I would like to display the last changed value of a device as an extra sensor.
My device has some sensors included (temperatur, humidity, pressur, battery level) and those do not update simultaniously. It seems, that the zigbee connection (with zigbee2mqtt) is not 100% stable, so I would like to check, when the sensor has sended the last updated.
I can grab the value, but the format with a value template is the absolute time.
How would I format the value to be a relative one like (“Updated 2 minutes ago”) when using the secondary value?
That’s my value template: value_template: "{{ states.sensor.hygrothermo_1_temperature.last_changed }}"
Second question:
How would I use the minimum last changed of all three sensor of my device?
Min(last_changed(temp, humidty, batterie)
Third question - maybe on templates, too:
I have to correct the temperature value by adding 0.5. After a reboot, I see 0.5 degree, till the sensor did send a new value. Is there an easy way to display NaN instead of 0.5, until I got the first real sensor value?
add device_class: timestamp to your configuration at the same indentation as value_template. When displayed in the UI, it will show “updated x min ago”. It will not display correctly in custom cards that don’t properly translate states. So as long as you use well made custom cards and the built in Lovelace cards, you should be good to go.
This would require a template sensor and some jinja magic
as long as it’s a date time object. as_timestamp converts it to a float and will always work even if last_changed is the date time as a string. I.E. through restart.
Nuts! I keep forgetting that (even when I have no reason to forget it). Hopefully pnbruckner’s correction is included in 0.96 to make this bug disappear into the dustbin of history.
Hold on … that’s for last_triggered whereas this is last_changed. Is this also affected by the deserialization bug?
EDIT
I don’t think the deserialization bug affects last_changed. The example I posted above was produced on my test system which I just turned on this morning. The last_changed for all three entities is a datetime object so the restoration feature performed the deserialization correctly.
if this is a single device, chances are that they all update at the same time. You are trying to get last changed. It’s a bit different because last_changed tells you the last value change. I don’t even know why you’d want last_changed for 3 different sensor values. To me, that value would be pointless.
Maybe sensor is missleading.
I would like to know the last value submitted of a device having 3, 5 or six sensors included.
In my case the sensors are Xiaomiweather sensors, one via Bluetooth and the others via zigbee2mqtt.
