Launch command line when pushing button
I would like to create a virtual buttun with the following action :
=> type a command line in my terminal & SSH addon
Any idea of how to do it?
Many thks!
make an Shell Command Shell Command - Home Assistant
then make an action that runs the shell command.
Many thks ! I have done. On question, how can I check that the command line is done properly?
for exemple, my cmd shell is a ping, but i do not see it in the terminal, how can I check ?
cli commands have an exit code. 0 is all OK. anything else is an error.
perhaps you want to run it as a sensor.
the output is in homeassistant.log
