connections:
- name: myLCN
host: 192.168.8.13
port: 4114
username: lcn
password: !secret lcn_password
looks ok from what i can tell
connections:
- name: myLCN
host: 192.168.8.13
port: 4114
username: lcn
You have to use the same host in the address
as defined in the connections
Form what you wrote the correct address for your cover should be myLCN.s0.m7
(not myhome
I implemented this for a test some time ago, but found it very unreliable. Therefore, I didnāt see any real benefit and removed it again.
Hi @alengwenus,
does it mean thereās no option to contol tilt positions using Shutter position command like in LCN-PRO? If I set proper timing configuration for each cover in LCN-PRO it seems to work pretty well. So having an option to set blade angle sounds resonable to me? Doing it using only full open/close and stop option is unmanagable. I know I could set a button in LCN pro and call it using send_keys but thatās a bit poor if comes to reconfigurations etc.
So Iād really opt for having support for shutter position options set height/set blade angle and other. What do you think?
Best regards,
K.M.
