LAYOUT-CARD 1.3.1: Can'nt use - all custom cards has bad performance
Does anyone know a workaround for this problem?
I’m not sure whether it is the ovelace-layout-card plugin on the frontend or whether it is a general problem with the home assistant frontend
Each time I reload, if I use the LAYOUT-CARD (Version 1.3.1), the constructor and the settings of each custom card are called several times.
Without LAYOUT-CARD only once
Depending on how well the custom cards have been programmed, the loading process is very slow and uses a lot of memory.
see: LAYOUT-CARD 1.3.1: Can'nt use - all custom cards has bad performance · Issue #99 · thomasloven/lovelace-layout-card · GitHub
Home Assistant 0.118.0b3
Frontend-Version: 20201111.1 - latest
Version 0.118.0b3
Installation Type Home Assistant Core
Development false
Supervisor false
Docker false
Virtual Environment true
Python Version 3.8.6
Operating System Family Linux
Operating System Version 5.8.0-29-generic
CPU Architecture x86_64
Timezone Europe/Vaduz
