Layout-Card Grid rendering too wide
I would like to have multiple history cards on a dashboard using the full with available. I’ve installed layout-card frontend via hacs but it is not rendering properly in Grid mode with a history card. A scroll bar appears on the bottom and I to scroll to see the end of the graph/charts. It seems to be when I have a combination of a graph and binary sensors. Any ideas on how to get this to render properly?
If you put all your cards in a vertical stack you should be able to show the whole dashboard in panel mode.
Thanks, this idea works for what I wanted, however, bug still exists in layout-card.
