updated to 4.16 and now nothing appdaemon works. I have ha on a raspberry pi 4. im at a loss because it was fine until the update to 4.16.
Changes to your operating system shouldn’t impact HA or AppDaemon.
What problem are you having?
appdaemon webui and dashboards just show unable to connect.
i get this
Unable to connect
Firefox can’t establish a connection to the server at homeassistant.local:5050.
Check the logs for the add-on
Looking at discord it broke zigbee2mqtt too.
Personally I see substantially increased CPU use with 4.16.
I’m rolling back now.
ha os update --version=4.15
where did you find that in the discord?
also how would i go about reverting back to a older version?
Here: https://discord.gg/avBrgE7y
I included the home assistant command line command to roll back in my post.
However rolling back did not solve my issue. It turned out to be an addon I usually leave off but which was set to “Start on boot”. Upgrading again…
apparently appdaemon didnt like the fact that i edited the latitude and longitude and timezone in the appdaemon yaml file. restore to what was in there and its working now. but ive restarted and rebooted ha and ad multiple times since i did that. but for some reason it was after the last update it started to have an issue with it apparently.
