I’d like to share something I really got used to when I am home alone. You all know this situation when you start a movie on your television in the livingroom and suddenly you realize that your snacks are still in the kitchen so you press pause on the remote, grab your snacks and return to the livingroom and press play again just until your realize that your beer is still in the kitchen so you press pause and grab your beer and get back to the livingroom and press play… you get the idea.
I’ve turned most of my media players into presence and state aware devices. When media is playing and I leave the room the media automatically stops and resumes as soon as I return to the room. Here is how I did this and what you need on the hardware side:
Every of my rooms is equipped with a motion sensor. In my case:
- binary_sensor.hue_motion_flur
- binary_sensor.hue_motion_wohnzimmer
- binary_sensor.hue_motion_kueche
- binary_sensor.hue_motion_room2
- binary_sensor.hue_motion_schlafzimmer
So the first step to get hass to know in which room you currently are is to create a sensor that sets it’s state to the name of the room where the last motion was triggered. I use a custom integration named home-assistant-variables for this. It is avaiable in HACS. So here is the automation:
- alias: Set Last Motion Variable
initial_state: True
- platform: state
entity_id:
to: 'on'
- service: variable.set_variable
variable: last_motion
attributes_template: >
"history_1": "{{ variable.state }}",
"history_2": "{{ variable.attributes.history_1 }}",
"history_3": "{{ variable.attributes.history_2 }}"
data_template:
value: >
{% if trigger.entity_id == "binary_sensor.hue_motion_flur" %} Flur
{% elif trigger.entity_id == "binary_sensor.hue_motion_kueche" %} Küche
{% elif trigger.entity_id == "binary_sensor.hue_motion_room2" %} Room2
{% elif trigger.entity_id == "binary_sensor.hue_motion_schlafzimmer" %} Schlafzimmer
{% elif trigger.entity_id == "binary_sensor.hue_motion_wohnzimmer" %} Wohnzimmer
{% endif %}
The next step is to create a template sensor that reads the state of the newly set variable and displays a corresponding mdi:icon that represents the rooms:
sensors:
last_motion:
friendly_name: 'Wo bims?'
value_template: "{{ states.variable.last_motion.state }}"
icon_template: >-
{% if is_state('variable.last_motion', 'Küche') %}
mdi:food-variant
{% elif is_state('variable.last_motion', 'Wohnzimmer') %}
mdi:sofa
{% elif is_state('variable.last_motion', 'Flur') %}
mdi:cube-unfolded
{% elif is_state('variable.last_motion', 'Room2') %}
mdi:guitar-electric
{% elif is_state('variable.last_motion', 'Schlafzimmer') %}
mdi:hotel
{% else %}
mdi:account-question
{% endif %}
Fine! Now you have a sensor that shows in which room you are currently in. Now comes the fun part. For the following example I’ll use my Kodi media_player (media_player.beelink
) that is in my livingroom (Wohnzimmer in german). Here is the basic automation that automatically pauses and resumes Kodi based on room presence:
- alias: Kodi Auto Pause
initial_state: True
- platform: state
entity_id: sensor.last_motion
condition:
- condition: state
entity_id: input_boolean.besuchermodus
state: 'off'
- service_template: >
{% if not is_state("sensor.last_motion", "Wohnzimmer") and is_state("media_player.beelink", "playing") %}
media_player.media_pause
{% elif is_state("sensor.last_motion", "Wohnzimmer") and is_state("media_player.beelink", "paused") %}
media_player.media_play
{% endif %}
entity_id: media_player.beelink
As you can see I am using a condition based on an input_boolean
called input_boolean.besuchermodus
(Besucher means visitor/guest in german). This is a boolean I manually trigger when there are more than one person at home. I strongly advise you to do the same because if multiple persons are in your house they aren’t necessarly in one room and the automation would cause inconvenience if someone is watching a movie.
Have fun trying it out. If anyone has an idea how to replace the custom variable integration to create the last motion sensor please let me know. There is probably a better solution out there for this sensor.
