Hi there,
i am trying to integrate LCN devices to HA: i send temperature values from third party sensors to LCN with the help of automations. i configured the variables as counters in LCN. And most of the time the automation stops with an error “wrong variable type”. But not all the time. Sometimes it manages to send the values. I also tried to send direct values in celcius, in native units (like 1250), most of the time i get an error. I noticed in the log, that LCN integration sends LCN.var_reset command by itself, that may cause the error. Thank you!
alias: LCN children bedroom_temp
description: ""
- platform: state
entity_id: sensor.temp_children_bedroom_temperature
condition: []
- service: lcn.var_abs
address: myhome.s0.m136
variable: var10
value: "{{temp}}"
unit_of_measurement: °C
mode: single
variables:
temp: "{% set temp = states('sensor.temp_children_bedroom_temperature') %}{{temp}}"
the debug log with an error is here:
2023-01-11 11:58:49.570 ERROR (MainThread) [homeassistant.components.automation.lcn_children_bedroom_temp] While executing automation automation.lcn_children_bedroom_temp
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 546, in async_trigger
await self.action_script.async_run(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1524, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 409, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 453, in _async_step
self._handle_exception(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 476, in _handle_exception
raise exception
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 451, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 684, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1755, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1792, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/components/lcn/services.py", line 211, in async_call_service
await device_connection.var_abs(var, value, unit)
File "/usr/local/lib/python3.10/site-packages/pypck/module.py", line 412, in var_abs
not self.is_group, PckGenerator.var_reset(var, software_serial)
File "/usr/local/lib/python3.10/site-packages/pypck/pck_commands.py", line 690, in var_reset
raise ValueError("Wrong variable type.")
ValueError: Wrong variable type.
