I am trying to understand this YAML language .. I am trained in C ++ .... it is explained very badly in esphome
how can i run a script use this lambda?
.state: Retrieve the current state of the binary sensor.
// Within lambda, get the binary sensor state and conditionally do something
if (id(my_binary_sensor).state) {
// Binary sensor is ON, do something here
} else {
// Binary sensor is OFF, do something else here
You don’t need lambda for that.
There is plenty of documentation, and many examples.
thanks for your help but I don’t find many examples, and if there are examples of user projects with personal reasoning.
the esphome documentation is explained as if any user already knew that language.
It’s a nice project but very badly explained.
If I have to predict a condition in a file if a variable is incremented, I don’t necessarily have to expect a sensor that changes state by inserting on_press etc. functions that are not needed, I want to change the state of the sensor based on other logics but this is not possible or I can’t understand
How about you provide an actual example of what you are trying to?
PS the lambda code is c++
