[{“id”:“c5a928a.ecadad8”,“type”:“tab”,“label”:“Winthing Conversion Bridge”,“disabled”:false,“info”:“”},{“id”:“564f71ff.19fdf”,“type”:“mqtt out”,“z”:“c5a928a.ecadad8”,“name”:“Media PC Run Apps”,“topic”:“winthingmediapc/system/commands/open”,“qos”:“”,“retain”:“”,“broker”:“54e19abc.c77134”,“x”:788.0613784790039,“y”:207.54880905151367,“wires”:,“inputLabels”:[“["C:\\Steam.exe"]”]},{“id”:“de6c0612.177988”,“type”:“mqtt in”,“z”:“c5a928a.ecadad8”,“name”:“Media PC”,“topic”:“mediapc”,“qos”:“2”,“broker”:“54e19abc.c77134”,“x”:65,“y”:252.71788024902344,“wires”:[[“6d58845f.3cce2c”,“c2036a96.0f28d8”]],“outputLabels”:[“msg.payload”]},{“id”:“6d58845f.3cce2c”,“type”:“switch”,“z”:“c5a928a.ecadad8”,“name”:“”,“property”:“payload”,“propertyType”:“msg”,“rules”:[{“t”:“eq”,“v”:“startkodi”,“vt”:“str”},{“t”:“eq”,“v”:“stopkodi”,“vt”:“str”},{“t”:“eq”,“v”:“restart”,“vt”:“str”},{“t”:“eq”,“v”:“startteamviewer”,“vt”:“str”},{“t”:“eq”,“v”:“killteamviewer”,“vt”:“str”},{“t”:“eq”,“v”:“killsteam”,“vt”:“str”},{“t”:“eq”,“v”:“startsteam”,“vt”:“str”},{“t”:“eq”,“v”:“killorigin”,“vt”:“str”},{“t”:“eq”,“v”:“pcmr”,“vt”:“str”},{“t”:“eq”,“v”:“sleep”,“vt”:“str”}],“checkall”:“true”,“repair”:false,“outputs”:10,“x”:218.06148529052734,“y”:252.54875946044922,“wires”:[[“85d6d93.fad7b28”],[“d7480417.3a9e48”],[“f0485437.6186f8”],[“f4788483.1c8f88”],[“dcf7ad0e.9dc8d”],[“bcf6e24.8a4562”],[“dd542796.b6aca8”],[“3114cc74.983b24”],[“5d450d7a.b62474”],[“2394e232.fcd8ae”]]},{“id”:“85d6d93.fad7b28”,“type”:“change”,“z”:“c5a928a.ecadad8”,“name”:“Start Kodi”,“rules”:[{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“["C:\\Program Files (x86)\\Kodi\\kodi.exe"]”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:404.52369689941406,“y”:75.47617769241333,“wires”:[[“564f71ff.19fdf”,“c2036a96.0f28d8”]]},{“id”:“cedbc81a.63e8d8”,“type”:“comment”,“z”:“c5a928a.ecadad8”,“name”:“Topic”,“info”:“Set Topic\n\nSet Payload in HA with script\n\nPayload can be anything, it’s coverted by the switch”,“x”:83.85954666137695,“y”:24.377704620361328,“wires”:},{“id”:“a66d011a.18152”,“type”:“comment”,“z”:“c5a928a.ecadad8”,“name”:“Switch”,“info”:“If payload contains "X" goto swtich "X"”,“x”:218.4619026184082,“y”:25.960501670837402,“wires”:},{“id”:“12e57b6c.be4d25”,“type”:“comment”,“z”:“c5a928a.ecadad8”,“name”:“Msg Payload”,“info”:“Set Payload to link to .exe or other command\n\nDouble escaped ie "C:\\test\\test.exe"”,“x”:404.1761131286621,“y”:24.5319242477417,“wires”:},{“id”:“d9d2b732.293338”,“type”:“comment”,“z”:“c5a928a.ecadad8”,“name”:“Send To Host”,“info”:“Sends message to host PC \n\nEnsure "winthing" Server is running!\n\nTopic is winthing/system/commands/open”,“x”:746.5570831298828,“y”:24.293835639953613,“wires”:},{“id”:“d7480417.3a9e48”,“type”:“change”,“z”:“c5a928a.ecadad8”,“name”:“Close Kodi”,“rules”:[{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“["C:\\Users\\Media\\Desktop\\Start-up\\Control\\closekodi.exe"]”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:410.0236587524414,“y”:120.00947761535645,“wires”:[[“564f71ff.19fdf”]]},{“id”:“3abbcb12.6713b4”,“type”:“mqtt