Hi all,
I hope you can help, I’ve been trying to use “last_changed” as a trigger to turn a light off & I’ve been messing about with it for the last few days, just can’t seem to get it to work.
I want this Lifx light to turn off (but only after 5 mins of NO motion) and I can’t seem to get it to turn off = the trigger that turns it on works fine.
I started with one automation, that would turn on, then turn off & I couldn’t get it working so now I’ve added an Input Boolean and tried splitting them into two in the hope that would work better.
I’ll post the YAML below, but I think I’ve made that many changes that now I’m a bit lost (if you know that feeling & would appreciate if someone could point me in the right direction). `- id: ‘123’
alias: Hallway Motion to turn Light OFF AFTER NO Motion
- entity_id: input_boolean.hallway_motion
platform: state
to: ‘off’
condition:
- condition: template
value_template: “{% if as_timestamp(now()) - as_timestamp(states.input_boolean.hallway_motion.last_changed) > 2 %}true{% endif %}”
- data:
entity_id: bedroom_main_light
transition: 3
service: light.turn_off
- id: ‘888’
alias: Hallway Motion to Turn on Light after dark
platform: state
to: ‘on’
condition:
- condition: state
entity_id: light.bedroom_main_light
state: ‘off’
- condition: state
entity_id: switch.hallway_lamp
state: ‘off’
- condition: state
entity_id: sun.sun
state: below_horizon
- data:
brightness_pct: 8
color_temp: 400
transition: 1.5
service: light.turn_on`
I think I have tried that many variations of above that I just don’t know what else to try, I thought Value Templates would do the job. but I just can’t get them working, am I missing something? If someone/anyone can point me in the right direction, much appreciated.
Please follow the directions at the top of the page when posting YAML code.
I’m not sure I understand everything you want to do, but if you want an automation to trigger when an entity is in a particular state for at least a certain amount of time, then use the for:
parameter with a state trigger:
platform: state
entity_id: ENTITY_ID
to: SOME_STATE
for:
minutes: 5
See State Trigger.
My apology’s, I did use that little button to post the Yaml. Not too sure why it’s turnds out like that.
What I’d like is for a motion sensor to turn on my light in the hallway (I’ve got that not working just fine). And to only turn it off after 5 minutes of no motion in that area.
I tried your suggestion this morning and it didn’t manage to turn the light off.
Many thanks
You need to format right after you copy and paste the code into the post.
If you try something and it still doesn’t work, it helps to post the code as it is now so we can see if there’s something wrong. Just saying it doesn’t work isn’t very helpful.
Have you tried something like this:
- alias: Turn light off
platform: state
to: 'off'
for:
minutes: 5
transition: 3
BTW, in your original post, you didn’t enter the full entity_id of the light when calling the light.turn_off service. You just had bedroom_main_light
instead of light.bedroom_main_light
. That would definitely prevent it from working, regardless if you had the triggers and conditions correct.
Hi @pnbruckner,
Many thanks for all your help, the light now turns off. You were right in your last post in that it was missing the full format light.bedroom_main_light.
I’ve been trying & trying to get this working on my own, making so many changes and I think I got a bit lost.
Many thanks for your help.
I’ve been using these two automation for the last few weeks to turn the hallway light on/off after sunset, but I’ve noticed that after midnight the trigger stops working.
I tried to add a “before sunrise” condition but it caused to trigger to fail completely.
Is there a way to get this automation to work while the sun is below the horizon?
- id: ''
platform: state
to: 'on'
condition:
- condition: state
entity_id: light.hallway_main_light
state: 'off'
- condition: state
state: 'off'
- after: sunset
after_offset: -01:00:00
condition: sun
- data:
brightness_pct: 8
color_temp: 400
transition: 1.5
- id: ''
alias: Hallway motion to turn LIGHT OFF
for:
minutes: 5
platform: state
to: 'off'
condition:
- condition: state
state: 'on'
- data:
transition: 5
Many Thanks
Yes. Change your condition to:
condition:
- condition: state
state: 'off'
- condition: state
state: 'off'
- condition: or
conditions:
- after: sunset
condition: sun
- before: sunrise
before_offset: 01:00:00
condition: sun
Of course, adjust the before_offset as needed.
