Can you test it with a serial to usb adapter and a computer?
Have you crossed the TX and RX connections?
Does the digital output work as expected?
Are you powering it up with 5V?
I think you have to disable serial logging in the yaml configuration.
@lukcz Unfortunately I cannot use 1 and 3 as it is already in use by a Particulate Matter sensor… I can only use the pins on the outer rows as show in the pinout picture above.
Is it a typo or you had to connect RX to RX and TX to TX? That should not work as the have to be inverted… Either way, I always test both ways in case the documentation is bad or whatever else
I tried using a different Wemos D1 Mini 32 and LC2410C with reduced code configured to use the hardware UART on the D1 Mini 32, which should handle the 256000 baud unlike the other pins (from what I’ve read)… but it appears to crash immediately as I get no logs and HA doesn’t even discover it. As soon as I remove all the LD2410 code, it is discovered just fine. While, on the other setup with the same type of board, it doesn’t crash it but simply won’t work.
On a side note, I had the sensor working using an ESP32 S2 Mini and the native HA integration but unfortunately I cannot use that board in this device due to pinout (it was designed for an 8266). I therefore wanted to try the custom component by rain931215 because it allows to use slower baud rates which I assumed would help with making this work on pins other than the hardware UART. The native integration seems to require 256000 (I get an error saying it has to be 256000 if I try anything else).
I have ld2410b sensors that I update to version 2.04.23022511 through the HLKRadar-Tool application, but I also have some ld2410 without bluetooth that are at version 1.07.22082218 and I don’t know how I can take them to version 2.04…
There are some interesting cases regarding ld2410 without suffixes:
It and the ld2410b seem to have just a number of components missing in hardware, but the chips are almost identical.
Its OP seems to have updated firmware capability at the moment.
And the ld2410b(c)'s firmware update capability no doubt comes from the Bluetooth serial port as well. So the ld2410 should have the ability to update firmware, but it’s quite a hassle and hilink doesn’t seem to be open to ways of doing so.
We sent an issue to hilink on this issue to see how they answer the question.
@carltonb 1.27mm pin spacing, but from what I have read, it looks like connectors with 1.25mm spacing seem to work too. I have seen reports of several different connector variants used by people.
I don’t know what I have done incorrectly. I just copy the LD2410 official code and change my credential settings, but it doesn’t work. It would show a few state changes, then it stopped. No more response. It seems the LD2410 just burn out. I’ve tried 2 new LD2410.
I will not be using the native code but the custom component route. I will test the 2 ‘burnt’ LD2410 on the custom component when I get the chance later on down.
I came across this code in this thread some time ago. I have tried to use it but it comes up with all kind of issues.
So what i am asking is, is it possible to use this code in esphome or do I need to install one of the beta or dev branches of esphome to use it? Or is there something else I am missing?
well I just quickly threw in the code and this comes out in the logs.
INFO Reading configuration /config/esphome/testradar.yaml...
Failed config
ld2410: [source /config/esphome/testradar.yaml:40]
- uart_id: ld2410_uart
[throttle] is an invalid option for [0]. Please check the indentation.
throttle: 1500ms
binary_sensor.ld2410: [source /config/esphome/testradar.yaml:45]
platform: ld2410
has_target:
has_moving_target:
has_still_target:
[out_pin_presence_status] is an invalid option for [binary_sensor.ld2410]. Please check the indentation.
out_pin_presence_status:
name: out pin presence status
sensor.ld2410: [source /config/esphome/testradar.yaml:56]
platform: ld2410
[light] is an invalid option for [sensor.ld2410]. Please check the indentation.
light:
moving_distance:
still_distance:
moving_energy:
still_energy:
detection_distance:
[g0_move_energy] is an invalid option for [sensor.ld2410]. Did you mean [moving_energy]?
g0_move_energy:
name: g0 move energy
[g0_still_energy] is an invalid option for [sensor.ld2410]. Did you mean [still_energy]?
g0_still_energy:
name: g0 still energy
[g1_move_energy] is an invalid option for [sensor.ld2410]. Did you mean [moving_energy]?
g1_move_energy:
name: g1 move energy
[g1_still_energy] is an invalid option for [sensor.ld2410]. Did you mean [still_energy]?
g1_still_energy:
name: g1 still energy
[g2_move_energy] is an invalid option for [sensor.ld2410]. Did you mean [moving_energy]?
g2_move_energy:
name: g2 move energy
[g2_still_energy] is an invalid option for [sensor.ld2410]. Did you mean [still_energy]?
g2_still_energy:
name: g2 still energy
[g3_move_energy] is an invalid option for [sensor.ld2410]. Did you mean [moving_energy]?
g3_move_energy:
name: g3 move energy
[g3_still_energy] is an invalid option for [sensor.ld2410]. Did you mean [still_energy]?
g3_still_energy:
name: g3 still energy
[g4_move_energy] is an invalid option for [sensor.ld2410]. Did you mean [moving_energy]?
g4_move_energy:
name: g4 move energy
[g4_still_energy] is an invalid option for [sensor.ld2410]. Did you mean [still_energy]?
g4_still_energy:
name: g4 still energy
[g5_move_energy] is an invalid option for [sensor.ld2410]. Did you mean [moving_energy]?
g5_move_energy:
name: g5 move energy
[g5_still_energy] is an invalid option for [sensor.ld2410]. Did you mean [still_energy]?
g5_still_energy:
name: g5 still energy
[g6_move_energy] is an invalid option for [sensor.ld2410]. Did you mean [moving_energy]?
g6_move_energy:
name: g6 move energy
[g6_still_energy] is an invalid option for [sensor.ld2410]. Did you mean [still_energy]?
