Dear Commuity,
I installed the LCN-integration and everything works very fine. With one exception:
Using entity-dialog I changed the Icon and seted the Area of an LCN-entity.
I saved it and the entity-overwiew (listview) showed every change.
After rebooting the system, all changes are gone.
I tested changing an LCN-icon/area and a Synology-icon/area simultaneously.
After rebooting, the Synology-icon/area are present, the LCN-icon/area are gone.
In both cases, via LCN-entity-dialogue created new areas are still present.
Only the linkage to the LCN-entity is gone.
Any idea about this? Would be very thankful for any advice of you
System
=> Raspberry Pi with SSD (no SD-Card)
=> Installed this way: Raspberry Pi - Home Assistant
Regards from germany
Lars
