LD2410 - Can't enable Engineering mode
I have an ESP32 with two LD2410C connected via UART.
Now one of them totally works, but for the other one (S2 in my config), only the binary sensors work, the rest (Engineering Mode, gate values, timeout, max still(/moving gate) doesn’t work…
How could I fix this?
My config is the following:
esphome:
  friendly_name: ld2410-esp32-01
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
  level: DEBUG
  baud_rate: 0
# Enable Home Assistant API
api:
  encryption:
    key: "IArm3ZGuqL1HLZXXbu4/L0ciw1TDSagu6THKP8LnFdo="
ota:
  - platform: esphome
    password: "3373716c7967d461cf4bd0ce1ba42e9a"
wifi:
  networks:
  - ssid: !secret wifi_ssid
  power_save_mode: NONE
  ap:
    ssid: "Ld2410-Esp32 Fallback Hotspot"
    password: "AhxmD317i7r1"
captive_portal:
uart:
  - id: ld2410_uart
    tx_pin: 26
    rx_pin: 32
    baud_rate: 256000
    parity: NONE
    stop_bits: 1
  - id: ld2410_uart_2
    tx_pin: 21
    rx_pin: 25
    baud_rate: 256000
    parity: NONE
    stop_bits: 1
ld2410:
  - uart_id: ld2410_uart
    throttle: 1000ms
  - uart_id: ld2410_uart_2
    throttle: 1000ms
select:
  - platform: ld2410
    ld2410_id: ld2410_comp
    distance_resolution:
      name: S1 distance resolution
  - platform: ld2410
    ld2410_id: ld2410_comp_2
      name: S2 distance resolution
button:
  - platform: restart
  - platform: ld2410
    factory_reset:
      name: "S1 factory reset"
    restart:
    query_params:
      name: S1 query params
  - platform: ld2410
    factory_reset:
      name: "S2 factory reset"
    restart:
    query_params:
      name: S2 query params
number:
  - platform: ld2410
    timeout:
      mode: box
    max_move_distance_gate:
      name: S1 max move distance gate
      mode: box
    max_still_distance_gate:
      name: S1 max still distance gate
      mode: box
    g0:
      move_threshold:
        name: S1 g0 move threshold
        mode: box
      still_threshold:
        name: S1 g0 still threshold
        mode: box
    g1:
      move_threshold:
        name: S1 g1 move threshold
        mode: box
      still_threshold:
        name: S1 g1 still threshold
        mode: box
    g2:
      move_threshold:
        name: S1 g2 move threshold
        mode: box
      still_threshold:
        mode: box
        name: S1 g2 still threshold
    g3:
      move_threshold:
        name: S1 g3 move threshold
        mode: box
      still_threshold:
        name: S1 g3 still threshold
        mode: box
    g4:
      move_threshold:
        name: S1 g4 move threshold
        mode: box
      still_threshold:
        name: S1 g4 still threshold
        mode: box
    g5:
      move_threshold:
        name: S1 g5 move threshold
        mode: box
      still_threshold:
        name: S1 g5 still threshold
        mode: box
    g6:
      move_threshold:
        name: S1 g6 move threshold
        mode: box
      still_threshold:
        name: S1 g6 still threshold
        mode: box
    g7:
      move_threshold:
        name: S1 g7 move threshold
        mode: box
      still_threshold:
        name: S1 g7 still threshold
        mode: box
    g8:
      move_threshold:
        name: S1 g8 move threshold
        mode: box
      still_threshold:
        name: S1 g8 still threshold
        mode: box
  - platform: ld2410
    timeout:
      mode: box
      name: S2 max move distance gate
      mode: box
      name: S2 max still distance gate
      mode: box
    g0:
      move_threshold:
        name: S2 g0 move threshold
        mode: box
      still_threshold:
        name: S2 g0 still threshold
        mode: box
    g1:
      move_threshold:
        name: S2 g1 move threshold
        mode: box
      still_threshold:
        name: S2 g1 still threshold
        mode: box
    g2:
      move_threshold:
        name: S2 g2 move threshold
        mode: box
      still_threshold:
        name: S2 g2 still threshold
        mode: box
    g3:
      move_threshold:
        name: S2 g3 move threshold
        mode: box
      still_threshold:
        name: S2 g3 still threshold
        mode: box
    g4:
      move_threshold:
        name: S2 g4 move threshold
        mode: box
      still_threshold:
        name: S2 g4 still threshold
        mode: box
    g5:
      move_threshold:
        name: S2 g5 move threshold
        mode: box