g6_still_energy:
name: g6 still energy
[g7_move_energy] is an invalid option for [sensor.ld2410]. Did you mean [moving_energy]?
g7_move_energy:
name: g7 move energy
[g7_still_energy] is an invalid option for [sensor.ld2410]. Did you mean [still_energy]?
g7_still_energy:
name: g7 still energy
[g8_move_energy] is an invalid option for [sensor.ld2410]. Did you mean [moving_energy]?
g8_move_energy:
name: g8 move energy
[g8_still_energy] is an invalid option for [sensor.ld2410]. Did you mean [still_energy]?
g8_still_energy:
name: g8 still energy
switch.ld2410: [source /config/esphome/testradar.yaml:107]
Platform not found: 'switch.ld2410'.
platform: ld2410
engineering_mode:
bluetooth:
name: control bluetooth
number:
switch.ld2410: [source /config/esphome/testradar.yaml:114]
platform: ld2410
timeout:
light_threshold:
name: light threshold
max_move_distance_gate:
name: max move distance gate
max_still_distance_gate:
name: max still distance gate
g0_move_threshold:
name: g0 move threshold
g0_still_threshold:
name: g0 still threshold
g1_move_threshold:
name: g1 move threshold
g1_still_threshold:
name: g1 still threshold
g2_move_threshold:
name: g2 move threshold
g2_still_threshold:
name: g2 still threshold
g3_move_threshold:
name: g3 move threshold
g3_still_threshold:
name: g3 still threshold
g4_move_threshold:
name: g4 move threshold
g4_still_threshold:
name: g4 still threshold
g5_move_threshold:
name: g5 move threshold
g5_still_threshold:
name: g5 still threshold
g6_move_threshold:
name: g6 move threshold
g6_still_threshold:
name: g6 still threshold
g7_move_threshold:
name: g7 move threshold
g7_still_threshold:
name: g7 still threshold
g8_move_threshold:
name: g8 move threshold
g8_still_threshold:
name: g8 still threshold
button.ld2410: [source /config/esphome/testradar.yaml:161]
Platform not found: 'button.ld2410'.
platform: ld2410
factory_reset:
restart:
query_params:
text_sensor.ld2410: [source /config/esphome/testradar.yaml:170]
Platform not found: 'text_sensor.ld2410'.
platform: ld2410
version:
mac_address:
select.ld2410: [source /config/esphome/testradar.yaml:177]
Platform not found: 'select.ld2410'.
platform: ld2410
distance_resolution:
name: distance resolution
baud_rate:
light_function:
out_pin_level:
name: out pin level
Which led me to think I needed something else?
The sensor is working fine on this code.
the yaml code is
esphome:
friendly_name: Testradar
esp8266:
board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "stuff"
ota:
password: "stuff"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Testradar Fallback Hotspot"
password: "stuff
captive_portal:
uart:
tx_pin:
number: GPIO1
rx_pin:
number: GPIO3
baud_rate: 256000
parity: NONE
stop_bits: 1
ld2410:
throttle: 1500ms
binary_sensor:
- platform: ld2410
has_target:
has_moving_target:
has_still_target:
- platform: ld2410
light:
moving_distance:
still_distance:
moving_energy:
still_energy:
detection_distance:
g0_move_energy:
g0_still_energy:
g1_move_energy:
g1_still_energy:
g2_move_energy:
g2_still_energy:
g3_move_energy:
g3_still_energy:
g4_move_energy:
g4_still_energy:
g5_move_energy:
g5_still_energy:
g6_move_energy:
g6_still_energy:
g7_move_energy:
g7_still_energy:
g8_move_energy:
g8_still_energy:
switch:
- platform: ld2410
engineering_mode:
bluetooth:
name: "control bluetooth"
number:
- platform: ld2410
timeout:
light_threshold:
g0_move_threshold:
g0_still_threshold:
g1_move_threshold:
g1_still_threshold:
g2_move_threshold:
g2_still_threshold:
g3_move_threshold:
g3_still_threshold:
g4_move_threshold:
g4_still_threshold:
g5_move_threshold:
g5_still_threshold:
g6_move_threshold:
g6_still_threshold:
g7_move_threshold:
g7_still_threshold:
g8_move_threshold:
g8_still_threshold:
button:
- platform: ld2410
factory_reset:
restart:
query_params:
text_sensor:
- platform: ld2410
version:
mac_address:
select:
- platform: ld2410
name: "distance resolution"
baud_rate:
light_function:
out_pin_level:
name: out pin level
web_server:
port: 80
version: 2
include_internal: true
ota: true
The official component is not able to use light, we modified a library to support this by turning on project mode, but you obviously have to remove this if you are using the official library.
According to the documentation on the official page, you should reduce a lot of the options in there.
The code for this section should be in a separate ld2410, not in the sensor.
In fact, if you use ld2410b or ld2410c and use Bluetooth to adjust the parameters, then all this code for fixed parameters can be removed. Otherwise restarting the esp32 after the Bluetooth adjustment will cause the parameters to be reset again.
- platform: ld2410
light:
moving_distance:
still_distance:
moving_energy:
still_energy:
detection_distance:
g0_move_energy:
g0_still_energy:
g1_move_energy:
g1_still_energy:
g2_move_energy:
g2_still_energy:
g3_move_energy:
g3_still_energy:
g4_move_energy:
g4_still_energy:
g5_move_energy:
g5_still_energy:
g6_move_energy:
g6_still_energy:
g7_move_energy:
g7_still_energy:
g8_move_energy:
g8_still_energy:
