šŸ”¹ Layout-card - Take control of where your cards end up
Hmmm in this way how to have always the latest release after conversion?
Hey! Is there a way how to add other CSS grid properties? Right now I would like to use justify-items but itā€™s not available.
You can do pretty much anything you want with CSS using card-mod.
OK thanks, that can work too!
Maybe Iā€™m saying something crazy but could there be an implementation to parse key value to css?
I think it would help keeping our YAML file cleaner with less nested cards.
Oh, right. I forgot youā€™d need mod-card for layout-cardā€¦ Thatā€™s not a pretty solution.
Iā€™ll see what I can do.
@thomasloven I recently updated Home Assistant from 0.106.x to 0.114.1 and all of the custom components that got an update in the meantime. I posted about this yesterday in the Button Card topic as I first thought it was an issue with that component, but after some testing I found out that the issue is with Layout Card. Only on mobile (iOS), on desktop it works fine.
In a reply to my post from yesterday someone mentioned that something changed in Layout Card around the time of 0.112.0, so I went through the changelog and found out that it had to be release 14 of Layout Card. So, I reinstalled version 13 and got the following result (as expected):
That is what it looked like before the update. I updated back to release 16 and got this as a result (unexpected):
Just to make sure it actually changed in release 14, I installed both release 14 and 15 as well. This was kind of unexpected to what Iā€™ve read elsewhere as both release 14 as well as 15 worked perfectly fine.
I didnā€™t change any of my code btw. These are the cards shown in the screenshots on my Lovelace view:
        - type: custom:button-card
          template: heading
          name: {{ _t_i18n.lights.title }}
        - type: custom:mod-card
          style: |
            layout-card {
              padding: 0 10px;
          card:
            type: custom:layout-card
            layout: horizontal
            justify_content: start
            min_columns: 4
            cards:
              {% for light in room.lights %}
                template: room_light
                entity: {{ light.entity }}
                icon: {{ light.icon }}
                name: {{ light.name }}
                label: "{{ light.label | default(' ') }}"
                hold_action:
                  !include
                    - ../../popups/light.yaml
                    - entity: {{ light.entity }}
              {% endfor %}
                color_type: blank-card
                aspect_ratio: 1/1
                aspect_ratio: 1/1
                aspect_ratio: 1/1
This is the room_light Button Card template (not sure whether you would need this), but just in case here it is:
room_light:
  aspect_ratio: 1/1
  show_state: true
  deep_press: true
  tap_action:
    action: toggle
    haptic: light
  styles:
    card:
      - box-shadow: none
      - border-radius: 12px
    grid:
      - grid-template-areas: '"i i" "n n" "s brightness"'
      - grid-template-columns: 1fr
      - grid-template-rows: 1fr min-content min-content
    img_cell:
      - justify-content: start
      - align-items: start
    icon:
      - padding: 10px 10px
      - height: 50%
    name:
      - justify-self: start
      - padding: 5px 0 0 10px
      - font-weight: bold
      - font-size: 13px
    label:
      - padding: 0 10px 5px
      - font-size: 11px
    state:
      - font-size: 11px
    custom_fields:
      brightness:
        - position: absolute
        - top: 12px
        - right: 12px
        - width: 30%
  state:
    - value: 'unavailable'
      styles:
        card:
          - filter: opacity(50%)
In issues related to Layout Card release 14 on this forum and on your Github issues youā€™ve asked those people to update to release 16. All of those issues seem to have been fixed with that release. For me however it didnā€™t. For me the issue actually started to occur with release 16. All release before that seem to work fine. Do you know how to fix this?
Edit:
Something I posted in the other thread, but not hereā€¦ when I have 2, 3 or 4 columns, the buttons in column 2 and 3 are smaller. The buttons in column 1 and 4 however are the correct size (screenshot with 4 columns can be seen here in the other thread).
@thomasloven Hi, I was wondering: is it possible to create a layout card with a max height, where if the content exceeds the height you can continuously scroll to reveal the rest of the content? So basically like swiper card, but vertically with a set max height and continuous scrolling. Trying to build a new user interface where this would be the basis.
Iā€™m trying to see if I can use layout card for my light buttons, instead of combing horizontal-stacks withing vertical-stacks. Goal is to include auto-entities later on, to populate my UI with button cards automatically.
However I am having weird issues with sizing. I use the following code:
          - layout: horizontal
            type: 'custom:layout-card'
            column_num: 4
            column_width: 100%
            cards:
              - template: light
                entity: light.small_bulb
                type: 'custom:button-card'
              - MORE BUTTON CARDS 8x DOWN HERE
The layout itself works, but the sides are expanded somehow. Expanding the window a little bit solves this weird behaviour. Tried adding column_width: 100% and even made that smaller. Makes no difference. This is on Chrome/chromium browser and iOS (13.6). On iOS this is kinda bad, since I canā€™t resize windows (nor should I want to). One thing to note: I have this line of code at the base of my view (so I have a little padding all around).
      - layout: vertical
        column_width: 96%
I tried chaning that to 100% for now, but solves nothing. Also, this should just work (which shows when Iā€™m slightly expanding the window). This is only with the content inside the layout-card you see in the gif below.
Video of the glitch:
Is this a bug or a user error on my end?
Edit: I changed the code to this:
            column_width: 25%
            cards:
              - template: light
I figured, letā€™s just devide by 4 since I want 4 button cards, so put in 25% column width instead of column_num. This does work. Though I am curious if this is the correct way to use it. I want to avoid issues down the roadā€¦
Edit 2: After further testing this also gives a different issue, kinda like @thmry mentioned. 2 and 3 button cards are slightly smaller than 1 and 4. Also this ONLY occurs when setting the windows to smallest size (which is standard on mobile).
Edit 3: I can confirm this issue is not present with build 14. After that build something has changed with the paddings. I noticed back then (and now again) that I need to set my base layout card to 98% with build 14, while build 16 needs ~96% to achieve the same margins. Could be related to this: https://github.com/thomasloven/lovelace-layout-card/issues/93
I will revert back to horizontal and vertical stacks for now (cause I donā€™t want to use an older build of layout card). I hope this will be fixed soon.
Itā€™s the exact same issue I have. Itā€™s an issue in the latest release as youā€™ve already noticed. I reverted back to release 15 which works fine.
Yeah, Iā€™m worried that build 16 added features that build 15 will break because thatā€™s missing. Or that it never gets fully updated and newer builds with more features release. I donā€™t want to rewrite my entire view and revert everything to horizontal/vertical stacks down the road.
If this gets fixed or there is a workaround, Iā€™ll take the plunge and change everything to layout card :slight_smile:
Edit: @thmry I kinda used a workaround to use build 16 with the normal styling of build 15. I figured it was because of the styling in the .js file. I inspected the elements and changed some stuff and could indeed fix the paddings around the left and right card. I couldnā€™t fix the 2nd and 3rd buttons though. I noticed 16 had more styling codes, so I thought maybe that caused it.
So what I figured: why not use the styling codes of build 15 and remove the one of build 16ā€¦ The code of 15 works flawlessly in 16. Kinda hacky method, but it works. Running build 16 now without the glitched view. Maybe doing this is the same as running build 15, but at least I donā€™t see an update in HACS anymore lol.
I try to show my Lights Button Cards only if they are ā€œonā€. All works in the Way i want, little bit complicated i think, but this way it works. But one thing i dint understand.
The Position of the Buttons change when a second or more lights go ā€œonā€. Is there a way to set the position fixed?