      still_threshold:
        name: S2 g5 still threshold
        mode: box
    g6:
      move_threshold:
        name: S2 g6 move threshold
        mode: box
      still_threshold:
        name: S2 g6 still threshold
        mode: box
    g7:
      move_threshold:
        name: S2 g7 move threshold
        mode: box
      still_threshold:
        name: S2 g7 still threshold
        mode: box
    g8:
      move_threshold:
        name: S2 g8 move threshold
        mode: box
      still_threshold:
        name: S2 g8 still threshold
        mode: box
switch:
  - platform: ld2410
    engineering_mode:
      name: "S1 engineering mode"
    bluetooth:
      name: S1 control Bluetooth
  - platform: ld2410
    engineering_mode:
      name: "S2 engineering mode"
    bluetooth:
      name: S2 control Bluetooth
  - platform: ld2410
    moving_distance:
      name: "S1 Moving distance (cm)"
    still_distance:
      name: "S1 Still Distance (cm)"
    moving_energy:
      name: "S1 Move Energy (%)"
    still_energy:
      name: "S1 Still Energy (%)"
    detection_distance:
      name: "S1 Distance Detection (cm)"
    g0:
      move_energy:
        name: S1 g0 move energy
      still_energy:
        name: S1 g0 still energy
    g1:
      move_energy:
        name: S1 g1 move energy
      still_energy:
        name: S1 g1 still energy
    g2:
      move_energy:
        name: S1 g2 move energy
      still_energy:
        name: S1 g2 still energy
    g3:
      move_energy:
        name: S1 g3 move energy
      still_energy:
        name: S1 g3 still energy
    g4:
      move_energy:
        name: S1 g4 move energy
      still_energy:
        name: S1 g4 still energy
    g5:
      move_energy:
        name: S1 g5 move energy
      still_energy:
        name: S1 g5 still energy
    g6:
      move_energy:
        name: S1 g6 move energy
      still_energy:
        name: S1 g6 still energy
    g7:
      move_energy:
        name: S1 g7 move energy
      still_energy:
        name: S1 g7 still energy
    g8:
      move_energy:
        name: S1 g8 move energy
      still_energy:
        name: S1 g8 still energy
  - platform: ld2410
    moving_distance:
      name: "S2 Moving distance (cm)"
    still_distance:
      name: "S2 Still Distance (cm)"
    moving_energy:
      name: "S2 Move Energy (%)"
    still_energy:
      name: "S2 Still Energy (%)"
    detection_distance:
      name: "S2 Distance Detection (cm)"
    g0:
      move_energy:
        name: S2 g0 move energy
      still_energy:
        name: S2 g0 still energy
    g1:
      move_energy:
        name: S2 g1 move energy
      still_energy:
        name: S2 g1 still energy
    g2:
      move_energy:
        name: S2 g2 move energy
      still_energy:
        name: S2 g2 still energy
    g3:
      move_energy:
        name: S2 g3 move energy
      still_energy:
        name: S2 g3 still energy
    g4:
      move_energy:
        name: S2 g4 move energy
      still_energy:
        name: S2 g4 still energy
    g5:
      move_energy:
        name: S2 g5 move energy
      still_energy:
        name: S2 g5 still energy
    g6:
      move_energy:
        name: S2 g6 move energy
      still_energy:
        name: S2 g6 still energy
    g7:
      move_energy:
        name: S2 g7 move energy
      still_energy:
        name: S2 g7 still energy
    g8:
      move_energy:
        name: S2 g8 move energy
      still_energy:
        name: S2 g8 still energy
binary_sensor:
  - platform: ld2410
    has_target:
    has_moving_target:
      name: S1 Moving Target
    has_still_target:
      name: S1 Still Target
  - platform: ld2410
    has_target:
    has_moving_target:
      name: S2 Moving Target
    has_still_target:
      name: S2 Still Target
Best regards
Aaron
The binary sensor is not using the uart, so it seems the second uart is not working. First steps for me would be see if reversing rx/tx works, also check the pinout to make sure the pins are what you think they are. The right documentation of the board is viatal.
I only have the UART converted…
What you meant was the OUT pin, but that isn’t connected in my setup…
I can even toggle Bluetooth on/off and set the gate thresholds, but I can’t enable Engineering Mode and thus can’t read the current gate values…
I think its a firmware problem I am having the same issues
