LAN Names DNS Resolution Failing in Home Assistant OS and container
I’m running a DHCP and DNS Server with Microtik CHR mainly to be able to identify server and services by names.
I just noticed that in Home Assistant OS and Home Assistant container name resolution of my lan hosts fails when I use a name that point to a CNAME record instead of an A record.
To be more explicit, if I run nslookup X.lan in HAOS where X.lan is a static A entry in my DNS Server this give the correct IP address of the server and I can use X.lan almost everywhere in HA configurations files and while adding integrations with the UI.
But if I run nslookup Y.lan in HAOS or HA container where Y.lan is a static CNAME entry in my DNS Server that point to X.lan, this still give the correct IP address of the server but with a footnote ** server can't find Y.lan: NXDOMAIN and I can’t use Y.lan while adding integrations with the UI.
There something wrong in my setup?
There’s a bug somewhere?