This is my Config:
          - type: custom:stack-in-card
            style:
              left: 75.0%
              top: 18.0%
              width: 50%
            cards:
                    - type: markdown
                      content: '     '
                    - type: custom:auto-entities
                      show_empty: false
                      filter:
                        include:
                          - entity_id: light.wohnzimmer
                            state: 'on'
                            options:
                                entity: light.wohnzimmer
                                show_icon: false
                                show_state: false
                                custom_fields:
                                  icon_wohnen: >
                                    <svg viewBox="0 0 35.02 31.02">
                                    <path fill="#9da0a2" d="M12.44,15.69v.24c0,.06,0,.11,0,.19.49,0,.92.06,1.05.61h3.56V10.68c0-.33,0-.35.34-.35h3.46c.34,0,.35,0,.35.35v5.88a1.21,1.21,0,0,0,0,.18c.1,0,.2,0,.3,0s.22.09.22.24c0,1.35,0,2.7,0,4.05,0,.35,0,.36-.37.36H21c0,.36-.07.71-.11,1.07l0,.33c0,.34,0,.34-.37.34-.64,0-.53.07-.61-.58,0-.38-.07-.77-.11-1.15H2.46c0,.35-.07.7-.1,1.05,0,.15,0,.31,0,.46s-.09.22-.24.22H1.63c-.17,0-.24-.07-.25-.24,0-.44-.08-.88-.13-1.32a1.68,1.68,0,0,0,0-.18H.84c-.3,0-.32,0-.32-.33V17c0-.26,0-.29.29-.29H1c0-.08,0-.15,0-.21V10.66c0-.3,0-.33.31-.33H4.91c.26,0,.29.05.29.31v5.23c0,.28,0,.56,0,.86H8.73c.29-.52.29-.52,1.07-.63v-.41h-3a.87.87,0,0,1-1-1c0-1.53,0-3.07,0-4.61a.85.85,0,0,1,.89-.91h8.83a.85.85,0,0,1,.91.93v4.66a.85.85,0,0,1-.89.91H12.44Zm-3.74-1c.45,0,.45,0,.72-.22l.89-.84c.09-.09.18-.16.29,0s0,.2-.06.28L10.4,14l-.72.68h6.4V10.18H15.5c-.11,0-.22,0-.23-.16s.11-.18.24-.18h.54c-.09-.25-.19-.31-.49-.31H6.62a.42.42,0,0,0-.44.31h8.23a.69.69,0,0,1,.25,0,.27.27,0,0,1,.13.18s-.08.11-.14.14a.59.59,0,0,1-.19,0H6.17v4.51H8a.5.5,0,0,0,.31-.12C8.9,14,9.46,13.48,10,12.93c.09-.08.19-.15.29,0s0,.21-.05.29l-.57.54C9.38,14,9.06,14.34,8.7,14.67ZM.87,21H5.36V17.09H3.94c0,.08,0,.15,0,.22,0,.29,0,.32-.33.32H2.48c-.25,0-.29,0-.29-.29v-.25H.87Zm20.51,0V17.09H20.07v.33a.19.19,0,0,1-.21.21H18.53a.19.19,0,0,1-.21-.21v-.33H16.89V21ZM5.73,17.09v2.83H7.45v-1.6c0-.29,0-.31.29-.31h6.79c.25,0,.28,0,.28.28,0,.54,0,1.08,0,1.63h1.72V17.09ZM1.39,15.73H4.84v-5H1.39Zm19.46,0V10.68H17.41v5.05Zm-4.32,4.56H5.73V21h10.8Zm-7.76-.37h4.7V18.37H8.77ZM6.18,15a.5.5,0,0,0,.54.32h8.85c.29,0,.42-.08.47-.31Zm11.23,1.69h3.44V16.1H17.41Zm-16,0H4.84V16.1H1.39Zm7.72,0h4a.39.39,0,0,0-.39-.27H9.5A.39.39,0,0,0,9.11,16.73Zm-.69,3.2V18.36H7.8v1.57Zm6-1.57h-.62v1.56h.62Zm-2.37-2.65H10.16v.4h1.93ZM2,22.78l.13-1.37H1.58l.13,1.37ZM20.13,21.4l.14,1.38h.27c0-.37.08-.72.11-1.08,0-.09,0-.19,0-.3ZM2.53,17.29h.91c.15,0,.15,0,.12-.2h-1Zm16.15-.2c-.05.15,0,.2.15.2h.73c.15,0,.21,0,.13-.21h-1ZM1.68,14a1.47,1.47,0,0,1,1.44-1.46,1.45,1.45,0,1,1,0,2.9A1.49,1.49,0,0,1,1.68,14ZM2,14a1.11,1.11,0,1,0,1.1-1.12A1.11,1.11,0,0,0,2,14Zm1.65-2.35a.57.57,0,0,1-.54.54.58.58,0,0,1-.54-.54.57.57,0,0,1,.55-.54A.57.57,0,0,1,3.66,11.64Zm-.3,0c0-.18-.1-.25-.24-.25a.18.18,0,0,0-.2.19c0,.14.07.23.21.21A1,1,0,0,0,3.36,11.69ZM20.58,14a1.49,1.49,0,0,1-1.45,1.46A1.5,1.5,0,0,1,17.68,14a1.45,1.45,0,0,1,2.9,0Zm-.34,0a1.11,1.11,0,1,0-1.13,1.11A1.1,1.1,0,0,0,20.24,14ZM19.13,11.1a.57.57,0,0,1,.54.54.54.54,0,1,1-1.08,0A.57.57,0,0,1,19.13,11.1Zm-.23.6a.79.79,0,0,0,.23.14.18.18,0,0,0,.2-.21.17.17,0,0,0-.2-.19C19,11.44,18.93,11.51,18.9,11.7ZM9.78,18.64c-.13,0-.26,0-.26.18s.14.16.27.16h2.67c.13,0,.26,0,.27-.16s-.15-.18-.28-.18H9.78ZM3.14,13.12a.87.87,0,1,1,0,1.73.87.87,0,0,1,0-1.73ZM2.6,14a.5.5,0,0,0,.53.52.53.53,0,0,0,0-1A.5.5,0,0,0,2.6,14ZM20,14a.86.86,0,1,1-.87-.86A.9.9,0,0,1,20,14Zm-.34,0a.5.5,0,0,0-.52-.53.53.53,0,1,0,0,1A.49.49,0,0,0,19.65,14ZM.33,1c.1,0,.3-.2.6-.2a3.87,3.87,0,0,1,2.6.1c.3.1.4.3.6.4s.1.3-.1.5a2.29,2.29,0,0,1-.5.3,5.24,5.24,0,0,1-2.8-.2l-.6-.3C-.07,1.45-.07,1.25.33,1Zm1.5-1a2.09,2.09,0,0,0-1.7.8A4.79,4.79,0,0,1,4,1,2.17,2.17,0,0,0,1.83,0Zm5.8,1c.1,0,.3-.2.6-.2a4.24,4.24,0,0,1,2.7.2,2,2,0,0,1,.6.4c.2.1.1.3-.1.5l-.6.3A4.5,4.5,0,0,1,8,2a2,2,0,0,0-.6-.4C7.23,1.45,7.23,1.25,7.63,1Zm1.5-1a2.09,2.09,0,0,0-1.7.8,5.26,5.26,0,0,1,3.9.1A2.3,2.3,0,0,0,9.13,0Zm5.5,1c.1,0,.3-.2.6-.2a4.24,4.24,0,0,1,2.7.2,2,2,0,0,1,.6.4c.2.1.1.3-.1.5l-.6.3A4.5,4.5,0,0,1,15,2a2.29,2.29,0,0,1-.5-.3C14.23,1.45,14.33,1.25,14.63,1Zm1.6-1a2.09,2.09,0,0,0-1.7.8,5.26,5.26,0,0,1,3.9.1A2.39,2.39,0,0,0,16.23,0Zm5.7,1c.1,0,.3-.2.6-.2a4.24,4.24,0,0,1,2.7.2.81.81,0,0,1,.5.3c.2.1.1.3-.1.5l-.6.3a4.41,4.41,0,0,1-2.8-.2,2.29,2.29,0,0,1-.5-.3C21.53,1.45,21.63,1.25,21.93,1Zm1.6-1a2.09,2.09,0,0,0-1.7.8,4.82,4.82,0,0,1,3.9.2A2.26,2.26,0,0,0,23.53,0Zm6,1c.1,0,.3-.2.6-.2a4.24,4.24,0,0,1,2.7.2,2,2,0,0,1,.6.4c.2.1.1.3-.1.5a1.42,1.42,0,0,0-.6.2,4.41,4.41,0,0,1-2.8-.2,2.29,2.29,0,0,1-.5-.3C29.13,1.45,29.13,1.25,29.53,1ZM31,0a2.09,2.09,0,0,0-1.7.8,4.78,4.78,0,0,1,3.9.2A2.17,2.17,0,0,0,31,0Z"/>
