šŸ”¹ Layout-card - Take control of where your cards end up
Hi, Iā€™m trying to create a card with entities on the left and an icon on the right (cropped, I like it that way).
Iā€™m not sure Iā€™ve done it in the best way, for example I would like to increase the width of the left column to have only one line for each entity (now it wraps).
This is the graphic result:
Could you give me some advice?
square: false
type: grid
cards:
  - type: custom:stack-in-card
    cards:
      - type: markdown
        content: >-
          <center><strong><font size="3"><font
          color=white>FRIGORIFERO</font></font></center>
      - type: custom:layout-card
        layout_type: custom:grid-layout
        layout:
          grid-template-columns: 23% 140%
        cards:
          - type: vertical-stack
            cards:
                chips:
                  - type: spacer
                chips:
                  - type: entity
                    entity: sensor.ble_temp_freezer
                    icon_color: blue
                    icon: mdi:snowflake-thermometer
                chips:
                  - type: spacer
                chips:
                  - type: entity
                    entity: sensor.ble_temp_frigo
                    icon_color: blue
          - type: button
            tap_action:
              action: none
            icon_height: 100%
            show_name: false
            icon: mdi:fridge
            style: |
              ha-card {
               background-color: transparent;
               box-shadow: none;
              :host {
                --paper-item-icon-color: grey
columns: 2
This is the first time I have used this and it is exactly what I was after.
I am using it for a card only to allow me to have two other cards side by side and it works a treat. The only issue I have is that one of the cards is not being centred vertically.
As you can see the right hand card is not centring. Can anyone suggest how I go about making the right card sit beautifully in the middle of the card.
Sorry to dig up an old post but this doesnā€™t seem to work with custom:button-cards within a layout card.
Or should it? see a simple test code below;
Card in area ā€œA1ā€ has its height manually adjusted.
the remaining cards wonā€™t adjust to 100% height.
Let me know if this is a custom:button-card issue/standard behavior or if there is something wrong with my code.
type: custom:mod-card
card_mod:
  style:
    layout-card$:
      grid-layout$: |
        :host {
          padding: 0rem !important;
        #root {
          margin: 0rem !important;
          height: 100% !important;
        #root > * {
          margin: 0.2rem !important;
      ha-card  {
        border: solid 0.1rem blue !important;
card:
  layout_type: grid
  layout:
    grid-template-columns: 30% 30% 1fr
    grid-template-rows: 30% 1fr
    grid-template-areas: |
      "A1 A2 A3"
      "A1 A2 B3"
  cards:
    - type: custom:button-card
      view_layout:
        grid-area: A1
      styles:
        card:
          - height: 10.2rem
      entity: switch.wallswitch50
      view_layout:
        grid-area: A2
    - type: horizontal-stack
      view_layout:
        grid-area: A3
      cards:
          icon: mdi:volume-minus
      view_layout:
        grid-area: B3
      cards:
Edit:
Answer is to add
        styles:
          card:
            - height: 100%
to each button card or via a template.
BTW thank you for the other part related to padding/margins as this works perfectly.
I think youā€™ll need to mess with the button-card itself, as far as I remember, it has a default aspect ratio set that will result in the behaviour youā€™re seeing.
Layout Card vs Grid card - I tried to replace my grid cards with layout card. Doing this i recognized that with the layout card compared to the grid card i have an small frame in the layout card
Layout Card
Grid Card
Question is now how could i get rid of this small frame. Compared with other cards the layout card has always this frame which makes them looking smaller compred to other card - This drives me mad.
As layout option i use:
grid-template-columns: 1fr 1fr
grid-template-rows: auto
margin: 0px
padding: 0px
Any one any idea i could try?
Check my post just above. You can manage all margins by embedding your layout-card In a custom.mod-card. this part is the one you need to play with:
card_mod:
  style:
    layout-card$:
      grid-layout$: |
        :host {
        #root {
        #root > * {
Thanks, will check it out. Wondering how I can bypass the default aspect ratio and force height: 100% as I already tried " !important;"
Fingers crossed. Thx
Youā€™ll have to play with the button-card styles to bypass its aspect ratio.
Seeking help from layout-card experts =)
I did some searching in this thread but couldnā€™t find the solution Iā€™m looking for.
