Elja
(Elja Trum)
September 1, 2023, 6:31pm
1
I got a Google Nest Hub 2 to create a dashboard to used in my living room.
I’m having trouble using the complete screen. Perhaps someone can help?
This is my current display:
I’m pretty happy with it, but I would like an extra column to show more information.
In my Chrome browser I got it working just fine. I had a screenshot, but the forum isn’t allowing me to post more embedded images.
Some extra info:
I’m using the casting ability of Home Assistant. For the dashboard I’m using the Amoled theme to create the black background with black cards. The cards used is the excellent Flex Horsehoe Card .
The Horseshoe card is to big by default, so I’m using the Lovelace Layout Card to adjust the size. I’m also trying to use this to create the wanted layout, but I’m finding this to be pretty hard.
I’m currently using 3 custom:vertical-layout cards for the Horsecards (2 in each layout-card). Since they would stack in a single line, I’ve added 3 extra random cards and moved them around. This was the only way I could get the cards to be shown as they are now. There’s probably a better way.
Any thoughts on how I could add the third column to the Nest Hub 2?
boheme61
(JC)
September 1, 2023, 7:18pm
2
You should show/post the code of the View/dashboard you want to “show” , pasting code here have to be within 2x3 backticks, cording to point 11 in below Doc
Before we begin…
This forum is not a helpdesk
The people here don’t work for Home Assistant, that’s an open source project. We are volunteering our free time to help others. Not all topics may get an answer, never mind one that helps you solve your problem.
[image]
This also isn’t a general home automation forum, this is a forum for Home Assistant and things related to it. Any question about Home Assistant, and about using things with Home Assistant, is welcome here. We can’t help you with e…
To copy the whole View, Click the 3 dots in top-right corner, then edit then Click the 3 dots again and choose “raw configuration editor” , then click then screen And Hit ctrl+a , then ctrl+c , here you paste it with ctrl+v ( BUT don’t forget in between the 3 backticks , as shoved above
PS: there are multiple options to accomplice what you want, depending upon i.e the resolution on each device, and which View-Layout you choose etc.
Elja
(Elja Trum)
September 1, 2023, 8:04pm
4
Sure, here it is.
I’ve removed the other dashboards. Those didn’t seem relevant.
- title: Nest Hub
path: nest-hub
icon: mdi:television
subview: false
theme: amoled
badges: []
cards:
- type: custom:layout-card
layout_type: custom:vertical-layout
cards:
- type: custom:flex-horseshoe-card
entities:
- entity: sensor.p1_meter_3c39e727dc16_active_power
attribute: acculading
decimals: 0
unit: W
- entity: sensor.maxumum_voltage
attribute: Volt
decimals: 1
unit: V
icon: mdi:sine-wave
- entity: sensor.stroomverbruik_vandaag
attribute: Dagelijks
decimals: 1
unit: kWh
icon: mdi:lightning-bolt
show:
horseshoe_style: colorstop
layout:
hlines:
- id: 0
xpos: 50
ypos: 42
length: 40
styles:
- stroke: var(--primary-text-color);
- stroke-width: 5;
- stroke-linecap: round;
- opacity: 0.7;
states:
- id: 0
entity_index: 0
xpos: 50
ypos: 34
styles:
- font-size: 3em;
- id: 1
entity_index: 1
xpos: 40
ypos: 57
styles:
- text-anchor: start;
- font-size: 1.5em;
- id: 2
entity_index: 2
xpos: 40
ypos: 72
styles:
- font-size: 1.5em;
icons:
- id: 0
entity_index: 1
xpos: 37
ypos: 57
align: end
- id: 1
entity_index: 2
xpos: 37
ypos: 72
align: end
names:
- id: 0
entity_index: 0
xpos: 50
ypos: 95
horseshoe_scale:
min: -17000
max: 17000
color_stops:
'0': '#05ba49'
'1': '#ba2705'
entities:
- entity: sensor.binnen_binnen_binnen_buiten_temperature
attribute: temperature
decimals: 1
unit: °C
area: Buiten
show:
horseshoe_style: lineargradient
layout:
states:
- id: 0
entity_index: 0
xpos: 50
ypos: 60
styles:
- font-size: 3.5em;
areas:
- id: 0
entity_index: 0
xpos: 50
ypos: 35
styles:
- font-size: 1.5em;
- opacity: 0.8;
horseshoe_scale:
min: -10
max: 35
color_stops:
'21': blue
'30': red
aspect_ratio: 100%
layout:
width: 200
max_width: 300
max_cols: 1
- type: light
entity: light.dimmable_light_1
cards:
entities:
- entity: sensor.deye_sun3p_battery_capacity
decimals: 0
unit: '%'
- entity: sensor.deye_accu_beschikbaar_kwh
attribute: kWh
decimals: 1
unit: kWh
icon: mdi:battery
- entity: sensor.deye_sun3p_battery_output_power
attribute: Watt
decimals: 0
unit: W
show:
horseshoe_style: colorstopgradient
layout:
hlines:
- id: 0
xpos: 50
ypos: 42
length: 40
styles:
- stroke-width: 5;
- opacity: 0.7;
states:
- id: 0
entity_index: 0
xpos: 50
ypos: 34
styles:
- font-size: 3em;
- id: 1
entity_index: 1
xpos: 40
ypos: 57
styles:
- font-size: 1.5em;
- id: 2
entity_index: 2
xpos: 40
ypos: 72
styles:
- font-size: 1.5em;
icons:
- id: 0
entity_index: 1
xpos: 37
ypos: 57
align: end
- id: 1
entity_index: 2
xpos: 37
ypos: 72
align: end
names:
- id: 0
entity_index: 0
xpos: 50
ypos: 95
horseshoe_scale:
min: 0
max: 100
color_stops:
'0': '#0277BD'
'3000': '#FBC02D'
entities:
- entity: sensor.binnen_binnen_binnen_125_jaar_temperature
decimals: 1
unit: °C
area: SLAAPKAMER
- entity: sensor.binnen_binnen_binnen_125_jaar_co2
attribute: co2
decimals: 0
unit: ppm
area: SLAAPKAMER
icon: mdi:molecule-co2
show:
layout:
states:
- id: 0
entity_index: 0
xpos: 50
ypos: 60
styles:
- font-size: 3.5em;
- id: 1
entity_index: 1
xpos: 45
ypos: 73
styles:
- font-size: 1.5em;
icons:
- id: 1
entity_index: 1
xpos: 42
ypos: 72
align: end
areas:
- id: 0
entity_index: 0
xpos: 50
ypos: 35
styles:
- font-size: 1.5em;
- opacity: 0.8;
horseshoe_scale:
min: -10
max: 35
color_stops:
'10': '#0277BD'
'20': '#05ba49'
aspect_ratio: 100%
layout:
width: 200
max_width: 300
max_cols: 1
- type: gauge
entity: sensor.2e_overloop_battery
cards:
entities:
decimals: 0
unit: W
attribute: Volt
decimals: 1
unit: V
icon: mdi:sine-wave
- entity: sensor.stroomlevering_dagelijks
decimals: 1
unit: kWh
show:
layout:
hlines:
- id: 0
xpos: 50
ypos: 42
length: 40
styles:
- stroke-width: 5;
- opacity: 0.7;
states:
- id: 0
entity_index: 0
xpos: 50
ypos: 34
styles:
- font-size: 3em;
- id: 1
entity_index: 1
xpos: 40
ypos: 57
styles:
- font-size: 1.5em;
- id: 2