                                    <path class="${state}" fill="var(--button-card-light-color-no-temperature)" d="M8.7,14.67c.36-.33.68-.64,1-.95l.57-.54c.09-.08.16-.18.05-.29s-.2,0-.29,0c-.57.55-1.13,1.09-1.71,1.63a.5.5,0,0,1-.31.12H6.17V10.18h8.29a.59.59,0,0,0,.19,0c.06,0,.15-.1.14-.14a.27.27,0,0,0-.13-.18.69.69,0,0,0-.25,0H6.18a.42.42,0,0,1,.44-.31h8.94c.3,0,.4.06.49.31h-.54c-.13,0-.24,0-.24.18s.12.16.23.16h.58v4.49H9.68L10.4,14l.14-.14c.09-.08.16-.17.06-.28s-.2-.05-.29,0l-.89.84C9.15,14.71,9.15,14.71,8.7,14.67Zm-.28,3.69H7.8v1.57h.62Zm5.42,0v1.56h.62V18.36ZM3.44,17.29c.15,0,.15,0,.12-.2h-1v.2Zm15.39,0h.73c.15,0,.21,0,.13-.21h-1C18.63,17.24,18.68,17.29,18.83,17.29ZM3.12,15.1A1.12,1.12,0,1,0,2,14,1.1,1.1,0,0,0,3.12,15.1ZM4,14a.92.92,0,0,1-.89.84.87.87,0,0,1,0-1.73A.92.92,0,0,1,4,14Zm-.87-2.57a.18.18,0,0,0-.2.19c0,.14.07.23.21.21a1,1,0,0,0,.23-.15C3.32,11.51,3.26,11.44,3.12,11.44Zm16,1.43A1.12,1.12,0,1,0,20.24,14,1.1,1.1,0,0,0,19.14,12.87Zm0,2A.87.87,0,1,1,20,14,.91.91,0,0,1,19.13,14.85Zm0-3a.18.18,0,0,0,.2-.21.17.17,0,0,0-.2-.19c-.14,0-.2.07-.23.26A.79.79,0,0,0,19.13,11.84Zm-16,2.67a.53.53,0,0,0,0-1,.53.53,0,1,0,0,1Zm16-1a.53.53,0,1,0,0,1,.49.49,0,0,0,.51-.52A.5.5,0,0,0,19.13,13.46ZM3.23,1.83a3.75,3.75,0,0,1-2.1,0c-.2-.1-.4-.1-.4-.4s.2-.3.4-.4a3,3,0,0,1,2.1.22c.1,0,.2.1.3.1a.22.22,0,0,1,.05.08.25.25,0,0,1-.15.32C3.33,1.85,3.33,1.85,3.23,1.83Zm7.3,0a3,3,0,0,1-2.1-.1c-.2-.1-.4-.2-.4-.4s.2-.3.4-.3a3.75,3.75,0,0,1,2.1.12c.1.1.2.1.3.2a.22.22,0,0,1,.05.08.25.25,0,0,1-.15.32C10.63,1.85,10.63,1.85,10.53,1.83Zm7,0a3,3,0,0,1-2.1-.1c-.2-.1-.4-.2-.4-.4s.2-.3.4-.3a3,3,0,0,1,2.1.1c.1.1.2.1.3.2a.22.22,0,0,1,.05.08.25.25,0,0,1-.15.32C17.73,1.85,17.63,1.85,17.53,1.85ZM25,1.75c0,.1-.07.1-.17.1a3,3,0,0,1-2.1-.1c-.2-.1-.4-.2-.4-.4s.2-.3.4-.3a3.75,3.75,0,0,1,2.1.1c.1.1.2.1.3.2a.22.22,0,0,1,.05.08.25.25,0,0,1-.15.32Zm7.43.1a3,3,0,0,1-2.1-.1c-.2-.1-.4-.2-.4-.4s.2-.3.4-.3a3.75,3.75,0,0,1,2.1.1c.1.1.2.1.3.2a.22.22,0,0,1,.05.08.25.25,0,0,1-.15.32C32.53,1.85,32.53,1.85,32.43,1.85Z"/></svg>
                                styles:
                                  custom_fields:
                                    icon_wohnen:
                                     [top: 0%, left: 2%, width: 100%, position: absolute]
                                template: ['base', 'light']
                          - entity_id: light.kuche
                            state: 'on'
                            options:
                                entity: light.kuche
                                custom_fields:
                                   icon_kuche: >
                                     <path fill="#9da0a2" d="M.33,1c.1,0,.3-.2.6-.2a3.87,3.87,0,0,1,2.6.1c.3.1.4.3.6.4s.1.3-.1.5a2.29,2.29,0,0,1-.5.3,5.24,5.24,0,0,1-2.8-.2l-.6-.3C-.07,1.45-.07,1.25.33,1Zm1.5-1a2.09,2.09,0,0,0-1.7.8A4.79,4.79,0,0,1,4,1,2.17,2.17,0,0,0,1.83,0Zm5.8,1c.1,0,.3-.2.6-.2a4.24,4.24,0,0,1,2.7.2,2,2,0,0,1,.6.4c.2.1.1.3-.1.5l-.6.3A4.5,4.5,0,0,1,8,2a2,2,0,0,0-.6-.4C7.23,1.45,7.23,1.25,7.63,1Zm1.5-1a2.09,2.09,0,0,0-1.7.8,5.26,5.26,0,0,1,3.9.1A2.3,2.3,0,0,0,9.13,0Zm5.5,1c.1,0,.3-.2.6-.2a4.24,4.24,0,0,1,2.7.2,2,2,0,0,1,.6.4c.2.1.1.3-.1.5l-.6.3A4.5,4.5,0,0,1,15,2a2.29,2.29,0,0,1-.5-.3C14.23,1.45,14.33,1.25,14.63,1Zm1.6-1a2.09,2.09,0,0,0-1.7.8,5.26,5.26,0,0,1,3.9.1A2.39,2.39,0,0,0,16.23,0Zm5.7,1c.1,0,.3-.2.6-.2a4.24,4.24,0,0,1,2.7.2.81.81,0,0,1,.5.3c.2.1.1.3-.1.5l-.6.3a4.41,4.41,0,0,1-2.8-.2,2.29,2.29,0,0,1-.5-.3C21.53,1.45,21.63,1.25,21.93,1Zm1.6-1a2.09,2.09,0,0,0-1.7.8,4.82,4.82,0,0,1,3.9.2A2.26,2.26,0,0,0,23.53,0Zm6,1c.1,0,.3-.2.6-.2a4.24,4.24,0,0,1,2.7.2,2,2,0,0,1,.6.4c.2.1.1.3-.1.5a1.42,1.42,0,0,0-.6.2,4.41,4.41,0,0,1-2.8-.2,2.29,2.29,0,0,1-.5-.3C29.13,1.45,29.13,1.25,29.53,1ZM31,0a2.09,2.09,0,0,0-1.7.8,4.78,4.78,0,0,1,3.9.2A2.17,2.17,0,0,0,31,0ZM.66,15.59A1,1,0,0,1,1,15.51H6.68a1.57,1.57,0,0,1,.28.06l0,0a18.35,18.35,0,0,1,2.87-.08c.67,0,1.34,0,2,0,.14,0,.28.06.42.06s.23-.06.35-.06h4c0-.18,0-.35,0-.52s.11-.15.23-.15H18l0-.05.23-.28.22.27-.05.05h.33c0-.39,0-.78,0-1.17,0-.05.1-.13.16-.14s.15.08.15.13c0,.39,0,.79,0,1.18h.33l-.05-.05.24-.27.21.28,0,.05h1.06c.2,0,.28.07.26.27s0,.25,0,.4h.74a1.38,1.38,0,0,1,.29.08v7.5a1.09,1.09,0,0,1-.31.08H12.61c-.11,0-.22-.05-.32-.05s-.2.05-.3.05H8.8c-.36,0-.71,0-1.06,0s-.68,0-1,0c-1.93,0-3.86,0-5.79,0a.92.92,0,0,1-.27-.08Zm21,6.58V16.51H19v5.66Zm-3,0V16.51H16v5.66Zm-12-5.65H4v5.64H6.68Zm-5.7,0v5.65H3.69V16.51ZM7,15.81l-.12.68s0,0,0,.06a1.13,1.13,0,0,1,.06.31c0,1.52,0,3,0,4.54a11.52,11.52,0,0,0,0,1.44h5.31a1.