I have a smart plug that I am monitoring power values for a device. How can I create a sensor to display “Last Run”? So basically, if the current or power value increased above a specific value and then dropped below a specific value for a predetermined amount of time, set a timestamp so I can display this in the frontend. Below is my typical sensor for these type of devices, which shows how long the device has been running. {Disclaimer: the “smart_plug_2_info” run time code is not mine, I just tailored it to my application, and I don’t use the “on after” portion}
sensors:
smart_plug_2_status:
friendly_name: 'Smart Plug 2 Status'
value_template: >
{% if states.sensor.awp04l_plug_2_power.state | float > 100.0 %}
{{ "Running" }}
{% elif states.sensor.awp04l_plug_2_power.state | float > 5.0 %}
{{ "On" }}
{% elif states.sensor.awp04l_plug_2_power.state | float < 4.9 %}
{{ "Off" }}
{% else %}
{{ "Unknown" }}
{% endif %}
smart_plug_2_info:
friendly_name: 'Smart Plug 2 Info'
entity_id: sensor.time
value_template: >
{%- macro as_formatted_elapsed_time(now, other_date_time) %}
{% set duration = as_timestamp(now) - as_timestamp(other_date_time) %}
{% set seconds = (duration % 60) | int %}
{% set minutes = ((duration / 60) | int) % 60 %}
{% set hours = (duration / 3600) | int %}
{{ [hours, "hours", minutes, "minutes"] | join(' ') }}
{%- endmacro %}
{% if states.input_text.smart_plug_2_enriched_status.state == "Running" %}
Run time: {{ as_formatted_elapsed_time(now(), states.input_text.smart_plug_2_enriched_status.last_changed)}}
{% elif states.input_text.smart_plug_2_enriched_status.state == "On_After_Running" %}
Smart Plug 2 off for: {{ as_formatted_elapsed_time(now(), states.input_text.smart_plug_2_enriched_status.last_changed)}}
{% elif states.input_text.smart_plug_2_enriched_status.state == "On_After_Off" %}
{{ "Smart Plug 2 ready to start" }}
{% else %}
{% endif %}