entity_index: 2
xpos: 40
ypos: 72
styles:
- font-size: 1.5em;
icons:
- id: 0
entity_index: 1
xpos: 37
ypos: 57
align: end
- id: 1
entity_index: 2
xpos: 37
ypos: 72
align: end
names:
- id: 0
entity_index: 0
xpos: 50
ypos: 95
horseshoe_scale:
min: -17000
max: 17000
color_stops:
'0': '#05ba49'
'1': '#ba2705'
entities:
decimals: 1
unit: °C
area: Buiten
show:
layout:
states:
- id: 0
entity_index: 0
xpos: 50
ypos: 60
styles:
- font-size: 3.5em;
areas:
- id: 0
entity_index: 0
xpos: 50
ypos: 35
styles:
- font-size: 1.5em;
- opacity: 0.8;
horseshoe_scale:
min: -10
max: 35
color_stops:
'21': '#0277BD'
'30': '#ba2705'
aspect_ratio: 100%
layout:
width: 200
max_width: 300
max_cols: 1
- type: gauge
entity: sensor.binnen_co2
This is how it looks in the browser (but not on the Nest Hub 2):
boheme61
(JC)
September 1, 2023, 10:22pm
5
Yes, i think this diff is caused by the fact that the vertical-stack-columns can’t fit in the resolution you have in the nest-hub, and therefore move the 3rd column down, below the first 2 ( try to reduce the width of your browser window, by dragging it from right to left, to verify whether this also will cause the 3rd to move down) PS: as now it also look odd on a bigger screen than your browser is on ( i guess it’s a ipad or small device)
as you have set the vertical-stack-card width/max width it will per automatic force this in all screen-sizes
and your “View” is masonry ( it will always “move” around cards )
If so as i said there are multiple options to avoid, either reduce the width of the columns ( might look to odd in the browser then thou ) then you could use grid or horizontal-stack(with 3 column) ( in Panel view )
What you can do is using Grid with 3 columns ( 1 for each vertical stack ) , and set
grid-template-columns: 33% 33& 33%
Elja
(Elja Trum)
September 1, 2023, 10:57pm
6
Thank you!
I tried the grid type and used fixed values, since the screen is a fixed size.
Now I’m able to get the 3 columns.
Still have some fine-tuning to do, but I am close now.
Here’s the code I’m using:
- title: Nest Hub
path: nest-hub
type: custom:grid-layout
theme: amoled
layout:
width: 1024px
margin: 0
padding: 0
card_margin: 0
grid-template-columns: 341px 341px 341px
grid-template-rows: auto
grid-template-areas: |
"block1 block2 block3"
"block4 block5 block6"
cards:
view_layout:
grid-area: block1
entities:
decimals: 0
unit: W
attribute: Volt
decimals: 1
unit: V
icon: mdi:sine-wave
decimals: 1
unit: kWh
show:
layout:
hlines:
- id: 0
xpos: 50
ypos: 42
length: 40
styles:
- stroke-width: 5;
- opacity: 0.7;
states:
- id: 0
entity_index: 0
xpos: 50
ypos: 34
styles:
- font-size: 3em;
- id: 1
entity_index: 1
xpos: 40
ypos: 57
styles:
- font-size: 1.5em;
- id: 2
entity_index: 2
xpos: 40
ypos: 72
styles:
- font-size: 1.5em;
icons:
- id: 0
entity_index: 1
xpos: 37
ypos: 57
align: end
- id: 1
entity_index: 2
xpos: 37
ypos: 72
align: end
names:
- id: 0
entity_index: 0
xpos: 50
ypos: 95
horseshoe_scale:
min: -17000
max: 17000
color_stops:
'0': '#05ba49'
'1': '#ba2705'
view_layout:
grid-area: block2
entities:
decimals: 0
unit: '%'
attribute: kWh
