For volume and brightness it’s a little more complex, than changing clockface.
If your are interested, I’ll write the “process” I must remember how I have do it ^^’
If you have already played with REST api it’s not complicated
Obtain your Lametric time local ip
- Depend on your Router
- OR use the mobile application
Settings → Wi-Fi → IP Address
(LAMETRIC_IP)
Obtain your Token
- Create an account to developer lametric go to developer lametric
- go to devices account name → devices
- take the Api Key
- encode it to base64 dev:APIKEY
expl on linux :
echo dev:APIKEY | base64
the result is your token (YOURTOKEN) used for authentication in the header
Find the ID_OF_THE_WIDGET :
You can use an app or browser extension to make the request.
Personnaly on macOS I use rested.
http://LAMETRIC_IP:8080/api/v2/device/apps/
header => Authorization: Basic YOURTOKEN
you obtain for example:
"name": "snooze"
"vendor": "LaMetric",
"version": "2.2.13",
"version_code": "50",
"widgets": {
"<ID_OF_THE_WIDGET_THAT_YOU_WHANT_CALL>": {
"index": 0,
"package": "com.lametric.clock",
"settings": {
"_title": "Horloge"
"com.lametric.countdown": {
"actions": {
this is the full automation I use for clockface:
in configuration.yml :
lametric_clock_date:
url: 'http://LAMETRIC_IP:8080/api/v2/device/apps/com.lametric.clock/widgets/ID_OF_THE_WIDGET/actions/'
method: POST
headers:
Authorization: "Basic YOURTOKEN"
Content-Type: application/json
payload: '{"activate": "false","id": "clock.clockface","params": {"type": "page_a_day"}}'
content_type: 'application/json; charset=utf-8'
lametric_clock_weather:
method: POST
headers:
payload: '{"activate": "false","id": "clock.clockface","params": {"type": "weather"}}'
lametric_clock_custom:
method: POST
headers:
payload: '{"activate": "false","id": "clock.clockface","params": {"type": "custom", "icon":"{{ icone }}"}}'
The automation (change all 15s the clockface [Weather → custom → Date → custom {taken randomly in a list picture in base64}])
alias: LaMetric clockface
description: ''
- platform: time_pattern
minutes: /1
condition:
- condition: time
after: '06:15'
before: '22:00'
- service: rest_command.lametric_clock_weather
data: {}
- delay: '00:00:15'
- service: rest_command.lametric_clock_custom
icone: |-
"data:image/png;base64,‘’iVBORw0KGgoAAAANSUhEUgAAAAgAAAAICAYAAADED76LAAAACXBIWXMAAAsTAAALEwEAmpwYAAAAeUlEQVQYlXWMvwmDQBSHvyeCZAabZwrBEY40qW4I17DLAHYpXcEhrhe3OOwyQkj1Ugm5B/m631/pVClIwYi7nLLCE3chBftf+H0Cau/nQ43+BcBV3UM+1D6PsRhUPmzmFYBlaAEQ4244lqHl+d4EQDpVpsutKJ0hwBca0yGxC/Gv9QAAAABJRU5ErkJggg==",
"data:image/gif;base64,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",
"data:image/gif;base64,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",
"data:image/gif;base64,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",
"data:image/gif;base64,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",
"data:image/gif;base64,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",
"data:image/gif;base64,R0lGODlhCAAIAIAAACQiJPz+/CH/C05FVFNDQVBFMi4wAwEAAAAh+QQJRgAAACwAAAAACAAIAAACDgyOEJa37Rh6ia47MQQFACH5BAkoAAAALAAAAAAIAAgAgSQiJPz+/FRSVAAAAAIPDI4QlrftGHqJiiskFvAUADs=",
] | random }}
- delay: '00:00:15'
- service: rest_command.lametric_clock_date
data: {}
- delay: '00:00:15'
icone: |-
] | random }}
mode: single
you can find all endpoints here : Device API Documentation — LaMetric v1.7.7 documentation
Documentation to obtain IP …
lametric Documentation
Hope this can help you
