Did you mean the configuration.yaml? If yes, here it is:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
recorder:
purge_keep_days: 10
auto_purge: true
auto_repack: true
exclude:
entities:
- sensor.date_time
- sensor.date_time_iso
- sensor.time
- sensor.time_date
In case you meant the system information, here it is:
## System Information
version | core-2025.12.4
installation_type | Home Assistant OS
dev | false
hassio | true
docker | true
container_arch | amd64
user | root
virtualenv | false
python_version | 3.13.9
os_name | Linux
os_version | 6.12.51-haos
arch | x86_64
timezone | Europe/Berlin
config_dir | /config
<details><summary>Home Assistant Community Store</summary>
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
HACS Data | ok
GitHub API Calls Remaining | 5000
Installed Version | 2.0.5
Stage | running
Available Repositories | 2500
Downloaded Repositories | 2
</details>
<details><summary>Home Assistant Cloud</summary>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Home Assistant OS 16.3
update_channel | stable
supervisor_version | supervisor-2025.12.3
agent_version | 1.7.2
docker_version | 28.3.3
disk_total | 294.6 GB
disk_used | 7.4 GB
nameservers | 192.168.1.1
healthy | true
supported | true
host_connectivity | true
supervisor_connectivity | true
ntp_synchronized | true
virtualization | kvm
board | ova
supervisor_api | ok
version_api | ok
installed_addons | File editor (5.8.0), Z-Wave JS (0.27.0), Z-Wave JS UI (6.1.2), Get HACS (1.3.1), Mosquitto broker (6.5.2), Zigbee2MQTT (2.7.1-1)
</details>
<details><summary>Dashboards</summary>
dashboards | 2
resources | 0
views | 0
mode | storage
</details>
<details><summary>Network Configuration</summary>
adapters | lo (disabled), enp6s18 (enabled, default, auto), docker0 (disabled), hassio (disabled), vethe476d9d (disabled), vethd2fc9bb (disabled), veth22bf6ba (disabled), veth6f0e35e (disabled), veth8e4f935 (disabled), vetha4d7c45 (disabled), vethb3a1f22 (disabled), veth065b816 (disabled)
ipv4_addresses | lo (127.0.0.1/8), enp6s18 (192.168.1.225/24), docker0 (172.30.232.1/23), hassio (172.30.32.1/23), vethe476d9d (), vethd2fc9bb (), veth22bf6ba (), veth6f0e35e (), veth8e4f935 (), vetha4d7c45 (), vethb3a1f22 (), veth065b816 ()
ipv6_addresses | lo (::1/128), enp6s18 (fe80::8eac:3e34:edfa:5738/64), docker0 (fe80::84b1:f5ff:feeb:4132/64), hassio (fd0c:ac1e:2100::1/48, fe80::f4b2:a3ff:feea:73b0/64), vethe476d9d (fe80::dcdd:c4ff:fef9:cff6/64), vethd2fc9bb (fe80::8c52:97ff:fea7:7e6b/64), veth22bf6ba (fe80::308e:cbff:fe33:ae83/64), veth6f0e35e (fe80::b0e3:c7ff:fef0:c6ef/64), veth8e4f935 (fe80::3091:54ff:fe62:dae3/64), vetha4d7c45 (fe80::6460:97ff:fe52:de62/64), vethb3a1f22 (fe80::644c:93ff:fefb:daaa/64), veth065b816 (fe80::3094:dcff:fe7b:5496/64)
announce_addresses | 192.168.1.225, fe80::8eac:3e34:edfa:5738
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | December 21, 2025 at 14:00
current_recorder_run | December 27, 2025 at 02:01
estimated_db_size | 25.37 MiB
database_engine | sqlite
database_version | 3.49.2
</details>
