Lawnmower custom integration for SunSeeker robotic-mowers
Just want to share my integration.
My mower is a Adano RMA6 from Denmark. Its a rebranded mower sold in many countries with a different name.
Other Brands of the SunSeeker mower
Seems to be the same mower as SunSeeker RMAxxxM and Texas RMX800
Found this while searching for an addition to the garden tools collection.
It’s the one from Harald Skrald (sorry non-Danes, it’s a nick name for a local shop), right?
Are you generally happy with it price/quality taken into consideration?
Yes, It’s the one from HN and It’s working very well for me. No problems at all. But with all robotic mower It’s all about making the right environment so it does not get stuck
These sunseeker mowers are also sold by the names of Brucke RMxxx (Tokmanni, Finland) Scheppach (Germany) Orbex. Meec tools (Jula, Sweden). Also Sunseekers new orion X7 model looks cool. Its boundry wireless.
Hi!
I can happy to find your integration. I can confirm that its working perfectly with a Practixx PX-RRM-600Wi badicly its a Scheppach lawn mower.
I was trying to find out what about the gps coordinates. Is it chaning when the machine is working ? Because mine was not chaning at all,its allways show the same number. It can be handy if u can track the device in the garden :slight_smile:
Thanks again for the great job
Thanks for the feedback :smiley:
Unfortunately, the GPS coordinates are only for anti-theft.
It does not update as the mower is working
I just noticed today the the cutting the border command is not working. its working in its own app. Any idea where i shoukd look for the problem ?
Fixed in the new release 1.0.9
Thank you for sharing, this is grate!!! Bought the first one last fall and a second larger model some weeks later, managed to get the token and some commands before the season ended. Now i does not have to continue digging :grinning:
Does someone have a cool card for this mowers?
Thank you so much of this intgration!
I can confirm that it is working with:
Brücke RM 501
RMA501M20V
Brucke
Grouw Ultra 2000 m²
Thanks for the integration, works with Orbex!
Thanks for this integration! Works even better than the app! For some reason the app won’t let me start my meec sunseeker mower if it’s not in the dock first.
Anyway, I have a couple of steep areas that my mower tips it’s nose up and gives the error ‘updown’. Most of the times the nose slowly tips down again. I have an automation in HA that restarts it when this happens. Most of the times this works, but sometimes it’s stuck with the nose up. It’s there anyway to send a manual command to make it back up a little before trying again?
For some reason schedule thursday is missing.
In the end you do not really need and app account to use this integration. You can just connect to the (very badly secured) Broker directly and filter for the /device/{serial number/# topics.
Would be cool to have this possibility in the integration. That way you wouldn’t have any problem with oauth providers.
You just need to know the serialnumber of the device.
Some Infos for manual mqtt integration: GitHub - OlliKantola/Sunseeker_LawnMower_Control
Thank you very much for your work!
I have the Practixx PX-RRM-600Wi robotic lawn mower, which is similar to the Adano model. Everything is working perfectly.
Best regards!
I live in Denmark and I am planning to buy the Adano RM5 (from Harald Nyborg) or the Garden 500 (from Jem & Fix). They seem to be a new 2025 model made for up to 500 square meter gardens (and much cheaper than previous models). I haven’t found any review of them yet and manuals seem to be a couple of months old.
Do you expect they should work with this integration and, if yes, if they might have fewer options being a cheaper option?
Another question I had is if with this integration the commands are still sent to some cloud service and then to the robot or if everything will happen locally?
I would be worried to be locked out in case they decide to close down the cloud service if it works that way…
I bought the new sunseeker x7 model in the US. Is anyone working on an integration for that one? I can load this integration and sign in, but it doesnt find any entities or devices.
Thanks for that!
It works with STALCO RPM1300US (Polish brand of these robots).
I’ve chosen Texas in config and it has got recognized. Works like charm, way better than with the default app.
I’ve made one small modification though - changed URLs to httpS, just to make it a bit safer. I’d suggest to add that in next version.
Cheers
Guess this would be usefull to the Grouw Smart Vision 600 too (Without boundry cable) (also available in Denmark, Føtex/Bilka) - The mower is compatible with the Sunseeker app so I guess it should be compatible too…