48,1.48,0,0,0,.08-.29.27.27,0,0,0,0-.09,1.4,1.4,0,0,1-.06-.28c0-1.78,0-3.55,0-5.33,0-.12.08-.24.07-.35s-.08-.47-.11-.69Zm8.65.71h-3V18.2h3Zm-3,3.68h3V18.48h-3Zm3,2V20.48h-3v1.69Zm6.05.35H12.62l.06.31h9Zm-.05-6.67h-9v.31h9ZM6.71,22.52H1l.06.31H6.64Zm-.06-6.67H1v.31H6.65ZM17,15.49h3.75l-.06-.31H17Zm5-4.4a1,1,0,0,1-.29.08h-9.1c-.24,0-.28,0-.28-.28V6.12c0-.24,0-.28.28-.28h9.12a.92.92,0,0,1,.27.08Zm-5-.26V6.19H12.67v4.64Zm4.63-4.65H17.31v4.65h4.35Zm-21-.26A1,1,0,0,1,1,5.84H6.7c.27,0,.3,0,.3.3v4.71c0,.3,0,.32-.32.32H1a1,1,0,0,1-.29-.08ZM1,10.83H6.65V6.19H1Zm7.7-2a3,3,0,0,1,0-.31c0-.79,0-1.59,0-2.39,0,0,0-.09,0-.12s.1-.11.15-.17A1,1,0,0,1,9,6s0,.08,0,.12V8.55c0,.09,0,.18,0,.28h1.41a2.17,2.17,0,0,1,0-.25V6.1s0-.1,0-.12.11-.13.16-.13.12.08.15.13,0,.11,0,.17c0,.8,0,1.59,0,2.39,0,.1,0,.19,0,.3h.81A.52.52,0,0,1,12,9.4c0,.44,0,.44-.44.44H7.62c-.27,0-.29,0-.29-.3V9.38a.51.51,0,0,1,.53-.54H8.7Zm-1,.66h4c0-.28,0-.32-.29-.32H8C7.7,9.17,7.66,9.21,7.67,9.49Zm-.12,5.36c-.07,0-.14.1-.22.16.08.05.15.15.23.16H9.11c.07,0,.15-.11.22-.17-.08-.05-.15-.15-.22-.15-.26,0-.52,0-.77,0S7.81,14.83,7.55,14.85Zm4.22.32c.12,0,.24,0,.21-.17s-.14-.15-.21-.15c-.52,0-1,0-1.54,0-.12,0-.24,0-.22.17s.14.15.22.16c.26,0,.51,0,.77,0ZM9.82,10.4c0-.08-.1-.15-.15-.22s-.16.14-.16.21c0,.4,0,.79,0,1.19,0,.07.11.15.16.22s.15-.14.16-.22a3.75,3.75,0,0,0,0-.58A4,4,0,0,0,9.82,10.4Zm-1.16-.06c0-.06-.1-.11-.15-.16s-.16.1-.17.17a3.21,3.21,0,0,0,0,.62c0,.06.1.11.15.16s.14-.1.17-.17a1.6,1.6,0,0,0,0-.31A1.61,1.61,0,0,0,8.66,10.34Zm2,.32a1.6,1.6,0,0,0,0,.31c0,.06.1.15.16.15A.25.25,0,0,0,11,11a3.42,3.42,0,0,0,0-.64.22.22,0,0,0-.16-.15.21.21,0,0,0-.15.14,1.22,1.22,0,0,0,0,.33ZM20.78,17.5c.08,0,.15-.11.22-.16s-.14-.15-.21-.16a7.21,7.21,0,0,0-.93,0c-.06,0-.13.11-.19.16s.13.15.2.16a3.53,3.53,0,0,0,.46,0A2.26,2.26,0,0,0,20.78,17.5Zm-3.9-.32c-.08,0-.14.1-.21.15s.13.17.19.17a7.37,7.37,0,0,0,.94,0c.07,0,.13-.11.2-.16s-.13-.15-.21-.16a3.2,3.2,0,0,0-.44,0A3.65,3.65,0,0,0,16.88,17.18Zm-12,0c-.06,0-.12.1-.18.15s.12.16.19.17a7.53,7.53,0,0,0,.95,0c.06,0,.12-.1.18-.15s-.12-.16-.19-.17a3.34,3.34,0,0,0-.45,0A4.17,4.17,0,0,0,4.85,17.18Zm-2.06.32c.08,0,.14-.1.2-.16s-.12-.15-.19-.16a7.21,7.21,0,0,0-.93,0c-.07,0-.14.1-.2.16s.12.15.19.16a3.85,3.85,0,0,0,.48,0A2.26,2.26,0,0,0,2.79,17.5ZM12,20v2.21c0,.25,0,.29-.29.29H7.63c-.27,0-.3,0-.3-.3v-4.4c0-.27,0-.3.3-.3h4.08c.26,0,.29,0,.29.29Zm-.35-2.15h-4v4.3h4ZM9.19,16.52c-.07,0-.13.09-.19.15s.11.16.17.16a8,8,0,0,0,1,0c.06,0,.12-.1.18-.16s-.12-.14-.18-.15a2.36,2.36,0,0,0-.46,0A2.77,2.77,0,0,0,9.19,16.52Zm2.33-.33c-.07,0-.12.1-.18.15s.1.14.16.15.13-.07.24-.14C11.64,16.27,11.57,16.18,11.52,16.19Zm-2.86.49c0-.06-.1-.11-.16-.17s-.15.1-.15.16.08.13.16.24C8.58,16.8,8.67,16.73,8.66,16.68Zm-1-.35c0,.07.1.12.16.17s.13-.11.14-.17-.07-.12-.15-.23C7.76,16.21,7.68,16.28,7.69,16.33Zm3,.34c0,.06.1.11.16.17s.14-.11.14-.17-.07-.12-.15-.23C10.76,16.55,10.68,16.62,10.69,16.67Zm3.16.51c-.07,0-.12.1-.18.15s.11.16.17.17a3.64,3.64,0,0,0,.66,0c.06,0,.11-.1.16-.15s-.1-.15-.17-.17a1.22,1.22,0,0,0-.33,0A1.61,1.61,0,0,0,13.85,17.18Zm.64,2.32c.07,0,.11-.11.17-.16s-.12-.15-.18-.16a3.42,3.42,0,0,0-.64,0c-.06,0-.11.11-.17.16s.11.14.18.16a1.08,1.08,0,0,0,.31,0A1.22,1.22,0,0,0,14.49,19.5Zm0,2c.08,0,.13-.1.19-.15s-.11-.16-.17-.17a3.53,3.53,0,0,0-.65,0c-.06,0-.11.11-.17.17s.11.13.18.15a1.08,1.08,0,0,0,.31,0A1.05,1.05,0,0,0,14.47,21.5ZM14.22,9.85c-.07,0-.14.1-.22.15.07.06.14.16.22.16.41,0,.81,0,1.22,0,.08,0,.15-.1.22-.15s-.14-.15-.21-.16a4,4,0,0,0-.6,0A4.42,4.42,0,0,0,14.22,9.85Zm4.67,0c-.08,0-.15.1-.22.16s.15.15.22.15c.41,0,.82,0,1.22,0,.08,0,.15-.1.22-.16s-.14-.14-.22-.15a4,4,0,0,0-.6,0A4.26,4.26,0,0,0,18.89,9.85Zm-14.45.31c.08,0,.15-.1.22-.16s-.13-.15-.2-.15c-.42,0-.84,0-1.27,0-.06,0-.12.1-.19.16s.13.15.2.15a4.3,4.3,0,0,0,.62,0A4.26,4.26,0,0,0,4.44,10.16Zm6.65,8.35c.12,0,.23,0,.23-.17s-.11-.17-.23-.17H8.25c-.12,0-.24,0-.24.16s.12.18.24.18h2.84Z"/>
                                     <path class="${state}" fill="var(--button-card-light-color-no-temperature)" d="M3.23,1.83a3.75,3.75,0,0,1-2.1,0c-.2-.1-.4-.1-.4-.4s.2-.3.4-.4a3,3,0,0,1,2.1.22c.1,0,.2.1.3.1a.22.22,0,0,1,.05.08.25.25,0,0,1-.15.32C3.33,1.85,3.33,1.85,3.23,1.83Zm7.3,0a3,3,0,0,1-2.1-.1c-.2-.1-.4-.2-.4-.4s.2-.3.4-.3a3.75,3.75,0,0,1,2.1.12c.1.1.2.1.3.2a.22.22,0,0,1,.05.08.25.25,0,0,1-.15.32C10.63,1.85,10.63,1.85,10.53,1.83Zm7,0a3,3,0,0,1-2.1-.1c-.2-.1-.4-.2-.4-.4s.2-.3.4-.3a3,3,0,0,1,2.1.1c.1.1.2.1.3.2a.22.22,0,0,1,.05.08.25.25,0,0,1-.15.32C17.73,1.85,17.63,1.85,17.53,1.85ZM25,1.75c0,.1-.07.1-.17.1a3,3,0,0,1-2.1-.1c-.2-.1-.4-.2-.4-.4s.2-.3.4-.3a3.75,3.75,0,0,1,2.1.1c.1.1.2.1.3.2a.22.22,0,0,1,.05.08.25.25,0,0,1-.15.32Zm7.43.1a3,3,0,0,1-2.1-.1c-.2-.1-.4-.2-.4-.4s.2-.3.4-.3a3.75,3.75,0,0,1,2.1.1c.1.1.2.1.3.2a.22.22,0,0,1,.05.08.25.25,0,0,1-.15.32C32.53,1.85,32.53,1.85,32.43,1.85ZM11.66,9.49c0-.28,0-.32-.29-.32H8c-.26,0-.3,0-.29.32Z"/></svg>
