LCN Cover Plattform
HI,
i try to configure the LCN Coverplattform, but have an issues with the direction of the covers.
if i press down - the cover goes up, if i press up, the cover goes down - is it possible to change this behavior?
many thanks
Christian
Hi tango38317,
please check your cover wiring. It has to be exactly as given in the manufacturer documentation for the LCN-R8H or LCN-R4M2H. I rechecked everything on my side. Seems to be ok.
The R4M2H has some builtin leds in the housing. They also show the right state when switching.
If you have the possibility, send up/down commands via LCN-Pro software to check if your wiring is inverted.
If everything fails and you are not able to change the wiring, you could use the template cover platform in combination with the LCN cover or switch platform to setup a custom cover behaviour.
Andre
Hi alengwenus,
many thanks for you tips. you are right - i have tested the cover with LCN-Pro software and its inverted.
many thanks
Christian
@alengwenus,
i have seen you have implemented the lcn-sensor plattform. i don´t know hot to get motion detection running. is motion detection already implemented?
br
Christian
For motion detection you need to monitor the binary ports. For this there is the binary_sensor platform which I also implemented and which already has been merged to the dev branch. I guess it will be available with the next HA release.
Andre
The LCN binary_sensor platform is available, now.
@tango38317: Have a look at Home Assistant v0.92.0
Good Morning @alengwenus;
many thanks for your good work :slight_smile:
