My temperature sensors doesn’t seem to get latest update, e.g “states.sensor.stua_temperature.last_updated” now shows “2018-11-13 13:25:12.249325+00:00”. But in the Telldus interface it was updated a minute ago:
It isn’t shown in /dev-state, probably since it isn’t an attribute. I can see it in /dev-template using {{ states.sensor.stua_temperature.last_updated }} though.
last_updated will show you the last time a object was updated. Unless you restart/shutdown&bootup. When you restart/shutdown&bootup, all objects in home assistant will have the last_updated time changed to when the system was started (because the system updated the states on startup). Same with last_changed.
Yes, and it will. I think you are not realizing that the timestamp for last updated isn’t in local time. It’s in UTC. That’s what the +00.00 is showing you.
not sure where you are getting 14:37. I don’t recognize that interface so I’m guessing it’s the devices interface. You need to look at the time in home assistant. It’s last updated is based on when home assistant gets an update from the device. The device may have updated in it’s own software but that doesn’t mean it published a change outbound.
If you have MQTT sensor: if measured data is same as previous value, then HA will not update, if you want to update every x minute, you must add force_update option.