                                styles:
                                  custom_fields:
                                    icon_kuche:
                                      [top: 0%, left: 6%, width: 100%, position: absolute]
                                template: ['light']
                          - entity_id: light.tradfri_esszimmer
                            state: 'on'
                            options:
                                entity: light.tradfri_esszimmer
                                custom_fields:
                                   icon_essen: >
                                     <path fill="#9da0a2" d="M12.82,3.81c.32-.09.38.11.42.32a.63.63,0,0,0,.41.47,2.34,2.34,0,0,1,1.43,1.91c0,.16,0,.23-.19.23H10.47c-.2,0-.25-.07-.2-.32a2.42,2.42,0,0,1,1.51-1.87c.15-.06.25-.13.27-.29l0-.12c.06-.21.11-.43.44-.33V.29c0-.06,0-.13,0-.18A.16.16,0,0,1,12.66,0a.22.22,0,0,1,.15.1.64.64,0,0,1,0,.2V3.81Zm1.95,2.63A2,2,0,0,0,13.58,4.9.87.87,0,0,1,13,4.2a.17.17,0,0,0-.1-.1c-.35-.07-.42,0-.53.31a.49.49,0,0,0,0,.11.32.32,0,0,1-.27.26,2.07,2.07,0,0,0-1.39,1.46,1.06,1.06,0,0,0,0,.2Zm4-2.63V.28c0-.05,0-.12,0-.16A.29.29,0,0,1,18.9,0s.1.07.13.13,0,.09,0,.14V3.78a.92.92,0,0,1,.19,0c.06,0,.16.08.17.14a1,1,0,0,0,.61.73,2.28,2.28,0,0,1,1.29,1.75c.05.27,0,.32-.27.32H16.75c-.27,0-.31,0-.26-.3A2.39,2.39,0,0,1,18,4.55a.38.38,0,0,0,.26-.29.78.78,0,0,1,.05-.14C18.37,3.92,18.43,3.72,18.74,3.81ZM21,6.43c0-.08,0-.14,0-.2A1.88,1.88,0,0,0,19.81,4.9a.87.87,0,0,1-.64-.7A.17.17,0,0,0,19,4.1c-.38,0-.38,0-.51.32,0,0,0,0,0,0a.4.4,0,0,1-.33.34,2,2,0,0,0-1.4,1.63ZM1.62,16.27H1c-.15,0-.21-.07-.21-.22v-.63H.26c-.23,0-.26,0-.26-.26V14c0-.23,0-.27.27-.27h4v-2a.89.89,0,0,1,1-.95H7.48a.91.91,0,0,1,.9.9v2.08h2.24v-2a.9.9,0,0,1,1-1h2a1.79,1.79,0,0,1,.4,0,.9.9,0,0,1,.71.89V13.7h4c.28,0,.31,0,.31.31s0,.78,0,1.17c0,.17-.06.25-.23.24h-.58V16c0,.24,0,.26-.27.26h-.55v.25c-.05,2.25-.09,4.5-.14,6.75,0,.24,0,.27-.27.27h-.52c-.21,0-.26,0-.26-.25,0-1.44-.06-2.88-.08-4.33q0-1.32-.06-2.67H14.71v.47H15a.68.68,0,0,1,.63.42.6.6,0,0,1-.16.68.42.42,0,0,0-.08.21.88.88,0,0,0,0,.28c0,.17-.07.24-.24.23h-.29v3.92c0,.3,0,.31-.32.31-.13,0-.26,0-.39,0s-.21-.09-.21-.23c0-.56,0-1.11,0-1.66a.37.37,0,0,0-.17-.33c-.37-.27-.73-.56-1.12-.86a7.26,7.26,0,0,1-.78.59,1,1,0,0,0-.52,1.07c0,.39,0,.79,0,1.19,0,.17-.06.24-.23.23a3.38,3.38,0,0,0-.45,0c-.17,0-.23-.06-.23-.23,0-.83,0-1.65,0-2.48V18.57h-.32c-.13,0-.21-.05-.2-.2v-.2a.45.45,0,0,0-.13-.37.55.55,0,0,1-.12-.63.67.67,0,0,1,.57-.42c.11,0,.23,0,.35,0v-.48H8.39v.48h.29a.67.67,0,0,1,.63.43.6.6,0,0,1-.16.68.37.37,0,0,0-.09.2,1.71,1.71,0,0,0,0,.32.17.17,0,0,1-.19.19H8.53v3.95c0,.27,0,.28-.27.28H7.89c-.24,0-.26,0-.26-.25V20.87a.28.28,0,0,0-.12-.25l-1.17-.9-1.22.94a.32.32,0,0,0-.06.2c0,.54,0,1.08,0,1.62,0,.31,0,.32-.32.32h-.3c-.27,0-.29,0-.29-.28V18.57H3.82c-.14,0-.21-.06-.21-.2v-.15a.51.51,0,0,0-.14-.43.54.54,0,0,1-.09-.64.66.66,0,0,1,.57-.4c.11,0,.22,0,.34,0v-.47H3v.44Q2.88,20,2.82,23.21c0,.3,0,.32-.32.32H2c-.23,0-.26,0-.26-.26,0-1.11-.05-2.22-.07-3.33s-.05-2.35-.07-3.52C1.63,16.37,1.62,16.33,1.62,16.27ZM.3,15.12H13.09c.05,0,.11,0,.15,0s.13.09.12.14-.08.12-.13.14a1.31,1.31,0,0,1-.28,0H1.12V16H17.88v-.54h-1c-.11,0-.22,0-.22-.14s.1-.16.22-.16H18.7c0-.32,0-.62,0-.91s0-.22-.21-.22H.48c-.09,0-.18,0-.18.12Zm7.78-1.43c0-.73,0-1.46,0-2.18A.53.53,0,0,0,7.54,11H5.27a.59.59,0,0,0-.67.66v1.84c0,.06,0,.11,0,.17Zm2.84,0H14.4V11.62c0-.31-.19-.57-.45-.57-.84,0-1.69,0-2.53,0a.5.5,0,0,0-.5.51C10.91,12.25,10.92,13,10.92,13.68ZM8.75,18H5.32c-.06,0-.12,0-.17,0S5,17.94,5,17.89s.08-.11.14-.14a.42.42,0,0,1,.16,0H8.66c.27,0,.39-.11.39-.34s-.12-.35-.39-.35H4c-.25,0-.38.13-.38.34a.35.35,0,0,0,.37.35.28.28,0,0,1,.13,0c.15,0,.42-.12.42.15s-.26.11-.41.14H3.91v.21H8.75ZM2.52,23.22l.14-6.94H1.92l.14,6.94Zm14.41,0,.15-6.94h-.74l.14,6.94Zm-4.26-6.17H10.32c-.27,0-.4.14-.38.39s.15.3.4.3h4.73a.33.33,0,0,0,.29-.44c0-.21-.2-.25-.38-.25Zm-8.06-.31H8.07v-.46H4.61Zm9.78-.46H10.93v.46h3.46ZM4.74,22.49V18.58H4.45v3.91Zm9.51-3.91v3.9h.3v-3.9Zm-6,3.91v-3.9H7.94v3.9Zm2.55-3.91v3.91h.29V18.58Zm4.31-.53H10.25v.21h4.83Zm-7.46.68-1,.8,1,.8Zm3.76,0v1.6l1-.8Zm-6.31,0v1.58l1-.79Zm8.87,0-1,.8,1,.8Zm-8.59-.15.93.71s.11,0,.15,0,.31-.24.46-.35l.43-.34Zm6.32,0,.54.42c.15.11.3.3.45.3s.3-.19.45-.31l.54-.41ZM14.14,15c-.11,0-.22,0-.2.16a.27.27,0,0,0,.2.13h1.34c.1,0,.19,0,.2-.14s-.09-.16-.2-.16H14.14Z"/>
