Lazy Spa - Node Red Set Temp
Hi. Hoping someone can help.
I am using the wifi module from HotTubManager on my Lazy spa hot tub. Its all hooked up via MQTT and i can control all of it via the HA dashboard.
I am looking to use Node Red to have a more flexible power up , turn heating on etc.
The entity is
number.hottubmanager_target_temperature
In developer tools i can set the target temp and all good, I am struggling to do the same thing via Node Red. Any suggestions?
min: 20
max: 40
step: 1
mode: slider
unit_of_measurement: oC
device_class: temperature
icon: mdi:thermometer
friendly_name: hottubmanager7D Target Temperature
Can you please post your node red code?
Since the entity is in HA already you can use a call service with number for the domain and set_value for the service.
Thank you so much. that has worked perfectly.
really appreciate the reply
