Hello!
I have a device that sends auto discovery messages to a MQTT broker. I want it to create an entity that can be used by the energy dashboard. The configuration looks like the following:
"avty_t":"EMR_C69134/device/status",
"dev":{
"ids":["Device0"],
"name":"Device0",
"via_device":"EMR_C69134"
"ic":"mdi:lightning-bolt",
"name":"Device0/Energy/Active/Positive",
"pl_avail":"connected",
"pl_not_avail":"disconnected",
"stat_t":"EMR_C69134/Device0/Energy/Active/Positive/value",
"uniq_id":"48015",
"dev_cla":"energy",
"frc_upd":true,
"last_reset":"1970-01-01T00:00:00+00:00",
"stat_cla":"measurement",
"unit_of_meas":"kWh"
The entity is created and the value is correctly retrieved. So far so good! But when I try to add it to the energy dashboard, I get the following error:
The following entities have state class ‘measurement’ but ‘last_reset’ is missing
The energy is not working because of this. But 'last_reset* is clearly there if you look at the config. Any ideas why this might be happening?
