None of the buttons on the MJ-SD01 seem to work when I use an an !include.
Maybe it has something to do with the lambdas?
If I use !include .base.light.mjdimmer.yaml, it validates and uploads no problem, but none of the buttons respond to input.
# Basic Config
substitutions:
# # https://esphome.io/guides/configuration-types.html#substitutions
device_name: mjd-officelight # hostname & entity_id
friendly_name: Office # Displayed in HA frontend
pwm_min_power: 15% # keep dimming functional at lowest levels
no_delay: 0s # transition when changing dimmer_lvl & relay delay
transition_length: .5s # transition when turning on/off
long_press_min: .4s # minimum time to activate long-press action
long_press_max: 2s # maximum time to activate long-press action
long_press_up: 100% # long press brightness
long_press_down: 33% # long press brightness
long_press_main: 50% # long press brightness
# Number of incremental steps between 0 and 100% intensity with the up/down
# buttons.
steps: "8"
gamma_correct: "2.0" # Default gamma of 2.8 is generally too high.
esphome:
# https://esphome.io/components/esphome
platform: ESP8266
board: esp01_1m
esp8266_restore_from_flash: true
<<: !include .base8266.yaml
<<: !include .base.light.mjdimmer.yaml
If i replace <<: !include .base.light.mjdimmer.yaml with the actual yaml the buttons respond.
binary_sensor:
- platform: gpio
# https://esphome.io/components/binary_sensor/gpio.html
#name: "${friendly_name} Up Button"
pin:
number: GPIO0
inverted: True
mode: INPUT_PULLUP
on_press:
# https://esphome.io/components/binary_sensor/index.html#on-press
- if:
condition:
light.is_on: dimmer
then:
- lambda: !lambda |-
// Similar to light.dim_relative but add the flashing.
auto val = id(dimmer).remote_values.get_brightness();
if (val >= (${steps}.0f-1.0f)/${steps}.0f) {
val = 1.0f;
} else {
val += 1.0f/${steps}.0f;
auto call = id(dimmer).turn_on();
call.set_brightness(val);
call.perform();
if (val == 1.f) {
id(flash_lights).execute();
else:
- light.turn_on:
brightness: "${long_press_up}"
on_click:
# https://esphome.io/components/binary_sensor/index.html#on-click
min_length: ${long_press_min}
max_length: ${long_press_max}
then:
- light.turn_on:
- platform: gpio
#name: "${friendly_name} Down Button"
pin:
number: GPIO1
inverted: True
mode: INPUT_PULLUP
on_press:
- if:
condition:
light.is_on: dimmer
then:
if (val <= 1.0f/${steps}.0f) {
val = .01f;
} else {
val -= 1.0f/${steps}.0f;
call.perform();
if (val == 0.01f) {
else:
- light.turn_on:
brightness: "${long_press_down}"
on_click:
then:
- light.turn_on:
- platform: gpio
#name: ${friendly_name} Main Button
pin:
number: GPIO15
mode: INPUT_PULLUP
on_press:
# TODO: Use "light.toggle: dimmer" instead of the code below if you want
# to keep the previous brightness by default.
- if:
condition:
light.is_on: dimmer
then:
- light.turn_off: dimmer
else:
- light.turn_on:
brightness: "${long_press_main}"
on_click:
then:
- light.turn_on:
light:
- platform: status_led
pin:
number: GPIO4
inverted: True
- platform: monochromatic
# https://esphome.io/components/light/monochromatic.html
output: pwm
default_transition_length: ${no_delay}
gamma_correct: "${gamma_correct}"
effects:
- flicker:
alpha: 90%
intensity: 25%
- strobe:
colors:
- state: true
brightness: 100%
duration: 500ms
- brightness: 1%
duration: 750ms
on_state:
- script.execute: set_lights
script:
- id: set_lights
then:
- lambda: |-
if (id(dimmer).remote_values.get_state() == 0.f) {
id(led2).turn_off();
id(led3).turn_off();
id(led4).turn_off();
id(led5).turn_off();
// Comment the following line out if you don't want the red LED when
// the dimmer is off.
id(ledred).turn_on().perform();
return;
id(ledred).turn_off().perform();
if (val >= .1f) {
id(led2).turn_on();
} else {
if (val >= .36f) {
id(led3).turn_on();
} else {
if (val >= .73f) {
id(led4).turn_on();
} else {
if (val >= .9f) {
id(led5).turn_on();
} else {
- id: flash_lights
then:
- output.turn_on: led2
- output.turn_on: led3
- output.turn_on: led4
- output.turn_on: led5
- delay: 150ms
- output.turn_off: led2
- output.turn_off: led3
- output.turn_off: led4
- output.turn_off: led5
- delay: 150ms
- delay: 150ms
- delay: 150ms
output:
- platform: esp8266_pwm
# https://esphome.io/components/output/esp8266_pwm.html
power_supply: relay
pin: GPIO13
# Even lower frequency can be used. 120 Hz works fine in 60 Hz countries.
frequency: 300 Hz
min_power: ${pwm_min_power}
- platform: gpio
# https://esphome.io/components/output/gpio.html
pin: GPIO14
inverted: true
- platform: gpio
pin: GPIO12
inverted: true
- platform: gpio
pin: GPIO5
inverted: true
- platform: gpio
pin: GPIO3
inverted: true
power_supply:
- id: relay
# https://esphome.io/components/power_supply.html
pin:
number: GPIO16
inverted: True
enable_time: ${no_delay}
keep_on_time: ${no_delay}
wifi:
# https://esphome.io/components/wifi
domain: !secret domain
power_save_mode: none
networks:
- ssid: !secret iot_wifi_ssid
password: !secret iot_wifi_pass
# hidden: true
ap:
ssid: ${friendly_name}_AP
password: !secret wifi_pass
# channel: 1
manual_ip:
static_ip: 192.168.1.1
gateway: 192.168.1.1
subnet: 255.255.255.0
# Enable Home Assistant API
api:
web_server:
port: 80
# https://esphome.io/components/web_server.html
logger:
baud_rate: 0 #disable UART logging since we aren't connected to GPIO1 TX
# https://esphome.io/components/logger
ota:
password: !secret default_password
# https://esphome.io/components/ota
time:
- platform: sntp
timezone: US/Central
servers:
- !secret sntp_server1
- !secret sntp_server2
binary_sensor:
# Reports if this device is Connected or not
- platform: status
- platform: wifi_signal
update_interval: 60s
# Reports how long the device has been powered (in minutes)
- platform: uptime
filters:
- lambda: return x / 60.0;
unit_of_measurement: minutes
text_sensor:
# Reports the ESPHome Version with compile date
- platform: version
name: ${friendly_name} ESPHome Version
- platform: wifi_info
ip_address:
name: ${friendly_name} IP Address
ssid:
name: ${friendly_name} Connected SSID
bssid:
name: ${friendly_name} Connected BSSID
mac_address:
name: ${friendly_name} Mac Wifi Address
switch:
- platform: restart
