine the state of a “my_binary_sensor” within a ESPhome script.
My goal is to set the colour of WS2812 LED within a script instead of determining it before calling the script.
As you can see in the program, in the creation o f"my_binary_sensor" I set parameter couleur [1,0,0] or [0,1,0] before executing the script. Using on_press/on_release (I don’t understand why using theses, this is not a button, but it works for me) I execute the script with proper parameter.
Every minute (using time:) I wish to flash the LED with the colour according to the state of “my_binary_sensor”.
By, determining the state of my_binary_sensor, within the script, and setting the colors accordingly, this will ensure that every time I execute the script, I will always get the same result.
Here is my code:
# Spare Unit
substitutions:
devicename: d1mini-06
friendly_name: Spare D1mini-06
comment: Spare
esp_id: D1Mini_06
board_type: nodemcuv2
esphome:
friendly_name: ${friendly_name}
comment: ${comment}
esp8266:
board: ${board_type}
packages:
base: !include
file: package/basic.yaml
vars:
Uptime_update_inverval: 10min
light:
- platform: neopixelbus # Configure WS2812 LED
name: "Status LED" # (Un)/comment to make visable in Home Assistant and local WEB
variant: WS2812
pin: D6
num_leds: 2
flash_transition_length: 1500ms
type: GRB
restore_mode: ALWAYS_OFF
binary_sensor:
- platform: homeassistant
entity_id: input_boolean.msg_flag_contact_ss_porte_av
on_press:
- lambda: |-
std::vector<float> couleur{0, 1, 0};
id(my_script)->execute(couleur);
on_release:
- lambda: |-
std::vector<float> couleur{1, 0, 0};
time:
- platform: sntp
on_time:
# Every minute
- seconds: 0
minutes: /1
then:
- logger.log: "Entering the on_time block"
- repeat:
count: 2
then:
#- logger.log: "Entering the repeat block"
- lambda: |-
std::vector<float> couleur{.1, 0,0};
- delay: 1s
script:
- id: my_script
parameters:
couleur: float[]
then:
- if:
condition:
lambda: return (id(my_binary_sensor).state));
then:
- logger.log: "ON"
else:
- logger.log: "OFF"
- light.turn_on:
brightness: 100%
red: !lambda return couleur[0] ;
green: !lambda return couleur[1] ;
blue: !lambda return couleur[2] ;
flash_length: 2s
While “install” the program, I get the following error
/config/esphome/d1mini-06.yaml: In lambda function:
/config/esphome/d1mini-06.yaml:74:39: error: expected ';' before ')' token
74 | lambda: return (id(my_binary_sensor).state));
/config/esphome/d1mini-06.yaml:74:39: error: expected primary-expression before ')' token
I read the documentation many time but either did not understand / figure out how to fix it.
Any suggestion how to fix this problem would be appreciate.
