LD21410 + ceiling fan. How to exclude detection distance range
I have an LD2410 connected to an ESP32 in a room with a ceiling fan. I’m using the ld2410 to detect presence and from there manage lighting.
When the fan is running, detection_distance consistently hovers between 348-352.
Can anyone give me pointers to how I can configure the device in ESPHome such that any time the detection distance is between the two numbers, the has_target binary sensor reports as clear?
Answering my own question for anyone else looking for a solution. Occupancy is now based on state of binary_sensor.study_mmwave_fudged_presence:
uart:
  tx_pin: GPIO1
  rx_pin: GPIO3
  baud_rate: 256000
  parity: NONE
  stop_bits: 1
ld2410:
  uart_id: ld2410_uart
binary_sensor:
  - platform: ld2410
    has_target:
    has_moving_target:
    has_still_target:
    lambda: !lambda |-
      if (id(presence).state && id(detection_distance).state >339 && id(detection_distance).state < 361) {
        return 0;
      } else {
        return id(presence).state;
  - platform: ld2410
    moving_distance:
    still_distance:
    moving_energy:
    still_energy:
    detection_distance:
number:
  - platform: ld2410
    timeout:
    max_move_distance_gate:
      name: max move distance gate
    max_still_distance_gate:
      name: max still distance gate
Hi, @whingingpom , glad to find your thread! Ive faced this problem all the time since the beginning i used this ld2410, and its quite hard to fine tuning my room with wall fan :disappointed_relieved:
Anyway can you please kindly teach me how you define the value inside you lamdba condition? Maybe a little decription about your noisy fan distance in your room will be help me to define mine.
Thanks!
Neat idea.
If you don’t mind, I’ve enhanced this exlusion feature by making the begin and end of the exclusion distance configurable.
Here is what you need to do to implement it:
Add the id values to the following existing entities:
number:
  - platform: ld2410
    timeout:
binary_sensor:
  - platform: ld2410
    has_target:
  - platform: ld2410
    detection_distance:
      name: "Distance Detection (cm)"
Then add the following:
number:
    min_value: 0
    max_value: 900
    mode: box
    device_class: distance
    entity_category: config
    unit_of_measurement: cm
    icon: mdi:arrow-right-bold
    step: 1
    optimistic: True
    initial_value: 0
    restore_value: True
    min_value: 0
    max_value: 900
    mode: box
    icon: mdi:arrow-left-bold
    step: 1
    optimistic: True
    initial_value: 0
    restore_value: True
binary_sensor:
    name: Presence with Exclusion
    device_class: occupancy
    filters:
      - delayed_off: !lambda |-
          return id(timeout).state * 1000.0;
    lambda: !lambda |-
      if (id(presence).state && id(detection_distance).state >= id(ex_start).state && id(detection_distance).state <= id(ex_end).state) {
        return 0;
      } else {
@athua @whingingpom
Thanks for your implementation to exclude the ceiling fan. I just tried it and it worked for my room
If you don’t mind me asking:
  1. What’s the optimal location to position the sensor in a room? Before this I’ve only been using this in bathroom where it’s just mounted on the ceiling
  2. i haven’t really followed up with the other variants of ld2410. Is the ld2411s a better version with more antennas?
