Latest updates have broken my automations
Hello!
I have had several automations for Samsung smartthings and Aqara buttons, that were working fine before the last two updates, but are no longer working and exhibiting weird behavior. I was following this method, to send an MQTT packet, which I used in Node Red:
https://community.home-assistant.io/t/my-howto-smartthings-zigbee-button/114482
Since the last two Hassio updates, the automations no longer publish an MQTT packet upon clicking the button, but it seems to make all my other MQTT devices send a packet and briefly go offline when I click the button.
Here’s my code:
automation:
  - id: samsungdeskbutton
    alias: samsung desk button
      - event_data:
          command: button_single
          device_ieee: 28:6d:97:00:01:05:37:5b
        event_type: zha_event
        platform: event
      service: mqtt.publish
      data_template:
        payload: >
          {{trigger.event.data['command']}}
        topic: >
          home/buttons/desk
I might be able to get the buttons working some other way without MQTT, but I’m baffled as to why this isn’t working now and I’d like to figure out why.
Thanks!
By last two updates do you mean 0.115 and 0.116, or do you mean 0.116.1 and 0.116.2.
Have you read the breaking changes for the releases?
Where is your log?
Thanks for the reply - it was the 0.115 release that caused issues. I don’t see any breaking changes that would affect me, the changes on automations do not appear to make a difference?
That said, I think I’ve found a simpler solution to getting these buttons to work in Node Red without automations, so I think that is the route I will go.
