I can confirm 0.84.5 with Harmony updated to .206 is working fine… Thanks Devs
Confirmed working with my docker container on my end as well. Thank you for taking care of this. Countdown until Logitech patches the next “security concern” starts now.
I can keep my hubs now. Time to test!
I’ve updated to 0.84.5, and for the most part, the harmony update works, except it can’t read the current activity. I It’s flooding me log with this error:
Update for remote.lounge_room fails
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity.py", line 221, in async_update_ha_state
await self.async_device_update()
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity.py", line 347, in async_device_update
await self.async_update()
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/remote/harmony.py", line 205, in async_update
activity_id = await self._client.get_current_activity()
File "/srv/homeassistant/lib/python3.5/site-packages/pyharmony/client.py", line 234, in get_current_activity
'vnd.logitech.harmony/vnd.logitech.harmony.engine'
File "/srv/homeassistant/lib/python3.5/site-packages/pyharmony/client.py", line 184, in _send_request
return await self._wait_response(msgid)
File "/srv/homeassistant/lib/python3.5/site-packages/pyharmony/client.py", line 190, in _wait_response
response_json = await self._websocket.recv()
File "/srv/homeassistant/lib/python3.5/site-packages/websockets/protocol.py", line 398, in recv
"cannot call recv() while another coroutine "
RuntimeError: cannot call recv() while another coroutine is already waiting for the next message
I’m not experiencing this on 84.5. My hub is at 206.
I’ve even got a template sensor that’s correctly updating with state changes.
harmony_status:
value_template: >
{% if is_state("remote.livingroom", 'on') %}
{{ states.remote.livingroom.attributes.current_activity }}
{% else %}
PowerOff
{% endif %}
friendly_name: Harmony Status
A reboot of HA fixed it. Not sure what happened.
Plus it’s good to see Logitech coming out with a developers program on the XMPP API.
I’m getting the same error
It was working for a few days but since yesterday it stopped.
Nothing changed in my configuration
I’ve restarted HA also, but error is still there
@deluxestyle, cjsimmons,
An update to Harmony component is forthcoming. The fix to get harmony working again was “quick&dirty”
If you want, you can currently deploy the fix as a custom component:
- In your HASS config folder create folder custom_components/remote (if not there)
- Change to that folder
- Download updated harmony component:
curl https://raw.githubusercontent.com/ehendrix23/home-assistant/Use_aioharmony_for_harmony/homeassistant/components/remote/harmony.py -o harmony.py
Or you can wait for next release as this should be able to make it into 0.85
@ehendrix Thanks for your work on this. For now it’s working for me, so I’ll just leave it and wait for the update in 0.85.
thank you
I will try it with the updated harmony.py
still the same issue even with the updated harmony.py file
@deluxestyle, if you haven’t done so already, update to 0.85. It includes using new aioharmony component for harmony.
thanks. I updated yesterday. seems to work now
HA is listing all of my hubs as unavailable. If I restart HA, they work fine but return to unavailable after awhile. I’m running Hassio v85.1 and my harmony hubs are on v4.15.206. Anyone else having this issue?
What is a while? 2 hour, 2 day??
I updated yesterday, will let you know
I’m using 1 HUB but i’m facing the exact same problem. A restart of HA will fix the problem but after a while (couple of hours i guess) the problem is back.
Have you put in an IP address in your config?
Yes. And the HUB gets a static IP from my DHCP based on its Mac address. Never had this problem before the whole “Harmony API gate”…
Well, I did an upgrade yesterday from 84.2 version, using API to 85.1 , still available now after about 10 hours