out”,“z”:“c5a928a.ecadad8”,“name”:“Restart”,“topic”:“winthingmediapc/system/commands/reboot”,“qos”:“”,“retain”:“”,“broker”:“54e19abc.c77134”,“x”:751.6903076171875,“y”:101.67611885070801,“wires”:,“inputLabels”:[“["C:\\Steam.exe"]”]},{“id”:“f0485437.6186f8”,“type”:“change”,“z”:“c5a928a.ecadad8”,“name”:“Restart”,“rules”:[{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:408.35691833496094,“y”:166.67610359191895,“wires”:[[“3abbcb12.6713b4”]]},{“id”:“f4788483.1c8f88”,“type”:“change”,“z”:“c5a928a.ecadad8”,“name”:“Start TeamViewer”,“rules”:[{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“["C:\\Users\\Media\\Desktop\\Start-up\\Control\\startteam.exe"]”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:435.0236396789551,“y”:210.0094699859619,“wires”:[[“564f71ff.19fdf”]]},{“id”:“dcf7ad0e.9dc8d”,“type”:“change”,“z”:“c5a928a.ecadad8”,“name”:“Stop TeamViewer”,“rules”:[{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“["C:\\Users\\Media\\Desktop\\Start-up\\Control\\stopteam.exe"]”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:433.35699462890625,“y”:255.00946044921875,“wires”:[[“564f71ff.19fdf”]]},{“id”:“bcf6e24.8a4562”,“type”:“change”,“z”:“c5a928a.ecadad8”,“name”:“Stop Steam”,“rules”:[{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“["C:\\Users\\Media\\Desktop\\Start-up\\Control\\stopsteam.exe"]”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:418.35699462890625,“y”:298.3428039550781,“wires”:[[“564f71ff.19fdf”]]},{“id”:“dd542796.b6aca8”,“type”:“change”,“z”:“c5a928a.ecadad8”,“name”:“Start Steam”,“rules”:[{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“["C:\\Users\\Media\\Desktop\\Start-up\\Control\\startsteam.exe"]”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:420.0236511230469,“y”:340.00944995880127,“wires”:[[“564f71ff.19fdf”]]},{“id”:“3114cc74.983b24”,“type”:“change”,“z”:“c5a928a.ecadad8”,“name”:“Stop Origin”,“rules”:[{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“["C:\\Users\\Media\\Desktop\\Start-up\\Control\\stoporigin.exe"]”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:420.0236511230469,“y”:381.67611598968506,“wires”:[[“564f71ff.19fdf”]]},{“id”:“5d450d7a.b62474”,“type”:“change”,“z”:“c5a928a.ecadad8”,“name”:“Start Game Mode PCMR”,“rules”:[{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“["C:\\Users\\Media\\Desktop\\Start-up\\Control\\gamemode.exe"]”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:458.35698318481445,“y”:416.67613530158997,“wires”:[[“564f71ff.19fdf”]]},{“id”:“8ccbc82f.3875c8”,“type”:“mqtt out”,“z”:“c5a928a.ecadad8”,“name”:“Hibernate”,“topic”:“winthingmediapc/system/commands/hibernate”,“qos”:“”,“retain”:“”,“broker”:“54e19abc.c77134”,“x”:760.0236015319824,“y”:151.6761302947998,“wires”:,“inputLabels”:[“["C:\\Steam.exe"]”]},{“id”:“2394e232.fcd8ae”,“type”:“change”,“z”:“c5a928a.ecadad8”,“name”:“sleep”,“rules”:[{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:401.69033432006836,“y”:455.0094575881958,“wires”:[[“8ccbc82f.3875c8”]]},{“id”:“c2036a96.0f28d8”,“type”:“debug”,“z”:“c5a928a.ecadad8”,“name”:“”,“active”:true,“tosidebar”:true,“console”:true,“tostatus”:true,“complete”:“payload”,“x”:240.5972023010254,“y”:505.8197202682495,“wires”:},{“id”:“54e19abc.c77134”,“type”:“mqtt-broker”,“z”:“”,“name”:“HA IO”,“broker”:“192.168.1.69”,“port”:“1883”,“clientid”:“”,“usetls”:false,“compatmode”:false,“keepalive”:“60”,“cleansession”:true,“birthTopic”:“”,“birthQos”:“0”,“birthPayload”:“”,“closeTopic”:“”,“closeQos”:“0”,“closePayload”:“”,“willTopic”:“”,“willQos”:“0”,“willPayload”:“”}]
