rogerio
(Rogerio Mota)
1
After the update 2022 8 0 some lamps stopped work whit white (and warm) and only work with colors.
![image](https://community-assets.home-assistant.io/original/4X/b/3/c/b3c6899ff95daa721f6516fb2cc42146a05747f3.png)
I have other lamps on the same HA work normal.
![image](https://community-assets.home-assistant.io/original/4X/e/3/1/e31df096352aec63528ed143669bb5fb34c4fc32.png)
All lamps are from the same manufacturer and some of the same model
Update to 2022_8_1, the same problem.
tom_l
4
No. I still don’t know which manufacturer (and hence integration) has the issue.
rogerio
(Rogerio Mota)
5
Sorry, I thought I spelled it wrong the first time.
They are.
Model HG06104A, HG06106B manufactured by Lidl Livarno.
A try reconfiguration (using ZHA) and get this output.
tom_l
6
Do you use zigbee2mqtt or ZHA?
rogerio
(Rogerio Mota)
7
ZHA.
I don’t know if this information can help. On developer tools show this.
Lamp whit problem.
![image](https://community-assets.home-assistant.io/original/4X/8/6/f/86f9b2a76977c1241f08eb1d7be4c22b8e329a3b.png)
Other lamp same manufacture but without problem.
![image](https://community-assets.home-assistant.io/original/4X/a/4/3/a43d8c38ed911e3384556d6703d368c19d40028f.png)
the color_temp no show on first.
Thanks.
tom_l
8
If you are sure this lamp actually supports color_temp you should raise an issue here:
https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A"integration%3A+zha"
rogerio
(Rogerio Mota)
9
I’m sure, it has been working here for over a year.
I will open a case there
Thanks for the answers.
jayjay
(JJ)
10
See that this is not a hot topic, but my zigbee light only gives me white, not able to dim and no RGB colours??
