Hi. I have two sensors (one ultrasonic and one luxmeter) connected to my esp32. I’m trying to get ESP to evaluate the state of both and then loop a scipt that will turn on and off a switch until the luxmeter registers a value above 200.
- platform: bh1750
name: "BH1750 Illuminance"
update_interval: 1s
on_value:
then:
- if:
condition:
lambda: 'return id(luxmeter).state < 200 && return id(ultra).state < 0.5;'
then:
- script.execute: script_led
- delay: 0.5s
else:
- script.stop: script_led
- platform: ultrasonic
trigger_pin: GPIO05
echo_pin: GPIO18
update_interval: 0.25s
switch:
- platform: gpio
pin: GPIO26
script:
- id: script_led
mode: queued
then:
- switch.turn_on: "green_led_switch_esp32"
- delay: 0.5s
- switch.turn_off: "green_led_switch_esp32"
I’m getting the following error:
/config/esphome/esp32-1.yaml:149:28: error: expected primary-expression before '<' token
if (id(luxmeter).state) < 500 and (id(ultra).state) < 0.5 {
/config/esphome/esp32-1.yaml:155:11: error: expected primary-expression before 'switch'
/config/esphome/esp32-1.yaml:154:7: warning: label 'turn_on_action' defined but not used [-Wunused-label]
turn_on_action:
/config/esphome/esp32-1.yaml: In lambda function:
/config/esphome/esp32-1.yaml:50:38: error: expected primary-expression before 'return'
lambda: 'return id(luxmeter).state < 30 && return id(ultra).state < 0.5;'
/config/esphome/esp32-1.yaml:50:38: error: expected ';' before 'return'
/config/esphome/esp32-1.yaml:156:3: warning: control reaches end of non-void function [-Wreturn-type]
*** [/data/esp32-1/.pioenvs/esp32-1/src/main.cpp.o] Error 1
========================= [FAILED] Took 19.53 seconds =========================
I’m completely new to writing lambdas so I can’t really tell what the issue is. Any ideas?