Iā€™m about to dig deeper in the css grid options but want to make sure Iā€™m not overengineering thisā€¦
Iā€™d like my layout to behave like
ā€œcustom:vertical-layoutā€
max_cols: 3
width: 400
but once cards reach the bottom of the screen, automatically move to the next column
and overflow at the bottom of the last column if needed.
I can do this by manually adding custom:layout-break at the bottom of each column but in order to correctly manage screen estate, I want the layout break to happen automatically based on screen size. Examples:
Large tablet
Small tablet
Cell phone
Thanks for your help!
Havenā€™t played with layout card for some time, but what youā€™re looking for is called mediaqueries. Check for it in the layout card documentation.
Thanks for the pointer,
I made some progress (below)
I defined the vertical height of the viewport to ensure columns are finite.
everything works and makes sense but the cards flow horizontally so I need to find a way to specify ā€œflex-direction: columnā€ or something equivalent.
Newbie coder so pretty sure my flex part is in the wrong spot or just plain incorrect so feel free to jump in.
thx
    layout:
      height: 90vh
      display: flex
      mediaquery:
        "(max-width: 900px)":
          grid-template-columns: 100%
        "(max-width: 1300px)":
          grid-template-columns: 50% 50%
        "(max-width: 3000px)":
          grid-template-columns: 33% 33% 1fr
found the equivalent of flex-direction for grid-layout:
ā€œgrid-auto-flowā€, thereā€™s a nice writeup here:
but best I could do is below.
Guess Iā€™m stuck with the obvious definition of a ā€œgridā€ where it ends up aligning all items to same height on each columnā€¦ would need each item in each column be directly underneath each other, and not lined upā€¦
which seems to bring me back to the ā€œvertical-layout optionā€ā€¦
would just need to figure out a way to apply custom:layout-break based on viewport height.
open to any suggestions, thx!
height: calc(100vh - var(--header-height))
grid-auto-flow: column dense
grid-template-columns: auto
grid-template-rows: repeat(6,1fr)
mediaquery:
  "(max-width: 500px)":
    grid-template-rows: repeat(20,1fr)
    grid-template-rows: repeat(5,1fr)
    grid-template-columns: 33% 33% 34%
I had the same annoying 4px margin issues. I have solved it by copying (directory: config/lovelace/www/community/lovelace-layout-card) layout-card.js to layout-card_rs.js.
Then edit layout-card_rs.js with an editor (File editor). Change ā€˜4pxā€™ or ā€˜8pxā€™ in every line with the word ā€˜marginā€™ to ā€˜0pxā€™.
After that edit the file (directory: config/) and change the line ā€˜- url: /hacsfiles/lovelace-layout-card/layout-card.jsā€™ in ā€˜- url: /hacsfiles/lovelace-layout-card/layout-card_rs.jsā€™.
Now you got rid of the annoying 4px margins and it wil not be updated anymore.
HI all,
Is there a possibility to ā€˜stretchā€™ or ā€˜reduceā€™ cards so that they fit in the grid areaā€™s and are aligned with each other ?
Iā€™m having following issue:
The two flow cards (Power Flow Now / Energy Flows (today)) are not aligned with the apexcharts-card.
Iā€™m using following grid configuration:
layout:
      grid-template-columns: 0em 74px 25% 42% 25% auto
      grid-template-rows: grid-title-row-height auto auto
      grid-gap: 0.1em
        ". . title title title ."
        ". nav line1 line1 line1 ."
        ". nav line2 line2 line2 ."
Where the two flow charts are in a horizontal-stack and the 3 gauges and apex are in a vertical-stack WITHIN that horizontal-stack
Can anyone point me in the right direction please ?
Thanks a lot in advance !
Kr,
Bart
Hello @liminal,
please excuse my cheeky question, but what are you using for cards here? Could you perhaps provide the yaml code? Thank you, looks very nice
have you tried with ā€œmargin-bottom Or margin-topā€ on the Flow-cards ?
Also , itā€™s kind of ā€œhard to imagineā€ why your columns-setup & your -areas looks as i does, when you only post the layout
Can anyone help me arrange the entities as shown below, thanks
row 1: 3 column
row 2: 2 column
95f32c981c5cbd16c38e2f5d6975be8aff1e53b3
My question is still ā€œValidā€ :wink: ā€¦ that is if you havenā€™t already figured it out, by reading some of the 730 post in here :wink:
I tried and followed the instructions here
grid-template-columns: repeat(3, 1fr)
grid-template-rows: 1fr 1fr
  "a b c"
  "d d e"
