Greetings all, new to Home Assistant after several years with SmartThings and IFTTT (and not that happy with either). Recently added a LaMetric Time, and am designing my first Node Red Flow to push notifications to it.
Right now, when my flow runs, it can take 3 minutes for the notification to push to the LaMetric cloud and get back to the device (meanwhile my Google Home devices are near instantaneous). Obviously, not the optimal thing when you want a time sensitive alert to go off. I started doing some digging, and found that LaMetric has published an API for Local Push for notifications, so you aren’t dependant on the cloud.
Would it be possible to have a version of the integration that would do local push? Likewise there are some options (alarms, repeat sound, etc.) that the current integration doesn’t yet support that could easily be incorporated in as well.
Hi !
I’m trying your rest command and script because I want to use the alarms sound, notifications sounds are too soft and too low for my use.
The IP in your URL is the IP of the LaMetric not HA ?
How do you get the lametric_device_api ? In the official implementation I get a client id and a client secret.
And last but not least when trying to test your script, I get a Message malformed: extra keys not allowed @ data[‘lametric_test’]
Help will be appreciated
