Last_reported updates only when last_changed updates
I have added line template: !include templates.yaml to /homeassistant/configuration.yaml and created the file templates.yaml.
My template sensor is
- sensor:
  - name: "Tuya last reported"
    unique_id: sensor.tuya_last_reported
    icon: mdi:trending-up
    state: >-
      {% set sensorIn = "tuya_01_tz3000_fie1dpkm_ts0201_temperature" %}
      {% set lastReportDate = states.sensor[sensorIn].last_reported | string %}
      {% set lastReportChangedDate = states.sensor[sensorIn].last_changed | string %}
      {{lastReportDate}}
      {{lastReportChangedDate}}
lastReportDate and lastReportChangedDate are always the same. I have enabled debug mode in ZHA and I can see from /homeassistant/home-assistant.log that my sensor is sending rerorts.
2024-04-20 08:43:11.015 DEBUG (MainThread) [zigpy.zcl] [0xC201:1:0x0402] Decoded ZCL frame: TemperatureMeasurement:Report_Attributes(attribute_reports=[Attribute(attrid=0x0000, value=TypeValue(type=int16s, value=2074))])
2024-04-20 08:43:11.020 DEBUG (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0xC201:1:0x0402]: cluster_handler[temperature] attribute_updated - cluster[Temperature Measurement] attr[measured_value] value[2074]
2024-04-20 08:43:23.673 DEBUG (MainThread) [zigpy.zcl] [0xC201:1:0x0402] Decoded ZCL frame: TemperatureMeasurement:Report_Attributes(attribute_reports=[Attribute(attrid=0x0000, value=TypeValue(type=int16s, value=2075))])
2024-04-20 08:43:23.679 DEBUG (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0xC201:1:0x0402]: cluster_handler[temperature] attribute_updated - cluster[Temperature Measurement] attr[measured_value] value[2075]
!! lastReportDate and lastReportChangedDate are update to 2024-04-20 05:43:23.681579+00:00
2024-04-20 08:43:34.015 DEBUG (MainThread) [zigpy.zcl] [0xC201:1:0x0402] Decoded ZCL frame: TemperatureMeasurement:Report_Attributes(attribute_reports=[Attribute(attrid=0x0000, value=TypeValue(type=int16s, value=2077))])
2024-04-20 08:43:34.022 DEBUG (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0xC201:1:0x0402]: cluster_handler[temperature] attribute_updated - cluster[Temperature Measurement] attr[measured_value] value[2077]
2024-04-20 08:43:52.021 DEBUG (MainThread) [zigpy.zcl] [0xC201:1:0x0402] Decoded ZCL frame: TemperatureMeasurement:Report_Attributes(attribute_reports=[Attribute(attrid=0x0000, value=TypeValue(type=int16s, value=2077))])
2024-04-20 08:43:52.027 DEBUG (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0xC201:1:0x0402]: cluster_handler[temperature] attribute_updated - cluster[Temperature Measurement] attr[measured_value] value[2077]
2024-04-20 08:44:04.317 DEBUG (MainThread) [zigpy.zcl] [0xC201:1:0x0402] Decoded ZCL frame: TemperatureMeasurement:Report_Attributes(attribute_reports=[Attribute(attrid=0x0000, value=TypeValue(type=int16s, value=2078))])
2024-04-20 08:44:04.321 DEBUG (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0xC201:1:0x0402]: cluster_handler[temperature] attribute_updated - cluster[Temperature Measurement] attr[measured_value] value[2078]
2024-04-20 08:44:10.753 DEBUG (MainThread) [zigpy.zcl] [0xC201:1:0x0402] Decoded ZCL frame: TemperatureMeasurement:Report_Attributes(attribute_reports=[Attribute(attrid=0x0000, value=TypeValue(type=int16s, value=2077))])
2024-04-20 08:44:10.758 DEBUG (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0xC201:1:0x0402]: cluster_handler[temperature] attribute_updated - cluster[Temperature Measurement] attr[measured_value] value[2077]
2024-04-20 08:44:19.026 DEBUG (MainThread) [zigpy.zcl] [0xC201:1:0x0402] Decoded ZCL frame: TemperatureMeasurement:Report_Attributes(attribute_reports=[Attribute(attrid=0x0000, value=TypeValue(type=int16s, value=2079))])
2024-04-20 08:44:19.031 DEBUG (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0xC201:1:0x0402]: cluster_handler[temperature] attribute_updated - cluster[Temperature Measurement] attr[measured_value] value[2079]
2024-04-20 08:44:25.953 DEBUG (MainThread) [zigpy.zcl] [0xC201:1:0x0402] Decoded ZCL frame: TemperatureMeasurement:Report_Attributes(attribute_reports=[Attribute(attrid=0x0000, value=TypeValue(type=int16s, value=2081))])
2024-04-20 08:44:25.960 DEBUG (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0xC201:1:0x0402]: cluster_handler[temperature] attribute_updated - cluster[Temperature Measurement] attr[measured_value] value[2081]
2024-04-20 08:44:33.039 DEBUG (MainThread) [zigpy.zcl] [0xC201:1:0x0402] Decoded ZCL frame: TemperatureMeasurement:Report_Attributes(attribute_reports=[Attribute(attrid=0x0000, value=TypeValue(type=int16s, value=2079))])
2024-04-20 08:44:33.044 DEBUG (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0xC201:1:0x0402]: cluster_handler[temperature] attribute_updated - cluster[Temperature Measurement] attr[measured_value] value[2079]
!! lastReportDate and lastReportChangedDate are stil 2024-04-20 05:43:23.681579+00:00. No change.
If I open Developer tools and then States and choose any sensor, only last update and last changed time is shown.
kuva
If I paste this code in Templates in Developer page. Last_report and last_update get different values but not is template sensor.
{{lastReportDate}}
The template sensor is only triggering on change.
But why last_reported will not change when sensor sends measurements if change is less than 0.1 C?
state.last_reported Time the state was written to the state machine in UTC time. This timestamp is updated regardless of any change to the state or a state attribute
State objects - Home Assistant
{{lastReportDate}}
{{lastChangedDate}}
{{now()}}
If I add now() to the template sensor last_reported is updated every minute. last_reported is about 30 seconds behind now() and last_report updates even I remove the battery from the sensor.
Is that a Tuya integration reporting in? Try it with a “basic” sensor that’s not going through any third-party integration.
It’s ZHA with a SkyConnect Zigbee USB adapter. The Zigbee 3.0 temperature/humidity sensor is manufactured by Tuya.
I have a Soil humidity/moisture sensor. last-updated shows “last week” and thats when I restarted Home Assistant. To know if the sensor is working I have to go Settings → Devices & Services → Zigbee Home Automation → Devices → the sensor → Zigbee info and check the Last seen time.
kuva
I solved this by buying a Tuya Zigbee gateway. With this gateway and Smart Life app I get info and alerts if the sensors stays offline over 8 ours.
