LD2410 BLE not being re-discovered
I’ve added a bluetooth proxy and a HLK-LD2410’s to my setup to experiment with presence detection. The initial setup worked like a charm, the proxy and the LD2410 were automagically added and it seemed to be working flawlessly :slight_smile:
However after a while the presence detection sensor reported unavailable even though the proxy and the LD2410 were immediately adjacent to one another, so couldn’t see that it was a range thing.
I decided to delete the integration from the UI and re-add the device. I unplugged the 2410, restarted Home Assistant but alas it was no auto-discovered. So I tried to manually add the integration, but was presented with a " LD2410 BLE - No unconfigured devices found." message.
I’m unable to locate any existing devices or entities associated with the LD2410 BLE integration and unable to add a new. Its like the previous instantiation has been tidied up and is preventing it being added again, but I can’t find any evidence of this.
Can anyone offer any advice?
TIA
UPDATE - The simplest solution to this problem I come up is was just create a new BT proxy and disabling the old one. The LD2410’s were automatically discovered and operating as expected. Possibly not the most elegant solution, but it worked.
Restart proxy not work ?
Unplugging / plugging in the proxy was the first thing I tried, but it did not solve the issue.
LD2410 BLE
No devices found on the network
any configuration yaml for this?
Thanks for your response, but the issue was resolved as per my post on the 26th.
There is no YAML for the LD2410 BLE, its natively supported by by home assistant and is auto discovered and configured via Bluetooth connection, in my instance via BT Proxy
I too have this problem. My house has multiple BLE proxies and coverage is not an issue with plenty of slots available. I have been experimenting with the LD2410’s in both ESPHOME Uart via ESP32 and standalone BLE modes.
When I restart HA, the LD2410 BLE’s often become permanentky unavailable. If I delete them and restart HA again they all just get rediscovered and work.
Im struggling to see that this is a BLE issue, wondering if anyone can shed some light on this rather than blaming the chinesium sensor or the BLE environment.
guidance appreciated thanks.
I am too having this problem, but a bit worse even. I was able to add an LD2410 thru a test Bluetooth proxy a while back, with an older version of Home Assistant. Fast forward a few versions of HA and this thing became unavailable. I tried creating a new proxy, it saw the LD2410, but it would never add it to the devices; it would spit out an error that something went wrong, and to try again. Any ideas? I like the sensor’s size and it worked great while it worked.
Having exactly the same issue. Had three LD 2410 configured but after a year one will not connect. Removed from configuration (deleted) and after a HA restart it see the device but will not connect.
Hi. I just want to share my experience, maybe someone will find it helpful. I had an LD2410C (bluetooth) connected just fine with smartphone but, tring to connect to home assistant with its integration LD2410 BLE give me the error: “no device found on the network”. The solution was to disable the passive scannig from bluetooth integration.
+1 work for me!
The LD2410C then immediately popped-up as a discovered device and although on the first attempt to connect/configure it failed for an, “unknown reason”, I immediately tried again and was fine.
Not for me… I just tried get a LD2410C device up and running. It is detected in the Bluetooth Advertisement Monitor, but not detected as a new device by HA. Also not by adding an integration and selecting LD2410 BLE. No devices found.
I have several Bluetooth Proxies, 5 Shelly devices, 2 ESP32 ESPHome Bluetooth Proxies (one about 1 meter away from the LD2410C). No passive scanning is active, all proxies show active mode.
I restarted HA and also played around with active/passive. Also no phone (app) is connected to the LD2410C.
What am I missing here?
