I want to read my Landis & Gyr E320 electricity meter with the component provided by aquaticus.
https://aquaticus.info/iec62056.html
Until now I’ve been doing this using an ESP8266 (Wemos D1 mini pro) with Tasmota. However, it seems to me that with the iec62056 component is better integrated into HA. Since it was running with Tasmota, I was naively thinking that it would be a piece of cake to make the transition. But no. ![]()
The script in Tasmota looks like:
>D
>B
=>sensor53 r
>M 1
+1,5,s,20,9600,E320
1,77070100020800ff@1000,Total Delivered,kWh,Total_out,1
1,77070100010800ff@1000,Total Consumed,kWh,Total_in,1
1,77070100100700ff@1,Current power,W,Power_in,0
1,77070100600100ff@#,Server-ID,,Meter_Number,0
https://tasmota.github.io/docs/Smart-Meter-Interface/#descriptor-syntax
The datasheet says 9600 Baud, 8-N-1.
At first I tried with the same hardware setup, i.e. GPIO5 as RX. But I received only a garbeled mess. As aquaticus recommends using the HW UART, I switched to the HW RX, i.e. GPIO3.
My yaml looks like:
external_components:
# IEC62056 component
- source: github://aquaticus/esphome@aquaticus-iec62056
components: [ iec62056 ]
uart:
rx_pin: GPIO3
tx_pin: GPIO1 # unused
baud_rate: 9600
data_bits: 8
parity: NONE
stop_bits: 1
iec62056:
mode_d: True
What I receive is the same/similar mess as with GPIO5:
[14:57:10][D][iec62056.component:174]: Meter identification: '/b'
[14:57:10][D][iec62056.component:232]: Connection start
[14:57:10][D][iec62056.component:323]: Data: 'R\x94'
[14:57:10][E][iec62056.component:338]: Invalid frame format: 'R\x94'
[14:57:10][D][iec62056.component:323]: Data: '\xbe\xad tw'
[14:57:10][E][iec62056.component:338]: Invalid frame format: '\xbe\xad tw'
[14:57:10][D][iec62056.component:323]: Data: 'R\x94w'
[14:57:10][E][iec62056.component:338]: Invalid frame format: 'R\x94w'
[14:57:10][D][iec62056.component:323]: Data: '\xbe\xad bR'
[14:57:10][E][iec62056.component:338]: Invalid frame format: '\xbe\xad bR'
[14:57:10][D][iec62056.component:323]: Data: ''
[14:57:10][E][iec62056.component:338]: Invalid frame format: ''
[14:57:10][D][iec62056.component:323]: Data: 'qc1\xa7'
[14:57:10][E][iec62056.component:338]: Invalid frame format: 'qc1\xa7'
[14:57:11][D][iec62056.component:323]: Data: '<q)21b'
[14:57:11][E][iec62056.component:338]: Invalid frame format: '<q)21b'
[14:57:11][D][iec62056.component:323]: Data: 'R\x94rb'
[14:57:11][E][iec62056.component:338]: Invalid frame format: 'R\x94rb'
[14:57:11][D][iec62056.component:323]: Data: '\xbe\xad
cC\xb9'
[14:57:11][E][iec62056.component:338]: Invalid frame format: '\xbe\xad
cC\xb9'
and so on
From the logs I would assume that the baud rate or the transmission parameters would be wrong. But I had checked with the datasheet. And 7-E-1 produces a similar mess.
Has anyone successfully used the IEC 62056-21 component with this meter?
Matthias.
P.S.
The raw output from the Tasmota console looked like:
11:11:47.011 : 77 07 01 00 60 32 01 01 01 01 01 01 04 4c 47 5a 01
11:11:47.013 : 77 07 01 00 60 01 00 ff 01 01 01 01 0b 0a 01 4c 47 5a 00 03 d5 52 94 01
11:11:47.061 : 77 07 01 00 01 08 00 ff 65 00 1c 41 04 72 62 01 65 02 80 81 4a 62 1e 52 03 69 00 00 00 00 00 00 0e 72 01
11:11:47.915 : 77 07 01 00 02 08 00 ff 01 72 62 01 65 02 80 81 4a 62 1e 52 03 69 00 00 00 00 00 00 1c 7b 01 01 01 63 6b 44 00 76 05 04
11:11:47.964 : 77 07 ff ff ff ff ff ff 0b 0a 01 4c 47 5a 00 03 d5 52 94 07 01 00 62 0a ff ff 72 62 01 65 02 80 81 4b 74