                                     <path class="${state}" fill="var(--button-card-light-color-no-temperature)" d="M14.77,6.44H10.59a1.06,1.06,0,0,1,0-.2A2.07,2.07,0,0,1,12,4.78a.32.32,0,0,0,.27-.26.49.49,0,0,1,0-.11c.11-.33.18-.38.53-.31a.17.17,0,0,1,.1.1.87.87,0,0,0,.63.7A2,2,0,0,1,14.77,6.44Zm6.17-.21A1.88,1.88,0,0,0,19.81,4.9a.87.87,0,0,1-.64-.7A.17.17,0,0,0,19,4.1c-.38,0-.38,0-.51.32,0,0,0,0,0,0a.4.4,0,0,1-.33.34,2,2,0,0,0-1.4,1.63H21C21,6.35,21,6.29,20.94,6.23Zm-3.42-.15a.18.18,0,0,1-.13-.14s.08-.13.12-.13a3.31,3.31,0,0,1,.63,0c.05,0,.12.09.12.14s-.07.12-.12.13a1.61,1.61,0,0,1-.31,0h0A1.06,1.06,0,0,1,17.52,6.08ZM18.92,6c0,.13-.1.14-.21.14s-.22,0-.19-.16.12-.11.22-.2C18.83,5.82,18.92,5.88,18.92,6Z"/></svg>`; ]]]
                                styles:
                                  custom_fields:
                                    icon_essen:
                                template: ['light']
                          - entity_id: light.wc
                            state: 'on'
                            options:
                                entity: light.wc
                                custom_fields:
                                   icon_wc: >
                                    <path style="clip-path: url(#mask);" fill="#9da0a2" d="M8.13,1A3,3,0,0,1,8.69.76a4.48,4.48,0,0,1,2.73.18,1.77,1.77,0,0,1,.56.39.27.27,0,0,1-.05.46,1.86,1.86,0,0,1-.59.27,5.11,5.11,0,0,1-2.82-.17A1.92,1.92,0,0,1,8,1.6C7.79,1.41,7.81,1.23,8.13,1ZM9.69,0A2,2,0,0,0,8,.83,4.8,4.8,0,0,1,11.89,1,2.19,2.19,0,0,0,9.69,0ZM3.33,16.91v1h.24v.51H.35c-.27,0-.35-.08-.35-.34V9.77A.25.25,0,0,1,.27,9.5H2.8c.18,0,.27.11.27.32v4h.77c0-.34,0-.67,0-1A2.15,2.15,0,0,1,4,12.31c.3-1,.61-2.08.91-3.12a1.25,1.25,0,0,1,1.3-1,4,4,0,0,0,.49,0l-.25-.07A1.66,1.66,0,0,1,7,4.9c.5,0,1,0,1.51,0A.54.54,0,0,0,9,4.63l.26-.39.41.28a1.27,1.27,0,0,1-1.49.86A1.66,1.66,0,0,1,8.54,7.1,1.62,1.62,0,0,1,7.28,8.2L8,8.59a1.73,1.73,0,0,1,0-.3,1,1,0,0,1,2,.08l.42,3.3a1,1,0,0,1-.73,1.12l-.11,0a.84.84,0,0,1,.58,1c-.07,1-.13,2-.19,3v.09h.21a.76.76,0,0,1,.75.76,4,4,0,0,1,0,.49.25.25,0,0,1-.27.29H9.17a.74.74,0,0,1-.73-.79c0-.59.07-1.18.11-1.77s.06-1,.1-1.52H7.42v.4a6.7,6.7,0,0,1,0,.9,1.5,1.5,0,0,1-1.47,1.25c-.8,0-1.6,0-2.39,0Zm-2.81,1H2.8v-1H2.06V16.4H5.87a1,1,0,0,0,1-.87,11.22,11.22,0,0,0,0-1.16H.52ZM7.76,9.5a.68.68,0,0,0-.67-.77H6.15a.71.71,0,0,0-.75.56c-.3,1-.58,2-.89,3a3.4,3.4,0,0,0-.16,1.18c0,.29.07.37.37.37H8.85c.24,0,.33.1.32.33s0,.51-.05.77c0,.89-.11,1.78-.17,2.68,0,.21.09.31.3.31h1.12l.1,0c0-.43,0-.5-.44-.5h0c-.56,0-.54-.11-.51-.55.07-1.07.14-2.14.2-3.21,0-.23-.08-.33-.32-.33h-2c-.49,0-1,0-1.47-.05-.3,0-.38-.21-.22-.46l.65-1,.35-.54c-.28-.18-.55-.34-.8-.52a1,1,0,0,1-.43-1,1,1,0,0,1,.68-.81,1,1,0,0,1,.88.12ZM10,11.8v-.1c-.14-1.09-.28-2.17-.41-3.26a.51.51,0,1,0-1,.13c.06.53.13,1,.2,1.58,0,.14,0,.26-.11.34s-.24,0-.35-.05L6.84,9.52a.67.67,0,0,0-.39-.1.47.47,0,0,0-.42.4.49.49,0,0,0,.23.53l1,.66,1.89,1.22a.51.51,0,0,0,.8-.43ZM.53,11v2.79h2V11ZM8.12,6.56A1.14,1.14,0,0,0,7,5.41a1.15,1.15,0,1,0,0,2.3A1.15,1.15,0,0,0,8.12,6.56Zm-.95,5-.81,1.26H9.14Zm-6.65-1h2V10h-2ZM4.1,14.88v.49H6.39v-.49Zm15.28-4.35a1.16,1.16,0,0,1-.58-.14s-.06,0-.09,0a1.49,1.49,0,0,1-1,.56,1.31,1.31,0,0,1-.59,0A.12.12,0,0,0,17,11a1.42,1.42,0,0,1-1.52.58l-.21-.08a.08.08,0,0,0-.11,0,.86.86,0,0,1-.76.37.94.94,0,0,1-.73-1.4c0-.06,0-.08,0-.12A1.68,1.68,0,0,1,13,9.61a1.73,1.73,0,0,1-.12-.78.13.13,0,0,0-.09-.14,1.44,1.44,0,0,1-.78-1A1.48,1.48,0,0,1,12.87,6a.08.08,0,0,0,.05-.12,1.64,1.64,0,0,1,.25-1.34,1.51,1.51,0,0,1,.77-.59,1.44,1.44,0,0,1,.87,0c.07,0,.1,0,.12,0a1.42,1.42,0,0,1,2.53-.21c.09.15.08.14.24.12a3.88,3.88,0,0,1,.48,0c.06,0,.09,0,.11-.08A1.05,1.05,0,0,1,19.57,3a1,1,0,0,1,.76.85A1.06,1.06,0,0,1,20,4.9s-.05,0-.08.06-.1.08-.09.2a2,2,0,0,1,0,.34c0,.07,0,.1.08.12a1.61,1.61,0,0,1,.76.5,1.75,1.75,0,0,1,.43,1.37,1.72,1.72,0,0,1-.51,1.07.09.09,0,0,0,0,.12,1.33,1.33,0,0,1-.95,1.83ZM14.45,10v0a.81.81,0,0,1,.47.13.89.89,0,0,1,.42.86c0,.07,0,.1.08.11l.19.07a1,1,0,0,0,1.17-.59c.08-.14.15-.17.3-.12a1.14,1.14,0,0,0,.94,0,1.3,1.3,0,0,0,.5-.46.19.19,0,0,1,.32-.06.85.85,0,0,0,.55.18.88.88,0,0,0,.78-.48.94.94,0,0,0,0-.93c-.11-.19-.1-.24,0-.38a1.39,1.39,0,0,0-.61-2.42c-.14,0-.19-.09-.18-.24s0-.23,0-.34a1.35,1.35,0,0,0-1-1.22,1.28,1.28,0,0,0-.92.08.18.18,0,0,1-.26-.11A.77.77,0,0,0,17.2,4a1.05,1.05,0,0,0-1.52-.44,1.11,1.11,0,0,0-.47.68.2.2,0,0,1-.29.15h0a1,1,0,0,0-.69-.06A1.23,1.23,0,0,0,13.35,6c.07.16,0,.26-.15.31l-.08,0a1.1,1.1,0,0,0-.68,1.49,1,1,0,0,0,.67.62.2.2,0,0,1,.16.25v.06a1.41,1.41,0,0,0,.68,1.42.14.14,0,0,0,.14,0Zm4.78-6.71a.66.66,0,0,0-.56.38c0,.06,0,.09,0,.12a1.67,1.67,0,0,1,.87.75c.05.09.06.09.14,0A.74.74,0,0,0,20,3.81.73.73,0,0,0,19.23,3.33ZM15,11c0-.05,0-.1,0-.14a.52.52,0,0,0-1-.17.42.42,0,0,0,0,.12.14.14,0,0,1,0,.06s0,0,0,.07A.53.53,0,1,0,15,11ZM14,3.13a.44.44,0,0,0,.43.45.45.45,0,0,0,.43-.44.44.44,0,0,0-.43-.45A.44.44,0,0,0,14,3.13Zm5.3,7.67a.39.39,0,0,0-.39.4.39.39,0,1,0,.78,0A.4.4,0,0,0,19.32,10.8Zm1.22-5.94a.3.3,0,0,0-.3.31.3.3,