Hey all,
I just cloned and built the latest master (0.34-4) and I am unable to start hass anymore. It seems to attempt to upgrade my configuration then falls over. Here is the output from the console:
Config directory: /home/hass/.homeassistant 16-12-11 01:44:28 INFO (Thread-2) [homeassistant.config] Upgrading config directory from 0.34.2 to 0.34.4 Traceback (most recent call last): File "/srv/hatdb/bin/hass", line 11, in <module> load_entry_point('homeassistant', 'console_scripts', 'hass')() File "/srv/hatdb/home-assistant/homeassistant/__main__.py", line 380, in main exit_code = setup_and_run_hass(config_dir, args) File "/srv/hatdb/home-assistant/homeassistant/__main__.py", line 293, in setup_and_run_hass log_rotate_days=args.log_rotate_days) File "/srv/hatdb/home-assistant/homeassistant/bootstrap.py", line 462, in from_config_file hass.loop.run_until_complete(future) File "/usr/lib/python3.5/asyncio/base_events.py", line 387, in run_until_complete return future.result() File "/usr/lib/python3.5/asyncio/futures.py", line 274, in result raise self._exception File "/srv/hatdb/home-assistant/homeassistant/bootstrap.py", line 453, in _async_init_from_config_file config_path, hass, verbose, skip_pip, log_rotate_days) File "/srv/hatdb/home-assistant/homeassistant/bootstrap.py", line 495, in async_from_config_file config_dict, hass, enable_log=False, skip_pip=skip_pip) File "/srv/hatdb/home-assistant/homeassistant/bootstrap.py", line 384, in async_from_config_dict None, conf_util.process_ha_config_upgrade, hass) File "/usr/lib/python3.5/asyncio/futures.py", line 361, in __iter__ yield self # This tells Task to wait for completion. File "/usr/lib/python3.5/asyncio/tasks.py", line 296, in _wakeup future.result() File "/usr/lib/python3.5/asyncio/futures.py", line 274, in result raise self._exception File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run result = self.fn(*self.args, **self.kwargs) File "/srv/hatdb/home-assistant/homeassistant/config.py", line 252, in process_ha_config_upgrade shutil.rmtree(lib_path) File "/srv/hatdb/lib/python3.5/shutil.py", line 474, in rmtree _rmtree_safe_fd(fd, path, onerror) File "/srv/hatdb/lib/python3.5/shutil.py", line 432, in _rmtree_safe_fd onerror(os.unlink, fullname, sys.exc_info()) File "/srv/hatdb/lib/python3.5/shutil.py", line 430, in _rmtree_safe_fd os.unlink(name, dir_fd=topfd) PermissionError: [Errno 13] Permission denied: 'tellcore'
I don’t use tellcore so not sure where they came from, however I do have tellduslive in my config. I was using 0.34-2 recently which worked fine.
Let me know if you need any further info!
