I was wondering if it’s possible to have a button in the panel menu (where map / logbook etc. are) that when clicked launches a webpage in a new window? The Panel iFrame only allows you to open it within homeassistant which isn’t what I want. Is there any solution I’m missing?
Not aware of a means to do this in the side panel, however, the weblink component allows you to put a link in the front end.
https://home-assistant.io/components/weblink/
You can see an example of where I use them below
Here you go:
Did you solve somehow?
I was also looking for a way to do this, but came up empty. After searching for a solution and figuring out how to accomplish this goal, I made a step-by-step post:
Regards,
Chris