0,0,0,.3.3.29.29,0,0,0,.3-.3A.29.29,0,0,0,20.54,4.86Zm-2.79,6.59a.17.17,0,0,0-.17-.16.16.16,0,0,0-.16.16.17.17,0,0,0,.16.17A.18.18,0,0,0,17.75,11.45Zm-5.22-.93a.16.16,0,0,0,.32,0,.16.16,0,1,0-.32,0Zm.9-6.95a.17.17,0,0,0,.17.16.17.17,0,0,0,.16-.16.18.18,0,0,0-.17-.17A.18.18,0,0,0,13.43,3.57Zm5.65,3.49a1.78,1.78,0,0,1-.74,1.43c-.09.07-.19.13-.28.21a.12.12,0,0,0,0,.09,1.33,1.33,0,0,1,0,.28A.64.64,0,0,1,17,9.4a.1.1,0,0,0-.12,0,.64.64,0,0,1-.7,0,.11.11,0,0,0-.12,0,.67.67,0,0,1-.63,0A.46.46,0,0,1,15.15,9a.42.42,0,0,0-.23-.4,1.88,1.88,0,0,1-.72-.84,1.59,1.59,0,0,1-.13-.88,1.89,1.89,0,0,1,.37-.92A2.27,2.27,0,0,1,15.84,5a2.8,2.8,0,0,1,2.63.62A1.84,1.84,0,0,1,19.08,7.06ZM16.79,5.31A2.49,2.49,0,0,0,15,5.87a1.61,1.61,0,0,0-.52,1,1.3,1.3,0,0,0,.26,1,2.16,2.16,0,0,0,.64.56.28.28,0,0,1,.16.27,1.31,1.31,0,0,0,0,.28c0,.09.09.13.19.13A.18.18,0,0,0,15.94,9s0-.05,0-.07a.22.22,0,0,1,.19-.15.19.19,0,0,1,.2.13l0,.1a.16.16,0,0,0,.19.12.18.18,0,0,0,.2-.17.18.18,0,0,1,.12-.16.21.21,0,0,1,.29.17.19.19,0,0,0,.22.16.18.18,0,0,0,.19-.18v-.2c0-.15.05-.24.18-.32a2.16,2.16,0,0,0,.64-.56,1.47,1.47,0,0,0-.11-1.8A2.06,2.06,0,0,0,16.79,5.31Zm2.06,3.13a.31.31,0,0,0-.3.32.32.32,0,0,0,.3.31.32.32,0,0,0,0-.63ZM16.37,4.12a.21.21,0,0,0-.21-.21.2.2,0,0,0-.21.22.21.21,0,0,0,.21.21A.21.21,0,0,0,16.37,4.12ZM13.63,7.68a.21.21,0,1,0,.21.21A.21.21,0,0,0,13.63,7.68Zm6.13.52A.17.17,0,0,0,19.6,8a.16.16,0,0,0-.16.17.16.16,0,1,0,.32,0Zm-.24-.86a.11.11,0,0,0-.11-.12.1.1,0,0,0-.11.11.1.1,0,0,0,.1.11A.11.11,0,0,0,19.52,7.34ZM14.11,8.39A.12.12,0,0,0,14,8.5a.12.12,0,0,0,.11.11.1.1,0,0,0,.11-.11A.1.1,0,0,0,14.11,8.39Zm2.72-4a.1.1,0,0,0-.12.1.11.11,0,0,0,.1.12.12.12,0,0,0,.12-.11A.1.1,0,0,0,16.83,4.39Zm.58,3.29a.79.79,0,0,1-.84-.74.85.85,0,0,1,1.69,0A.79.79,0,0,1,17.41,7.68Zm0-.36a.38.38,0,1,0,0-.76.43.43,0,0,0-.44.38A.42.42,0,0,0,17.41,7.32Zm-1.91.56a.8.8,0,0,1-.84-.74.8.8,0,0,1,.86-.74.79.79,0,0,1,.84.76A.81.81,0,0,1,15.5,7.88Zm.44-.74a.41.41,0,0,0-.43-.38.43.43,0,0,0-.44.37.42.42,0,0,0,.44.39A.41.41,0,0,0,15.94,7.14Zm.62,1.26h.19c.27,0,.43-.26.3-.45a1.39,1.39,0,0,0-.21-.27.37.37,0,0,0-.52,0,1.68,1.68,0,0,0-.25.29.29.29,0,0,0,.23.42,1.1,1.1,0,0,0,.26,0Z"/></clipPath></defs><path class="${state}" fill="var(--button-card-light-color-no-temperature)" d="M11.24,1.74c.18-.14.2-.26.07-.39a1,1,0,0,0-.25-.17A3.25,3.25,0,0,0,9,1c-.18.05-.4.11-.41.33s.2.3.37.37a3.24,3.24,0,0,0,2.15.08A.62.62,0,0,0,11.24,1.74Zm6.17,5.58A.42.42,0,0,1,17,6.94a.43.43,0,0,1,.44-.38.38.38,0,1,1,0,.76Zm-1.47-.18a.41.41,0,0,1-.43.38.42.42,0,0,1-.44-.39.43.43,0,0,1,.44-.37A.41.41,0,0,1,15.94,7.14Z"/></svg>
                                styles:
                                  custom_fields:
                                    icon_wc:
                                template: ['light']
                      sort:
                        method: last_changed
                        count: 5
                      card:
                        layout: horizontal
                        min_columns: 5
                        column_width: 18%
                        justify-content: flex-start
and this is the result:
1
2
3
4
Funny you mention this, I have this problem since v14 and on smaller screens the buttons in the middle are always smaller in height (the width is fine). I have tried so many things but it seems I have not the skills to fix it.
I donā€™t understand how it can work for you guys since you guys run v15 (which has the very same problem for me). Only v14 works, but the spacings left and right are huge. So I am currently still on v13, though v13 has a bug that when resizing the window on a browser the view will go into an LSD trip and is unusable
This is fixed in v14 and up but canā€™t use that because of the buttons getting smaller.
I also wonder if this will ever be updated since well, your post is almost a month old, and the other card from this developer (more-info-card) also has problems (unfortunately he didnt respond to that issue either).
So either heā€™s fed up with the custom cards (or fed up by people nagging him about them). Or he is working on core (which would be the best scenario imho) or he simply stopped developing for HA all together. Who knows? If someone does know please reply here.
Its a shame because his cards are really good (when they work as intended) and Iā€™d hate to see them go.
Yeah it is a shame, though I understand if heā€™s done with it. HA pumps out updates every week and a major every 3 weeks or so, which can break lots of stuff. I really hope Thomasā€™ work gets incorporated into the core, because as of right now, they are kinda musthaves (especially browser_mod, card_mod, card_tools).
