LD2410 BLE custom password support
The Hi-Link LD2410 BLE should support a custom password as the current implementation will force users to keep the original (standard) password, which is quite fragile, allowing any neighbour (or someone walking by the street) to change the passwords and break my integrations (if not making the sensors unusable).
It appears to be in the next version of the underlying library
Unfortunately I couldn’t find this in the change log of v2023.3. :weary:
Hello, this is Annie from Hi-Link. I consulted our technicist and got the solution as follows. You can try this command to set the Bluetooth control password. The configuration value is not lost after a power failure and takes effect after the module is restarted.
We will need also this supported by Home Assistant.
