Latest Reolink E1 Zoom can't be used in HomeAssistant
I’ve just received the latest Reolink E1 Zoom camera with Person/Pet detection (hardware version IPC_566SD664M5MP).
The previous model have a web interface and can be easily added to Home Assistant.
But with this new hardware version, it drops the web interface and so it can’t be added to HomeAssistant anymore.
So be careful if you plan to buy Reolink cameras, you might not be able to use it with Home Assistant.
I finally made it work. I must have had some networking issues when I tried to open the Web UI of the 1st camera because, it worked fine with https on the 2nd one…
Also, I learnt that the desktop app has more settings available than the mobile app. So if you have any issues, you can use it to make sure that HTTPS is enabled.