I decided to only use layout-card to put my UI inside a column to add some paddings. Iā€™m not looking into breaking my UI every three weeks. I guess itā€™s time I get my app developing skills and create a native app based of my UI so I donā€™t have to worry anymore xD
With version 16 and HA 115.3, the layout is a bit of. The button card in column 2 is less high as the rest (only on mobile)
Any idea how to resolve this ?
EDIT: I just now saw the posts from above from ppl having the same issue :frowning:
Same problem here, you can downgrade to version 12 to solve this.
Hello guys, iā€™m trying to understand how to align all the column to the left.
The default behavior of this card put the cards on the middle of the screen.
Can i set it to ā€œstartā€ from the left side?
Thank you!
EDIT: Iā€™m using it in panel mode!
Iā€™m actually on version 15 which works for me.
Any news about this?
I temporary switched to Layout Card Gridder.
Hello friends. I ask because I know that at the beginning it was very complicated and now it is solved. I have a view that is armed with a 2x2 grid, but when I break the phone I would like to see it as a 1x4 grid or vertically. If there is a solution for this, I would like you to help me. Excellent what they programmed and thank you very much.
layout: vertical
column_width: 100%
cards:
  - type: 'custom:layout-card'
    layout: grid
    gridrows: auto auto
    gridcols: 40% 60%
    min-witdh: 40px
    cards:
      - type: thermostat
        entity: climate.acuario
        gridrow: 1 / 1
        gridcol: 1 / 1
        style: 'ha-card { height: 100%; }'
      - type: 'custom:mini-graph-card'
        entities:
          - sensor.temperature
        hours_to_show: 24
        name: Temperatura de acuario
        points_per_hour: 2
        show:
          extrema: true
      - type: vertical-stack
        gridrow: 2 / 4
        gridcol: 1
        cards:
          - type: horizontal-stack
            cards:
              - entity: switch.enchufe_termometro_acuario
                hold_action:
                  action: more-info
                icon: 'mdi:fan'
                icon_height: 40px
                show_icon: true
                show_name: true
                tap_action:
                  action: toggle
                theme: default
                type: entity-button
              - color: var(--state-icon-active-color)
                entity: input_boolean.clima_manual
                icon: 'mdi:air-conditioner'
                icon_height: 40px
                state:
                  - color: null
                    value: 'off'
              - entity: switch.enchufe_retorno
                hold_action:
                  action: more-info
                icon: 'mdi:power'
                icon_height: 40px
                show_icon: true
                show_name: true
                tap_action:
                  action: toggle
                theme: default
                type: entity-button
              - entity: switch.enchufe_skimmer
                hold_action:
                  action: more-info
                icon: 'mdi:power'
                icon_height: 40px
                show_icon: true
                show_name: true
                tap_action:
                  action: toggle
                theme: default
                type: entity-button
            cards:
              - entity: switch.sonoff_refugio
                hold_action:
                  action: more-info
                icon: 'mdi:radiator'
                icon_height: 40px
                show_icon: true
                show_name: true
                tap_action:
                  action: toggle
                type: entity-button
                hold_action:
                  action: more-info
                icon: 'mdi:ceiling-light'
                icon_height: 40px
                show_icon: true
                show_name: true
                show_state: false
                tap_action:
                  action: toggle
                type: button
              - entity: switch.enchufe_luz_sump
                hold_action:
                  action: more-info
                icon_height: 40px
                show_icon: true
                show_name: true
                tap_action:
                  action: toggle
                type: button
      - type: 'custom:flex-table-card'
        gridrow: 2 / 2
        gridcol: 2 / 2
        columns:
          - attr_as_list: mediciones
            modify: x.KH
            modify: x.CA
            modify: x.MG
            modify: x.NO3
            modify: x.PO4
            modify: x.Fecha
        entities:
          include: sensor.mediciones
        title: Mediciones del Acuario
