I am working with an example YAML file that is doing something odd with a Lambda. Can anyone expand on what the writer may have been doing?
The code:
- delay: !lambda "return 200;"
Works exactly as:
- delay: 200ms
In the original code, where does ESPHome compiler get the time period (ms)? How does it know to use ms and not sec or other time period?
Is there a reason to use the lambda instead of the simpler delay code?
Be interesting to see the difference in the resulting c++ code.
Lambda’s are for computed variables, like if you want a different delay depending on the state of something else. There is no point in adding a lambda with no calculation or decision.
I think within a lambda the default is ms and you don’t need to specify the unit but anything that is in the ESPHome layer you need to specify the unit.
The default unit is ms but when using the esphome delay function as delay: xxx you need to include the time unit for the parser to recognize the value correctly and create the resultant code accordingly in the generated C++ code. for example this is the generated code when using 200ms:
delayaction = new DelayAction<>();
delayaction->set_component_source("template.switch");
App.register_component(delayaction);
delayaction->set_delay(200);
This is what is generated when using 200s (seconds)
delayaction->set_delay(200000); //note that 200s has been converted to milli seconds
This is the generated code with the lambda “return 200” (note that it returns the exact value entered)
As was noted before though, there is no need whatsoever to use a lambda in this case since it’s not doing any calculations or using variables to calculate the resultant delay. This just adds uneeded complexity to the code.
