bkr1969
(Brian)
July 6, 2022, 2:22pm
1
Got a notification this morning of a Terminal/SSH update. When I try to install it spins for a minute then I get an error:
“Failed to call service update/install. Error updating Terminal & SSH: Pulled image homeassistant/aarch64-addon-ssh:9.5.0 failed on content-trust verification!”
Any thoughts?
CO_4X4
(Colorado Four Wheeler)
July 6, 2022, 2:31pm
2
Same problem for me. HA Supervisor popped up at the same time and upgraded without issue and I’m on the latest release of HA.
I had this too. (HA supervised on Debian Bullseye)
sudo apt-get update
sudo apt-get upgrade
before the update solved it.
bkr1969
(Brian)
July 6, 2022, 3:17pm
5
Exactly where are you typing this? Doesn’t work in the terminal window on HA.
I did SSH in to the HA machine with Putty.
bkr1969
(Brian)
July 6, 2022, 4:11pm
7
OK. Well that won’t work for me here at work. Any other ideas?
I think the underlying problem is that this shouldn’t be an issue.
Depends on how you run HA. If it is a Supervised install, like mine, you are self responsible for keeping the OS (Debian) up to date…
bkr1969
(Brian)
July 6, 2022, 4:31pm
9
I’m on HA Blue (Odroid).
Define “keeping the OS up to date.” I’m not sure this applies to me.
No, it does not then. As you most likely are running HA OS.
bkr1969
(Brian)
July 6, 2022, 4:54pm
11
This confirms my suspicion that there’s something going on with that OS that causes trust verification to fail.
