I would like the ability to use an automation to do two things:
- initiate a widget on my android phone
- open a shortcut on my android phone
basically I would like the podcast addict app to check for new podcasts and then launch to the latest episodes areas of the app
podcast addict can create a widget to refresh the episode feed and has a shortcut that can launch directly to the ‘Recent episodes’ part of the app
See below for more context:
(top center - podcast addict normal app icon, bottom left - podcast addict shortcut to open the latest episodes / ‘Recent episodes’ view in the app, bottom right - podcast addict widget to refresh the feed of episodes)
Sadly it doesn’t seem like there is a different name under version when looking at the details of the shortcut.
I believe the packname is: com.bambuna.podcastaddict
I know it’s possible using the companion app to launch an app normally using code like what is shown below but I am uncertain about starting a widget and / or a specific app shortcut. Maybe somehow using the intent code example from: Notification Commands | Home Assistant Companion Docs ?
Thank you in advance for the help.
automation:
- alias: Launch app
- service: notify.mobile_app_<your_device_id_here>
message: "command_launch_app"
package_name: "com.twitter.android"
