LCN integration: DALI
Hello!
Does anyone know is it possible to address DALI LCN devices in HA?
A log string for example:
12:10:38:825 - M036 0-fl/entrance → M039 0-fl/cinema DALI broadcast: off
Thank you!
Hi @andreytel,
DALI commands are not natively supported by the LCN integration. With some effort you could use the general PCK service call and send one of the DALI specific PCK commands. Using the PCK service call in combination with automations or the Template integration one can already achieve a lot at the expense of high configuration effort. I guess you also need some deeper knowledge to the DALI specific teminology.
To my knowledge there are two PCK commands, which deal with DALI and can be used here:
Unfortunately I can’t support you with the PCK command itself as I do not employ DALI in my setup.
