Lastchanged template sensor does not change
I have two identical sensors devices.
For both I have created a template sensor showing the shortest time since update of anyone of the sensors in the device.
Here are the template sensors:
    sensors:
      xiaomiaqara_1_lastchanged:
        value_template: >
          {% set values = [
            states.sensor.xiaomiaqara_1_temperature.last_changed,
            states.sensor.xiaomiaqara_1_humidity.last_changed,
            states.sensor.xiaomiaqara_1_pressure.last_changed,
            states.sensor.xiaomiaqara_1_linkquality.last_changed,
            states.sensor.xiaomiaqara_1_voltage.last_changed,
            states.sensor.xiaomiaqara_1_battery.last_changed, ] %}
          {{ values | max }}
        device_class: timestamp
    sensors:
      xiaomiaqara_2_lastchanged:
        value_template: >
          {% set values = [
            states.sensor.xiaomiaqara_2_temperature.last_changed,
            states.sensor.xiaomiaqara_2_humidity.last_changed,
            states.sensor.xiaomiaqara_2_pressure.last_changed,
            states.sensor.xiaomiaqara_2_linkquality.last_changed,
            states.sensor.xiaomiaqara_2_voltage.last_changed,
            states.sensor.xiaomiaqara_2_battery.last_changed, ] %}
          {{ values | max }}
And that’s the result: Left sensor works well, the right one doesn’t
remember reading somewhere in here
if you add the
entity_id: sensor.time
to the template
    sensors:
        entity_id: sensor.time    #<<<<< here
        value_template: >
          {% set values = [
          {{ values | max }}
should help it kick off sensor
can you share your lovelace bit thanks
The better option would be to list the entities actually used in the template, that way Home Assistant monitors them for change rather than just updating every minute as will happen with the time sensor.
    sensors:
        entity_id:
          - sensor.xiaomiaqara_1_temperature
          - sensor.xiaomiaqara_1_humidity
          - sensor.xiaomiaqara_1_pressure
          - sensor.xiaomiaqara_1_linkquality
          - sensor.xiaomiaqara_1_voltage
          - sensor.xiaomiaqara_1_battery
        value_template: >
          {% set values = [
          {{ values | max }}
Thanks for your replys, but unfortunately both did not help.
cards:
  - content: >-
      ## Terrasse
      Xiaomi Aqara 1
      [Beschreibung](https://xiaomi-mi.de/mi-smart-home/aqara-temperature-and-humidity-sensor/)
    style: |
      ha-card {
        background: rgba(0,250,0,0.5);
        border-radius: 15px;
        height: 80px
    type: markdown
  - cards:
      - content: >-
          <img
          src="https://raw.githubusercontent.com/hajo62/HomeAutomation/master/images4git/xiaomi-aquara-sensor.jpg"
          width="100">
        style: |
          ha-card {
            height: 140px
        type: markdown
      - cards:
          - entity: sensor.xiaomiaqara_1_temperature
            scale: 26px
            type: 'custom:bignumber-card'
          - entity: sensor.xiaomiaqara_1_humidity
            scale: 26px
        type: vertical-stack
    type: horizontal-stack
  - entities:
      - entity: sensor.xiaomiaqara_1_lastchanged
      - entity: sensor.xiaomiaqara_1_pressure
        secondary_info: last-changed
      - type: divider
      - entity: sensor.xiaomiaqara_1_linkquality
      - entity: sensor.xiaomiaqara_1_voltage
    type: entities
show_header_toggle: false
Solved. I hade a duplicate sensor definition - cut&paste mistake.
