hello,
it’s possible save lambda delay after reboot or power off?
I try to add the parameter “restore_value” but doesn’t save anything after reboot or power off
switch:
- platform: gpio
pin: P14
icon: "mdi:garage"
on_turn_on:
- delay: !lambda return (id(TDLB).state);
- switch.turn_off: relay1
number:
name: "TDL Basculante"
optimistic: true
min_value: 250
max_value: 10000
step: 250
mode: slider
restore_value: true
Mikefila
(Mike Fila)
2
You can try with a global, use an on_value
trigger under the number to mirror the number value and use the global in the lambda.
https://esphome.io/guides/automations#global-variables
Edit you can set the logger to VERBOSE and you should see what is going on, my thought is that the number loads after.
https://esphome.io/components/logger#logger-manual-tag-specific-levels
Masterzz
(Igors Micko)
3
For esp8266
platfoem check this setting:
- restore_from_flash (Optional, boolean): Whether to store some persistent preferences in flash memory. Defaults to
false
IMHO it required ro save number
value.