decimals: 1
unit: kWh
icon: mdi:battery
attribute: Watt
decimals: 0
unit: W
show:
layout:
hlines:
- id: 0
xpos: 50
ypos: 42
length: 40
styles:
- stroke-width: 5;
- opacity: 0.7;
states:
- id: 0
entity_index: 0
xpos: 50
ypos: 34
styles:
- font-size: 3em;
- id: 1
entity_index: 1
xpos: 40
ypos: 57
styles:
- font-size: 1.5em;
- id: 2
entity_index: 2
xpos: 40
ypos: 72
styles:
- font-size: 1.5em;
icons:
- id: 0
entity_index: 1
xpos: 37
ypos: 57
align: end
- id: 1
entity_index: 2
xpos: 37
ypos: 72
align: end
names:
- id: 0
entity_index: 0
xpos: 50
ypos: 95
horseshoe_scale:
min: 0
max: 100
color_stops:
'0': '#0277BD'
'3000': '#FBC02D'
view_layout:
grid-area: block3
entities:
decimals: 0
unit: W
attribute: Volt
decimals: 1
unit: V
icon: mdi:sine-wave
decimals: 1
unit: kWh
show:
layout:
hlines:
- id: 0
xpos: 50
ypos: 42
length: 40
styles:
- stroke-width: 5;
- opacity: 0.7;
states:
- id: 0
entity_index: 0
xpos: 50
ypos: 34
styles:
- font-size: 3em;
- id: 1
entity_index: 1
xpos: 40
ypos: 57
styles:
- font-size: 1.5em;
- id: 2
entity_index: 2
xpos: 40
ypos: 72
styles:
- font-size: 1.5em;
icons:
- id: 0
entity_index: 1
xpos: 37
ypos: 57
align: end
- id: 1
entity_index: 2
xpos: 37
ypos: 72
align: end
names:
- id: 0
entity_index: 0
xpos: 50
ypos: 95
horseshoe_scale:
min: -17000
max: 17000
color_stops:
'0': '#05ba49'
'1': '#ba2705'
view_layout:
grid-area: block4
entities:
decimals: 1
unit: °C
area: Buiten
show:
layout:
states:
- id: 0
entity_index: 0
xpos: 50
ypos: 60
styles:
- font-size: 3.5em;
areas:
- id: 0
entity_index: 0
xpos: 50
ypos: 35
styles:
- font-size: 1.5em;
- opacity: 0.8;
horseshoe_scale:
min: -10
max: 35
color_stops:
'21': blue
'30': red
view_layout:
grid-area: block5
entities:
decimals: 1
unit: °C
area: SLAAPKAMER
attribute: co2
decimals: 0
unit: ppm
area: SLAAPKAMER
show:
layout:
states:
- id: 0
entity_index: 0
xpos: 50
ypos: 60
styles:
- font-size: 3.5em;
- id: 1
entity_index: 1
xpos: 45
ypos: 73
styles:
- font-size: 1.5em;
icons:
- id: 1
entity_index: 1
xpos: 42
ypos: 72
align: end
areas:
- id: 0
entity_index: 0
xpos: 50
ypos: 35
styles:
- font-size: 1.5em;
- opacity: 0.8;
horseshoe_scale:
min: -10
max: 35
color_stops:
'10': '#0277BD'
'20': '#05ba49'
view_layout:
grid-area: block6
entities:
decimals: 1
unit: °C
area: SLAAPKAMER
attribute: co2
decimals: 0
unit: ppm
area: SLAAPKAMER
show:
layout:
states:
- id: 0
entity_index: 0
xpos: 50
ypos: 60
styles:
- font-size: 3.5em;
- id: 1
entity_index: 1
xpos: 45
ypos: 73
styles:
- font-size: 1.5em;
icons:
- id: 1
entity_index: 1
xpos: 42
ypos: 72
align: end
areas:
- id: 0
entity_index: 0
xpos: 50
ypos: 35
styles:
- font-size: 1.5em;
- opacity: 0.8;
horseshoe_scale:
min: -10
max: 35
color_stops:
'10': '#0277BD'
'20': '#05ba49'
boheme61
(JC)
September 1, 2023, 11:11pm
7
Nice , looks cool now keep playing around
Elja
(Elja Trum)
September 3, 2023, 8:48pm
8
So, six of these cards in this size don’t fit that good on a Nest Hub.
I changed out the bottom cards for some Mini Graph Cards .
Tried getting my family calender (the upcoming 3 events) on one of the tiles, but haven’t got that working yet.
