Anyone else have a problem with loading the newest version of home assistant and some sensors?
some of my sensors did not pick back up in the latest update in version 0.91.3
I am having some minor issues with TPlink that could be the issue on the update (errors below):
Error setting up platform tplink
11:33 AM components/device_tracker/init.py (ERROR)
Router didn’t respond with JSON. Check if credentials are correct.
11:33 AM components/tplink/device_tracker.py (ERROR)
Couldn’t fetch auth tokens! Response was: <Script language=JavaScript> var errorCode = 501; var errorNote = “<p>File not found</p>”; var homeSite = “http://192.168.0.1”; </script> <HTML> <HEAD> <TITLE>Error</TITLE> <META http-equiv=“Content-Type” content=“text/html; charset=iso-8859-1”> </HEAD> <BODY> <DIV style=“padding:0px 30px;”> <script type=“text/javascript”> function goHome() { window.parent.location.href = homeSite; } document.write("<h1>" + errorCode +"</h1><hr>"); document.write(errorNote); </script> <p><a href="#" onClick=“goHome()”>Go Home</a></p> </DIV> </BODY> </HTML>
AP didn’t respond with JSON. Check if credentials are correct