Here’s the code for this layout:
- title: Nest Hub
path: nest-hub
theme: amoled
layout:
width: 1024px
grid-template-rows: 300px 50px 250px
"spacer spacer spacer"
cards:
- type: custom:button-card
color_type: blank-card
view_layout:
grid-area: spacer
view_layout:
grid-area: block1
entities:
decimals: 0
unit: W
attribute: Volt
decimals: 1
unit: V
icon: mdi:sine-wave
decimals: 1
unit: kWh
show:
layout:
hlines:
- id: 0
xpos: 50
ypos: 42
length: 40
styles:
- stroke-width: 5;
- opacity: 0.7;
states:
- id: 0
entity_index: 0
xpos: 50
ypos: 34
styles:
- font-size: 3em;
- id: 1
entity_index: 1
xpos: 40
ypos: 57
styles:
- font-size: 1.5em;
- id: 2
entity_index: 2
xpos: 40
ypos: 72
styles:
- font-size: 1.5em;
icons:
- id: 0
entity_index: 1
xpos: 37
ypos: 57
align: end
- id: 1
entity_index: 2
xpos: 37
ypos: 72
align: end
names:
- id: 0
entity_index: 0
xpos: 50
ypos: 95
horseshoe_scale:
min: -17000
max: 17000
color_stops:
'0': '#05ba49'
'1': '#ba2705'
view_layout:
grid-area: block2
entities:
decimals: 0
unit: '%'
attribute: kWh
decimals: 1
unit: kWh
icon: mdi:battery
attribute: Watt
decimals: 0
unit: W
show:
layout:
hlines:
- id: 0
xpos: 50
ypos: 42
length: 40
styles:
- stroke-width: 5;
- opacity: 0.7;
states:
- id: 0
entity_index: 0
xpos: 50
ypos: 34
styles:
- font-size: 3em;
- id: 1
entity_index: 1
xpos: 40
ypos: 57
styles:
- font-size: 1.5em;
- id: 2
entity_index: 2
xpos: 40
ypos: 72
styles:
- font-size: 1.5em;
icons:
- id: 0
entity_index: 1
xpos: 37
ypos: 57
align: end
- id: 1
entity_index: 2
xpos: 37
ypos: 72
align: end
names:
- id: 0
entity_index: 0
xpos: 50
ypos: 95
horseshoe_scale:
min: 0
max: 100
color_stops:
'0': '#0277BD'
'3000': '#FBC02D'
view_layout:
grid-area: block3
entities:
- entity: sensor.binnen_temperature
attribute: Temperatuur
decimals: 1
unit: °C
- entity: sensor.binnen_humidity
attribute: humidity
decimals: 0
unit: '%'
icon: mdi:water-percent
- entity: sensor.binnen_co2
attribute: PPM
decimals: 0
unit: PPM
show:
layout:
hlines:
- id: 0
xpos: 50
ypos: 42
length: 40
styles:
- stroke-width: 5;
- opacity: 0.7;
states:
- id: 0
entity_index: 0
xpos: 50
ypos: 34
styles:
- font-size: 3em;
- id: 1
entity_index: 1
xpos: 40
ypos: 57
styles:
- font-size: 1.5em;
- id: 2
entity_index: 2
xpos: 40
ypos: 72
styles:
- font-size: 1.5em;
icons:
- id: 0
entity_index: 1
xpos: 37
ypos: 57
align: end
- id: 1
entity_index: 2
xpos: 37
ypos: 72
align: end
names:
- id: 0
entity_index: 0
xpos: 50
ypos: 95
horseshoe_scale:
min: 10
max: 35
color_stops:
'10': '#0277BD'
'20': '#ba9a05'
- type: custom:mini-graph-card
view_layout:
grid-area: block4
entities:
- sensor.binnen_binnen_binnen_buiten_temperature
hours_to_show: 48
points_per_hour: 2
font_size: 160
font_size_header: 20
color_thresholds:
- value: 0
color: 0277BD
- value: 16
color: '#f39c12'
- value: 20
color: '#d35400'
- value: 25
color: '#c0392b'
view_layout:
grid-area: block5
entities:
- sensor.binnen_co2
font_size: 160
hours_to_show: 24
points_per_hour: 2
view_layout:
grid-area: block6
entities:
- entity: sensor.binnen_noise
color: green
icon: mdi:volume-high
font_size: 160
hours_to_show: 24
points_per_hour: 2
